C63 AMG (W204) 2008 - 2015
HELP ! Drag set up needed
Old 03-05-2013, 09:45 PM
Ezec63's Avatar
C63 Coupe
As the title says I'm on the lookout for a set of rear wheels/tires dedicated for drag strip use .. I have a 2012 c63 coupe and want to run this thing but obv need to do it the right way and need a dedicated setup.. For now ill be running the stockers up front but want a lightweight / sticky rear set up if anyone has anything for sale please let me know ! If not can someone recommend what to buy as a new set up which brand/tire/size/width/tiresize
Also I want it to clear my stock brakes without modifying the brakes/pads at all
Old 03-06-2013, 06:15 AM
TTA850's Avatar
2015 E63S AMG & 2013 GLK350
I'm in the same boat, went to the track Sunday and on stock tires it was tricky to launch cleanly. I'm leaning towards finding a set of oem rear wheels to mount a set of drag radials on for trips to the track but would love a 17" wheel option that doesn't look too out of place with the stock wheels up front and clears the stock brakes.
Old 03-06-2013, 06:54 AM
Faris63's Avatar
'13 CLS63 PP
CCW makes some good wheels for drag setup I would contact them
Old 03-06-2013, 08:09 AM
Dads C63's Avatar
2014 Audi RS7
CCW can make you 17" rears for Hoosiers and 18" front skinnies if you want the ultimate track package without modifying the rear brakes etc.... Great products and John a great guy to work with.
Old 03-06-2013, 12:24 PM
JumpinJim's Avatar
SL63
If you want cheap get some tsw RF series wheels and mount Mickey Thompson or whatever on them.
Old 03-06-2013, 03:58 PM
Ezec63's Avatar
C63 Coupe
Thanks for the response Keith ! I recently replaced my OEM wheels and tires with a set of 19" Forgestar CF10's wrapped in Nitto NT05's 245 F 275 R !
I was planning on wrapping my stock tires with some continental DWS Performance All season tires for the colder North East months and figure they will stick better than summers on cold pavement as the C will never see snow i have a range rover evoque for those duties
Would it be worth getting a custom lightweight 17" set up for the rears vs say using my stock 18's that are heavier wrapped in hoosiers? would the 17's be significantly faster? I dont mind the extra payment I want to run the fastest time possible without modifying my rear brakes
Can you provide me with an email or contact info for contacting CCW/John?
Old 03-06-2013, 03:59 PM
Ezec63's Avatar
C63 Coupe
Thanks for the input ! I just need help with right size/width/ and offset to make it all work together
Old 03-06-2013, 05:36 PM
JumpinJim's Avatar
SL63
Tsw interlagos 18x9.5 5x112 bolt pattern et 52 I think. They only make 2 offsets in that size and bolt pattern. 40 and 50something. You want the 50something. For tires you can use Mickey Thompson et street 2 in 265/40/18.
Old 03-06-2013, 08:28 PM
Merc63's Avatar
C63 AMG
Get a 17 inch rim and use Hoosier DOT drag radial. 275/40/17 I believe it is.
Old 03-06-2013, 08:39 PM
Ezec63's Avatar
C63 Coupe
Which 17 inch rims that would fit my car?! And size/offset help please I appreciate the suggestion ! I want to run a drag radial over a street radial for best times
Old 03-06-2013, 08:40 PM
Ezec63's Avatar
C63 Coupe
Jim thanks for the suggestion the price doesn't look bad on those hopefully I can get a drag radial vs a street radial that can fit them ill do some research
Old 03-06-2013, 08:43 PM
Merc63's Avatar
C63 AMG
I got really lucky, there was a guy on here that found a place locally that had some 17inch replicas. They fit perfectly and were only 200 bucks lol.
I think the guy only had 2 sets and we bought them up.
Another option is having ccw make you two of these:
http://www.ccwheel.com/wheelprofiles...php?id=Classic
This is what I was going to do. They are like 1300bucks though.
Offset would be the same as stock I assume??
Dont get a street radial, get those hoosiers, they are a true drag tire, the sidewall folds and grabs.
They are only DOT rated to compete in a specific racing class. It says all over them, not to drive on the street since the sidewall is so weak.
Old 03-06-2013, 09:27 PM
dodger63's Avatar
2013 f250 6.7 diesel
And the weight difference is huge!
Old 03-06-2013, 09:32 PM
Ezec63's Avatar
C63 Coupe
Wow 200$ you made out aright !
Yea Keith also recommended Ccw but is that price just 2 wheels without tires? That's a little steep if so but if that's the only option I can spend a little more money and do the right thing
Yes I'd prefer 17's but finding something available in the right offset is hard
I'm only considering Hoosiers I want the best possible time with my setup so streets are out of the equation as I will never street those tires anyway and there ultimate grip is compromised to be streetable
Old 03-06-2013, 09:55 PM
dodger63's Avatar
Ccw are great but u can find a much lighter 17" wheel
Old 03-06-2013, 10:13 PM
JumpinJim's Avatar
SL63
The MT ET Street 2 is a drag radial. Maybe you're thinking drag slicks? I think most people are either running the MT or the Hoosiers for drag radials. The Hoosiers are drag radials too, but not supposed to be driven on the street. They're a little sticker. You'd need to trailer the car or stuff them in the back and hope someone doesn't run off with the stock wheels while you're running. Some drive with the Hooisers on the street anyway. If you run slicks you definately can't run on the street.
The cheapest I found the TSWs for was $216 from lsdmotorsports. McCormack Racing the cheapest place for MTs. Haven't priced out Hoosiers.
Old 03-06-2013, 10:18 PM
Ezec63's Avatar
C63 Coupe
Hey dodger remember Bruce hit you up about 2 weeks ago regarding your drag set up? im the guy that was looking to get them put on but i dont want to shave the tabs off the back of the pads this is still going to be a street car most of the time ! Can you recommend another lighter wheel thats not a crazy price ?
Old 03-06-2013, 10:22 PM
Ezec63's Avatar
C63 Coupe
Ahhh ok judging by the name i thought it was a street radial made for ultimate street use not the purpose made drag strip setups ! Good news the Interlagos are pretty light and the offsets should work im just glad you can get a straight drag radial for 18's which gives me much more options
Old 03-08-2013, 10:42 PM
rory breaker's Avatar
Yes
You ran an 11.9@118 bone stock?
Old 03-09-2013, 07:48 AM
TTA850's Avatar
Yup, 100% bone stock just turned 2k miles.
Old 03-09-2013, 08:49 AM
Yes
Wow, how did that not get more attn here, am I the only one that thinks that's off the charts? Best I have seen stock with slip is maybe 12.2, 11.9 is flying!!!
Old 03-09-2013, 09:02 AM
TTA850's Avatar
Thanks, I should have a video too. My buddy with his 2012 mustang was in the right lane and his daughter was videotaping the runs so hopefully she gets back to me with it soon.
Old 03-09-2013, 01:56 PM
mvagusta's Avatar
bmw e-60 550i,bmw e-92 m3, c63coupe p31, stable of Italian stallions MV's
I knew the coupe 's are fast!!! I have a 2012 coupe p 31 with limited slip ...with slicks it'll do consistant high 11's
Old 03-09-2013, 02:25 PM
Yes
Why would the coupe be any faster than the sedan? Curious why you would specify.
On street tires 11.9 is by far the fastest I've seen a member here run, that's great.
Old 03-20-2013, 07:09 PM
2010c63amg's Avatar
2010 C63 amg
Would you happen to know if the Nitto 555R's in 285/35/18 will work with the TSW Interlagos? Or could I only run the Mickey Thompson in 265/40/18? Thanks for your help
Quick Reply: HELP ! Drag set up needed
