New Born Weistec Stage 3 Monster
If so, heads have to come off.
Did you check the plugs on those two cylinders?
I have never heard of anyone having these or any problems at that either. Trust me I don't want to be the first or even be in this situation to make anyone look bad. Hopefully its all figured out soon and its something minor.
Joe
Just Kidding
, I'm sure its nothing. I really dont think there is anything wrong with your valves. 21000 miles, almost impossible. Plus your having the same misfiring codes we had cylinders 5 and 8. Good luck man!
Haha even though I didn't think it was possible to laugh about this situation I can honestly say you scared me for a second
I don't have the codes on hand but I am hoping I will have some sort of update by the end of the day.
If you sprayed oil out your tail pipes you got big problems.
Pull your plugs and check them.
If you have oil out the tail pipes, you have oil in your cylinders, rings, valves or head gasket.
You guys are crazy to run the old head bolts with stage 3, I wouldn't sleep at night for sure.
I hope it's something minor.
Surely, if it was an oil issue, then there would be blue smoke?
Cheers, Pickles.
A simple leak down test would tell him if it is rings, have they done a leak down? It is a fifteen minute task and should have been one of the first things they checked.
Things like this have to be taken into consideration before going down this path. Whenever you starting modding a car, unforeseen problems can arise. It's just part of the game.
