C63 AMG (W204) 2008 - 2015
15mmF 10mmR HR Spacers HR Springs 235/18 Conti 265/18 PSS
Old Jul 16, 2013 | 11:43 AM
khmergod's Avatar
2011 P31 C63 2015 CLA45
http://s1103.photobucket.com/user/kh...?sort=3&page=1
Full walk around of stance.
Went really aggressive up front because wanted to look flushed and matched with the rears since our front fender is so wide. Go wide or go home!
I used 43mm bolts front and 40mm bolts rear. 0 ticking sounds. Tech said there's more than enough room to clear the parking brake.
p.s. each picture has before and after
Want to give a big thanks to Matt(olszowa) for recommending the widest and safest spacer to get. He had experiences with all sorts of sizes and assured me I'd be fine in normal driving situations.
Thanks to Jasonoff and diabolis as well.
Sig is fully stock.
Old Jul 16, 2013 | 12:49 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Looks great. Love the flush look. I'm actually a fan of the stock 18's no matter what people say...
Am I seeing things or could you of gone out about 2mm or so? Still not perfectly flush? Maybe its just the angle...
WE NEED SOME SIDE PICS OF THE WHOLE CAR
Old Jul 16, 2013 | 12:51 PM
chrisridebike8's Avatar
'10 C63
that looks awesome. any issues with rubbing, especially on the fronts?
Old Jul 16, 2013 | 12:53 PM
LIC63AMG's Avatar
2000 E55
looks good, you might get a little bit of settling after some time. mine seems to settle slightly after a week or so and some miles on it.
Old Jul 16, 2013 | 01:02 PM
mvagusta's Avatar
bmw e-60 550i,bmw e-92 m3, c63coupe p31, stable of Italian stallions MV's
Front driver side will rub or hit, hit a bump while turning you'll get a crease in the inside of fender.
Old Jul 16, 2013 | 01:26 PM
khmergod's Avatar
I don't hear any rubbing atm. Drove about 30 miles. @zephyr, Not going to risk going any further up front due to the chance of buckling a fender. Tech told me that front might rub, rears should be ok. So far so good. Will get some pics from side profile tomorrow.
Most stretched due to the bump in road.
the aftermath
Was going about 55 on a boulevard. hit a curved bump. This is a screenshot of the video. That was the driver's rear fender. I either rubbed or was 1mm from rubbing. No change in sound of video and I didn't really hear anything.
Old Jul 16, 2013 | 01:35 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Oooweee, that's a tight fit in that video. Cool shot!
Old Jul 16, 2013 | 01:39 PM
khmergod's Avatar
Springs were installed a month ago.
Old Jul 16, 2013 | 01:40 PM
khmergod's Avatar
Your turn bro!
Old Jul 16, 2013 | 02:04 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
My 14mm rubbed in the rear at the track. 14mm on the fronts were fine. On H&R springs.
Old Jul 16, 2013 | 02:07 PM
khmergod's Avatar
Yours would definitely rub. I think I'm cutting it close.
Old Jul 16, 2013 | 02:16 PM
ZephyrAMG's Avatar
Your car almost rubbed one out in that pic, so to speak
Old Jul 16, 2013 | 02:32 PM
khmergod's Avatar
I live my life a quarter mile at a time.
Old Jul 16, 2013 | 02:38 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
The fronts would rub slightly on a dip with the wheels straight. Too much camber when the wheels are turned so no chance of rubbing.
Couldn't get the rears to rub on the street but the track was a different story
Old Jul 16, 2013 | 02:41 PM
ZephyrAMG's Avatar
Hahah me too bro
Old Jul 16, 2013 | 02:42 PM
khmergod's Avatar
What size wheels and tires? I don't drive crazy on the road, only off the line do I punch it. I'd assume I'm pretty safe with this setup unless I'm on the track, correct?
Old Jul 16, 2013 | 03:10 PM
noodleman's Avatar
2014 E63S Wagon
looks good
Old Jul 16, 2013 | 03:15 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I posted all the info in your last thread. I was rubbing the sidewall almost half way down
No way would you get that much heat into the tires and suspension compression on the street. I think if I had 10mm it may have been fine.
Old Jul 16, 2013 | 03:24 PM
khmergod's Avatar
No major damage from beating her so hard on your track day?
Old Jul 16, 2013 | 04:01 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Nope just grinded the inside lip on the rear fender. Little bit of paint will fix it up.
Old Jul 16, 2013 | 04:10 PM
olszowa12's Avatar
'08 C63 Estate
Finally! - I thought you wouldn't get these installed until next year...
I'm glad I could help. Enjoy the new look
Old Jul 16, 2013 | 04:56 PM
khmergod's Avatar
Your fault lol
Old Jul 16, 2013 | 06:53 PM
adv4nced53's Avatar
2010 C63 AMG
Just to warn readers, 40mm lugs with 10mm spacers will touch the ebrake assembly and click in some of our cars. There's a tolerance difference from car to car and 40mm was too long for my car. Looks like they work for you though & car looks good!
Old Jul 16, 2013 | 07:12 PM
khmergod's Avatar
It might be a model year issue with bolts. Some say stock bolts are 27mm, while others say 28mm. Maybe clearance for perf. pack is higher?
Old Jul 16, 2013 | 07:35 PM
adv4nced53's Avatar
2010 C63 AMG
It's possible. There is a rotor in the way too that may have a difference thickness with the PP. The assembly lives inside the hub though and I can bet that it does not fit in the same spot every time.
