Michelin PSS 275s on stock 18" rims - feels wrong....
After doing some forum searching and talking to some guys in here, I figured out that Michelin PSS 275s will fit on the stock 18" rim without rubbing problems. But I am wondering if this is a situation of, "just because you can, doesn't mean you should".
I drive my car pretty hard as I am sure many in here do. What I have noticed is that the back-end feels loose now with these new tires. It feels like the side-wall of the tire is rolling (although I know that isn't what is happening), but it just doesn't feel right at high speeds and with aggressive cornering. I have checked the tire pressure and everything is right where it should be.
In a straight line under load, the PSSs feel amazing. Great traction.
I am assuming that by sticking wide tires on skinny stock rims that the tread has a little bit of lateral play now. I am assuming that all of you guys that are running after-market 19" rims with PSSs are not experiencing the same feeling???
Has anyone else ever experienced this? Is it is a Michelin PSS thing or is it my set-up.
I have a feeling a new set of HRE's are going to be on order shortly!!
Thanks in advance.
Happy Easter everyone.
http://www.michelinman.com/tire-sele...techspec_table
Thus you are getting that extra 10mm or so in the 265 PSS that almost makes it as wide as the 275 of other brands. In a PSS the 275 is too wide.
My Cl has 9.5 width wheels rear and the V12s feel mushy inversely as the OP said. A 275 V12 would be a better fit in the rear.
I'm going to stock PSS size all around this summer if we ever get it!
