Just recently picked up my new 2013 C63 coupe and now I'm looking for the right set of wheels! My initial thought where to put on 20", however, based on some of the readings and research that I have done it appears that 20" have more con's then pro's over a set of 19"?
Any help here would be great! Cheers!
You have to consider the roads conditions in your area... there is no right or wrong from choosing 20's over 19's ... the only difference will be the height of the tire sidewalls which gets thinner with the 20's... therefore more prone to damaging the wheels if the roads in your area are bad.
Plus keep in mind that tire size/brands are more limited with 20's. Good luck in your decision.
In summary:
20's = for look
18/19's = for performance
In summary:
20's = for look
thanks for the reply! Hmmmmm??? I had an easier time purchasing a house then I'm having purchasing wheels,LOL...
Former Vendor of MBWorld
PM Sent- I have been working with another C63 coupe owner on a new set of wheels.
SPONSOR
thewb
SPONSOR
close
- Join DateJan 2005
- LocationMIAMI, FL
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drivewww.wheelsboutique.com
Liked:246 Times in 190 Posts
Also take into consideration the design of the wheels. Wheels without a lip may look large enough in 19inch for the look you're going for. While a 19inch wheel with a lip may appear too small.
I had aftermarket 19s but decided to go 20s... To me it looks better but ride quality has suffered
Quote:
What do you mean by "suffered"? I'm on OEM 19" and I feel that the ride is pretty ruff as it is...do 20"Originally Posted by dcm95ss
cause a real drastic change in road 'bumps' feedback i.e. lower back pain suffering, LOL...
Or do you mean handling has suffered ?
ExploreYou will use tires with a lower tire profile so the ride will be much rougher.
Currently Active Users (1)
