507 Exhaust Crackle and No Paddle shift while turning
So I have had my car a few days (507 sedan), and have experienced a few things and wanted to know if they are normal / usual for C63s.
The first is the amount of crackle I get on downshifts when engine braking. Does everyone get this? Don't get me wrong, it sounds great, but it sounds more like a race car than a road car.
The other one is I noticed that the paddle shifters dont seem to trigger a shift if the steering wheel is turned (ie if you want to shift gears going around a corner then you have to use the stick shifter), is this correct? I didn't do extensive testing on this but the couple of tries I had seemed to yield this result.
Do you have a vanilla C63? Or has it been tuned?
EDIT: it seems that this would be the result of a highly tuned engine rather than standard.
I'll try to record some sound of this.
often times lack of sensitivity is caused by distortion of the paddle assembly due to over tightening of the mounting screw. (see attached pic). Overtightening and/or off-angle trauma to paddle can also cause the paddle "frame" to crack (generally eminating from mounting hole in frame casting). this will make operation of the paddle hit and miss as well.
for those seeking to increase sensitivity of the paddle (that is not otherwise damaged), you can disasemble the paddle and put a plastic shim under the pcb (printer circuit board with integral switch). 0.020" is a goog place to start. This shimming is a necessity in some cases where factory paddles have been modified with carbon fiber coating.
relative to the OP's experience with his low-functioning paddles, I agree with those opinions already stated, paddles should (must) work while steering ....
cheers,
Chris
cheers,
Chris
You got PM..
