C63 AMG (W204) 2008 - 2015
9x18 et45 front, 10,5x18 et60 rear?
Old Sep 26, 2013 | 10:32 PM
wahlsten's Avatar
C 63 AMG
9x18 et45 with 260/660-18 front, 10,5x18 et60 with 280/660-18 rear?
Does it work?
Or what offset should i go with?
Old Sep 27, 2013 | 01:44 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I would say the front should work with 18x9 +45mm (not sure about running 260/60/18 though.. Sounds meaty to me).
The rear might be a problem 18x10.5 +60mm should work in theory, but in real life they might have a big chance of rubbing the inner suspension if u are lowered. Again 280/60/18 sounds like a very odd size. I would suggest u 285/35/18.
Old Sep 27, 2013 | 02:14 AM
wahlsten's Avatar
C 63 AMG
The tires is DTM racing slicks 260/660-18 and 280/660-18
Old Sep 27, 2013 | 02:19 AM
wahlsten's Avatar
C 63 AMG
its not profile in % its 660 mm total high if the tire stand on the ground!
Old Sep 27, 2013 | 10:25 AM
Roswell's Avatar
I see, but i still think your 18x10.5 +60mm will touch the inner suspension... maybe +55 would be ideal.
Old Sep 27, 2013 | 12:46 PM
Mort's Avatar
I think the 660 height may be too much. 650 would be better if available. I am running a 245/35/19 on the front (~ 655) and it rubs the inner fender liner on the left front.
Roswell is correct that an ET60 on the rear with a 10.5 wheel will likely rub on the inner suspension.
Your widths of 260 and 280 will be very close as well if they don't rub the fenders.
Old Sep 27, 2013 | 12:54 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Like Roswell said, probably it will rub - not only because of the rear rim width and offset but also because the 660 mm metric tires are about 1" larger overall in diameter than the OEM size on the C63. Add to that the fact that racing slicks usually run fatter than their street counterparts of the same size and chances are you'll be rubbing.
If you're not lowered, 260 width on the front should be fine on a 9" wide rim (no issues running 255s on the front on a car with the AMG sport suspension).
Old Sep 29, 2013 | 10:20 AM
wahlsten's Avatar
C 63 AMG
Hmm, ok
I have H&R Coilovers, max drop rear and 2cm from max drop front right now.
