Sup guys, I'm looking into getting some spacers & lug bolts to bump out my wheels.
I'm not sure on the exact sizes yet, but I'm thinking of staying conservative... 10mm on OEM wheels type of thing.
Where can I find a good place for lug bolts? I know of a source for spacers... lug bolts I'm having a hard time with. Also, any additional info you think I should know, please pass it along. These would be for OEM 18" wheels.
Thanks!
Matt
Thanks!
Matt
Site sponsors have them, Vivid Racing, ACG, 3WD, or you can try ECS Tuning. Use to buy parts from them for my Audi.
Mort
close
- Join DateFeb 2010
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2012 C63;1971 280SE 3.5(Sold);2023 EQS 450 SUV 4 Matic (Wife's)
Liked:484 Times in 399 Posts
Spacers 10 to 15 mm front most do 10 or 12mm front and 10 mm rear (no more).
Tires 235 or 245 front and 265 or 275 rear.
Lug Bolts - OEM - M14 x 1.5 with R14 Ball Seat 27mm shank
One source for good quality lug bolts and spacers: Look under the RAD tab for German bolts and they have chrome and such under the Otis Inc LA tab.
http://otisincla.com/
Have fun with the new car.
Thanks for the responses guys... looking into RAD right now.
I would want to go a bit conservative up front and go with 5mm spacers... such a short length, I don't think I'll need hub centric one's as much of the hub will still be sticking out past the spacer.
And I'm thinking of going 10mm rear... so I'm wondering, can I get away with buying 37mm length lug bolts all around, or will they be too long up front? (Trying to avoid different size lug bolts).
Thanks,
Matt
Thanks,
Matt
mthis
close
- Join DateJun 2008
- LocationNy
- Vehicle(s) I driveAnything W/4Wheels
Liked:31 Times in 30 Posts
Quote:
X2. Originally Posted by Chris420
Tikore.
Great customer service as well.
Mort
close
- Join DateFeb 2010
Thanks,
Matt
You should be fine with 37mm lug bolts all around. You can't go too long on the rear or the bolts will interfere with the parking brake mechanism. You will be fine on the front.Originally Posted by mdgrwl
Thanks for the responses guys... looking into RAD right now.I would want to go a bit conservative up front and go with 5mm spacers... such a short length, I don't think I'll need hub centric one's as much of the hub will still be sticking out past the spacer.
Thanks,
Matt
If you go with a 5mm spacer on the front you may or may not still be able to centre the wheel. The hub is only 8mm, so when you take 5mm away that does not leave alot for the wheel to centre on. The OEM wheels may be fine but I have aftermarket wheels with a chamfer on the inside edge and they will not centre on the 3mm projection. I will get vibrations depending on how well I get the wheels centered or not. I have read of people using a 5mm spacer without problem so you may be fine.
Diabolis
close
- Join DateJan 2013
- LocationThe Great White North
- Vehicle(s) I driveW204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Liked:811 Times in 554 Posts
^^^ This.Originally Posted by Mort
You should be fine with 37mm lug bolts all around. You can't go too long on the rear or the bolts will interfere with the parking brake mechanism. You will be fine on the front.If you go with a 5mm spacer on the front you may or may not still be able to centre the wheel. The hub is only 8mm, so when you take 5mm away that does not leave alot for the wheel to centre on. The OEM wheels may be fine but I have aftermarket wheels with a chamfer on the inside edge and they will not centre on the 3mm projection. I will get vibrations depending on how well I get the wheels centered or not. I have read of people using a 5mm spacer without problem so you may be fine.
ExploreMBWorld Fanatic!
it's troublesome to mount the wheel with a 5mm spacer, but I don't notice any vibrations with my car. The tapered bolts plus the correct torque specs seems to help getting the wheel centered.
Can anyone confirm 37mm lug bolts will be fine with a 5mm spacer up front with 100% certainty?
I have an email in with RAD and they are saying they will be too long…. But folks here in this thread are saying itsfine. Just making sure I don’t pull the trigger on mis-information.
i'm using a 35mm locking bolt on the my front wheels with NO spacers without any issue. You should be fine with a 37mm bolt with a 5mm spacer.
^ Thanks. And how would a 39mm lug bolt do in the rear? Too long in the rear?
with a 10mm spacer in the rear? Hard to say.
I'm using the same 35mm bolt with a 5mm spacer in the rear and it's fine.
so doing some math, 35-5-27 = 3mm, 39mm with a 10mm spacer would be 39-10-27 = 2mm longer than stock. You should be ok, but definitely test it by making sure the rear wheels will turn before putting the wheel back on the ground.
If i were you I'd get the same length lug bolts that will work front and rear (37mm), it's annoying to deal with two different length lug bolts for the front and rear like i'm doing now.
Originally Posted by noodleman
with a 10mm spacer in the rear? Hard to say.I'm using the same 35mm bolt with a 5mm spacer in the rear and it's fine.
Gotcha. Sounds like a plan. I'll stick to 37mm
Another quick question -
Any rubbing with 10mm spacers in the rear with 265 PSS on OEM 18's ? Can I push 275's ? Stock ride height FWIW.
on stock ride height i don't think you'll have an issue with 275s.
Quote:
I have 10's on the rear with PSS 265/35/18 on oem's and no rubbing
What lug bolts did they give you? I notice they only carry H&R 35mm & 40mm shank length. I'm guessing 35mm? If so, how many full lug turns did you get out of them?Originally Posted by Ingenieur
ECS tuning worked for meI have 10's on the rear with PSS 265/35/18 on oem's and no rubbing
RAD is out of stock of the 37mm size
Optimum lenght would be 37mm for a 10mm spacer - but RAD is out of 37mm spacers.
RAD & H&R both have 35mm though.... is 35mm safe? Just 2mm, my guess is yes as I would only be losing 1 lug turn.... but wanted to confirm with you guys first.
Diabolis
close
- Join DateJan 2013
You can try EZAccessory.com (http://www.ezaccessory.com) - I got some black 10.9-grade hardened steel lug bolts there myself.
P.S. They've also got spacers, but I'd stick with H&R - who usually also have bolts in lengths specific to the specific spacer application.
Currently Active Users (1)
