C63 AMG (W204) 2008 - 2015
Keeping Your Cool!!
Old Aug 7, 2016 | 04:55 PM
  #226
glennhl's Avatar
2011 C63
Is it my imagination or do FL cars run hotter?
Old Aug 7, 2016 | 05:06 PM
  #227
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yes they run much hotter. Blame the MCT.
Old Aug 7, 2016 | 06:42 PM
  #228
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Originally Posted by Mazspeed
You should have used Royal Purple, you would have dropped your oil temp 30 degrees.
Stop it!!!!
Seriously, ducting coolers, guiding airflows directionally can help, but the C63 needs bigger oil coolers, plain and simple. The 44O kit works great and is actually good value (for an AMG). It's a no brainer for anybody tracking their car.
Old Aug 7, 2016 | 06:48 PM
  #229
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Originally Posted by Wobble64
Stop it!!!!
Just having some fun.
Yes, the 440 kit I hear works brilliantly. I want one.
Old Aug 7, 2016 | 07:50 PM
  #230
Tlnt60's Avatar
2012 C63 AMG Coupe
Any potential new info on this? Also in AZ and its 110 today!
FL coupe if you're still taking orders?
Old Aug 7, 2016 | 11:31 PM
  #231
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Originally Posted by BLKROKT
Quick update. For those of you who think this will help you in summer heat, think again. I was just at NJMP this morning for a trackday on their Lightning course. My 44O kit has not yet been installed, but I thought I would make the drive and hope that early morning temps would be low enough for me to get a few sessions in. Well, by the time I got out on track, it was already 92F. I got 3 laps in (it's a short track) and the car went into limp mode at 275F. Tried to get back on it after cooling for a few turns, and hit limp mode in another half lap. I drove off the track, packed up my things, and drove home. So annoyed.
Anyway, this air guide works really well in the spring and fall, when the temps are at or below 80F or so. Also seems to be a benefit on long high-speed tracks, even up to about 90F. Once you get much above 90F though, forget about it, the air guide does practically nothing.
That pretty closely matches my experience. I'm not seeing any value from the air guide on my 2012 cpe - I'm fine on the streets but a road course on a hot day will quickly drive up engine oil temp and force you into limp mode . . . unless you manage rpms carefully.
I quickly ran into limp mode problems if I was running the engine up to red line on every shift. I found that I could run a long time, even on a hot day, if I didn't let it rev as far and shifted early enough to keep revs under about 6,800. Not as much fun as 7,200 rpm shifts but it beats going home early.
BLKROKT, I look forward to hearing that your 440 kit is installed and you are back out tearing up the tracks again.
Old Aug 8, 2016 | 10:12 AM
  #232
INS1GNIA's Avatar
'13 C63 AMG P31
Pretty sure he is still currently backed up from the previous orders and also really busy with his actual job. Might be a bit before he starts taking orders again. I think it is a great thing though since there was so much interest.
Old Aug 8, 2016 | 11:19 AM
  #233
Tlnt60's Avatar
2012 C63 AMG Coupe
Hey, no worries at all! Now it's just a race between my laziness (build my own) or waiting to get on the list for one!
Thanks Gents!
Old Aug 8, 2016 | 12:56 PM
  #234
BLKROKT's Avatar
It's not hard at all to make. Just takes some measuring and fitting. If you used a standard piece of plastic (like the kind used for the other air ducting on the car), you could easily do it start-to-finish in one afternoon.
Old Aug 8, 2016 | 09:17 PM
  #235
Asher4799's Avatar
2009 C63/ 2015 C63 507 coupe
Hey I'm really sorry guys got two made and just aren't getting any good quality out of the mould. At this time don't feel comfortable with charging for something that isn't good. My suggestion is to get a pre made plate and do the cutting that way the measurements that are on thi thread are really great.
Sorry for the lack of communication on my part .
Old Sep 3, 2016 | 06:55 AM
  #236
Renius's Avatar
C63 PPP 2012
+1
I have tried this also. Especially on slower more technical tracks, this works quite well, not as fun of course. But the 44O package is probably the right thing to get if you are planing to tack car more often.
Old Nov 22, 2016 | 08:57 AM
  #237
Adam Chambers's Avatar
2014 C63 Sedan (SOLD), 2011 SLS Gullwing (SOLD), 2009 SLK55 (SOLD), 2015 C7 Z06 7MT, 2016 C450amg
Has anyone made one using ABS instead of the CF plate? Just curious as I dont really care what the finish looks like, just want the functionality.
https://www.amazon.com/ABS-Sheet-Thi...s%2Bsheet&th=1
Old Nov 22, 2016 | 01:19 PM
  #238
zcct04's Avatar
Anything that is moderately stiff, weatherproof and easily cut and trimmed will work.
Old Dec 7, 2016 | 11:29 AM
  #239
tpliquid's Avatar
too poor now
I finally powered on my Solidworks computer for a long time. I am able to draw this up and have made. Someone can give me the dimensions i'll draw it up. Or i'll just mock one up on my car and draw it up.
Old Dec 7, 2016 | 12:33 PM
  #240
INS1GNIA's Avatar
'13 C63 AMG P31
All info is from this thread:
Ok, this should get you FL guys started. It's not perfect (no ****ty comments), but make a template out of cardboard to test the fit and then go from there. Good luck.
I just finished fabbing a blockout plate for a 2012 coupe. Finding carbon on short notice wasn't doable so I tried first using acrylic (plexiglas). I found some smoke-gray stuff that looked pretty good but proved to fragile and was really sensitive to stress cracking. Next attempt was using plywood (3/8" luan). It isn't sexy and probably won't last long. However it is cheap and really easy to fab with just a jigsaw. I'll put a couple coats of primer on it to get through the season, spray it with some black to hide it and then build a better one over the winter.
In anticipation of making another in the future, I traced a template and saved it as a pdf. In hopes of saving someone else a lot of time measuring and fitting, I've attached a copy. It's 4 pages, full size, something you can just tape together and trace onto your material. When you print, be sure to print 'full size' and not as 'fit to page'. There are inch markings across the top so you can confirm that the size is correct.
Note that this fits a 2012+ coupe, probably fits a 2012+ sedan, and definitely does NOT fit a PFL car.
Old Dec 7, 2016 | 12:35 PM
  #241
tpliquid's Avatar
too poor now
great. i'll get started this weekend
Old Dec 8, 2016 | 04:21 PM
  #242
SuperFastYo's Avatar
C63 AMG - LSD
Yo, are your foglights intake holes?
Old Feb 9, 2017 | 07:56 AM
  #243
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
Guys, tell me how to attach this panel? Using double-sided tape?
Old Feb 9, 2017 | 09:29 AM
  #244
C63 AMG - LSD
And self tapping screws.
Old Feb 9, 2017 | 09:48 AM
  #245
BLKROKT's Avatar
You've really demonstrated a total inability to read through threads for instructions and other info lately. It's all in here dude.
Old Feb 9, 2017 | 04:48 PM
  #246
Alex-r-1's Avatar
I don't understand how to attach a plate from the front grille.
Old Feb 9, 2017 | 04:59 PM
  #247
BLKROKT's Avatar
Old Feb 10, 2017 | 07:46 AM
  #248
Emkovich's Avatar
C63
I want to start manufacturing this plate for my c63. What thickness is better to use a carbon plate?
Old Feb 10, 2017 | 08:01 AM
  #249
BLKROKT's Avatar
I used 1.7mm carbon fiber plate. Perfect thickness. Definitely use a respirator and cut it outside, carbon fiber particulate is very bad to inhale.
Old Feb 10, 2017 | 08:29 AM
  #250
Emkovich's Avatar
C63
OK! Thank you!
I'll make plate from sizes that you have shown before. They accurate?
