C63 AMG (W204) 2008 - 2015
What is this yellow light?
Old May 26, 2013 | 01:04 PM
mrl0n3ly714's Avatar
SLK 55, CLS 550, C63
I had check oil for next refill then i add about half of 5w-30 in it
Then run around 1h then i see this light
https://skydrive.live.com/redir?resi...Ir52-vQsA8R-08
Can anyone tell me what is it ?
Old May 26, 2013 | 01:13 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
Check engine light and you put the wrong oil in the car. 5W-40 or 0W-40
Old May 26, 2013 | 01:17 PM
what should i do now ? Im going yo dealer to change oil on next Monday.
Is it drivable now ?
Old May 26, 2013 | 02:49 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
1/2 a quart isn't going to do anything. If you're getting an oil change on Monday anyway I wouldn't be too worried.
On Monday get your dealer to pull the codes and fix accordingly.
Old May 26, 2013 | 06:33 PM
BD-C63's Avatar
2015 C63S AMG
My understanding is that the CEL is typically something emission related. I would guess that it had nothing to do about the oil...
Old May 26, 2013 | 07:21 PM
CarHopper's Avatar
E63S | X5
A CEL can be literally anything not just emissions. Maybe emissions is more common but not just restricted to...
It happened just after the oil so chances are it is related to that, however, the only way to really tell us pull the codes and go from there.
Old May 26, 2013 | 07:40 PM
shades's Avatar
09 C63, 11 Cayenne S
Yeah you gotta put the right spec oil in as well, not just 0-5w40, I think it's 229.5 spec non diesel or you get lifter noise
Old May 26, 2013 | 08:15 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
The most current spec. is 229.51, and in it calls for 5W-40 ESP Formula M. The dealer will likely use Mobil 1 5W-40 Formula M (non ESP) per the older 229.5 spec.
Regards,
Joe
Old May 26, 2013 | 11:08 PM
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
Regards,
Joe
What's the difference between ESP and non-ESP?
Old May 26, 2013 | 11:25 PM
Rsquad911's Avatar
229.51 just means it's fine for diesel and petrol cars.
Old May 27, 2013 | 12:03 AM
Valvestud's Avatar
ESP stands for Emission System Protection. It's a low ash formula. Here's a link to their page:
http://www.mobiloil.com/USA-English/..._M_5W-40.aspx#
Old May 27, 2013 | 11:01 PM
The CEL gone after couple days i guess the engine learned the new oil and be normal ?
Old May 28, 2013 | 01:13 AM
roadtalontsi's Avatar
10 C six trizzle
probably loose gas cap
