C63 AMG (W204) 2008 - 2015
C63 Edition 507 wider tires
Old Nov 19, 2016 | 11:50 PM
  #51
WESLEY KAY's Avatar
2014 C63 AMG 507
Originally Posted by georgy
I have a sedan with the 19 inch multispoke wheels. I assumed they were the same offset and width as the 507's.
I read somewhere that another guy was having rubbing issues with 275 on the inside, which makes sense cause it's pretty tight in there. That's why I thought that a 5 mm spacer would work work for the inside clearance, but not sure about outsude.
Yeah I read that somewhere too. Well no issues here. Yeah it's tight on the inside, I won't lie (that's what she said), but it clears. No rubbing yet and it's been six months. And the MPSS are awesome!! I hear another new tire is coming out to replace them though, from Michelin. Something comparable or better.
Old Nov 20, 2016 | 03:38 PM
  #52
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I had issues on my 335 when I went to PS2, they were wider than the equivalent Bridgestone by about 3mm, so guess it just varies tire to tire exact width of actual size.
New PSS is PS4S
http://www.roadandtrack.com/car-cult...lot-sport-4-s/
Old Nov 20, 2016 | 03:42 PM
  #53
WESLEY KAY's Avatar
2014 C63 AMG 507
Yeah PS4S....those are them.....good find!
Old Dec 11, 2016 | 08:59 PM
  #54
MFitz's Avatar
C63 AMG Edition 507
Originally Posted by Thrilla
H&R makes 10mm spacers. You will need extended lug bolts.
Anybody running 275 rears with spacers ?
Old Dec 12, 2016 | 11:10 AM
  #55
Mort's Avatar
Not likely.
Old Dec 12, 2016 | 11:42 AM
  #56
MFitz's Avatar
C63 AMG Edition 507
Ok, thanks Mort.
Your car has a nice stance from the rear.
What set up are you using?
Old Dec 12, 2016 | 07:41 PM
  #57
Mort's Avatar
Thanks MFitz.
I have HMS flares on the rear and running 20 x 11 ET +16.
Currently have Pirelli PZero Nero GT 295/25/20 but switching up to 305/25/20 over the winter.
You can likely run 275 on OEM wheels 18 (19) x 9 +54 but a spacer will make it rub.
Old Dec 17, 2016 | 08:40 AM
  #58
MFitz's Avatar
C63 AMG Edition 507
Impressive mods Mort!
Its great to see 295's & 305's on these cars...too bad the manufacturers don't do that, except Porsche it seems.
Thanks for the information.
After reading all of these interesting posts, I'm going to have to choose between 12mm spacers on the stock tires or putting 275's on the rear.
The 275's may provide a better look.
Old Dec 20, 2016 | 03:23 AM
  #59
Alex-r-1's Avatar
C63AMG Coupe 507, GL X166
Originally Posted by 149max
Nope no rubbing.
My rear fender clip (where bumper meets the rear quarter panel) is modified tho. Which gives me way more clearance.
Without the mod, you will prolly rub for sure if lowered.
Here's another shot of the rear fitment.
Tell please how you modified tho? Maybe you have photos?
Old Dec 20, 2016 | 12:31 PM
  #60
georgy's Avatar
2013 C63
Originally Posted by Mort
Thanks MFitz.
275 on stock wheels will not rub on outside 110%, but might rub on the inside fender lining, hence running a 3-5 mm spacer to clear.
Old Dec 20, 2016 | 05:09 PM
  #61
Mort's Avatar
The problem with a 3-5 mm spacer is that it is possible that the wheel will no longer centre on the hub and will end up with vibration at highway speeds from being slightly off centre when mounted.
Old Dec 20, 2016 | 06:45 PM
  #62
georgy's Avatar
2013 C63
Why would it not be centered?
Good spacers are hub-centric and hold the wheel dead center on the hub. I've never had issues with spacers and vibrations.
Old Dec 21, 2016 | 04:47 PM
  #63
Mort's Avatar
No spacer less than 10mm has a hub centering flange for the C63. Any spacer less than 10mm is a flat disc and will not centre the wheel hub. If the spacer moves the wheel out more than about 3mm the wheel hub will no longer centre on the hub extension and it will be difficult to get the wheel to
centre when you torque down the lug bolts.
Old Dec 21, 2016 | 09:56 PM
  #64
georgy's Avatar
2013 C63
Yea, you're right about that. Never looked into spacers less than 10 mm thick before. They just need to be installed carefully, I guess.
Old Dec 23, 2016 | 07:21 PM
  #65
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
I too am hoping that 149max would share the secret recipe for fitting 275 MPSS + 10mm spacers in the rear. All he's shared is modded fender-bumper clip and KW V3. An inside fender pic would say a lot.
Old Jan 8, 2017 | 09:31 AM
  #66
Alex-r-1's Avatar
Nope no rubbing.
You modified the black bracket? How to do it?
Old Apr 10, 2017 | 05:45 PM
  #67
MFitz's Avatar
C63 AMG Edition 507
I am planning to order H&R 12mm spacers (all the way around) with 40mm bolts for my 507 since H&R seems to be the brand of spacer that most are going with.
I have spoken with H&R but didn't find them very helpful.
Can anyone tell me what part number the 12mm spacers are and what type of bolt (round head or tapered)?
Many Thanks.
Old Apr 10, 2017 | 06:38 PM
  #68
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Many Thanks.
Lug bolt type depends on wheel type, not spacer type
Old Nov 4, 2017 | 08:43 PM
  #69
immelman's Avatar
C63 AMG
Sorry to dig up an old thread but I was wondering what some of the 507 owners in this thread ended up doing. I just got a 507 and was interested whether or not anyone has tried a 245 / 275 MPSS combo no spacers and with H&R's. Curious if you had any rubbing with the combo I am thinking about doing.
Old Nov 5, 2017 | 11:39 AM
  #70
Thrilla's Avatar
Veteran: Army
It’s not your exact setup, but I have KW V3 coilovers with a similar drop to H&R springs. I’m running 245 with a 12mm spacer up front, and 265 with a 10mm spacer in the rear. Tires are sumitomo htrz3. No rub even with passengers in the rear.
Fronts should be fine with MPSS 245 even with a spacer. The rears, I think 275 may work. I’m going with that combo at the next tire change. Do you have the thicker spring pads in the rear?
Old Nov 5, 2017 | 11:48 AM
  #71
immelman's Avatar
C63 AMG
[QUOTE=Thrilla;7304308Do you have the thicker spring pads in the rear?[/QUOTE]
Thanks for the Reply. I have not lowered the car yet but I was planning on buying the thicker pads in case I needed them.
Old Nov 5, 2017 | 03:08 PM
  #72
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I just put 255/ 275's on my new to me 507 sedan..... perfect fit without spacers on stock suspension - suspect I'll even be able to get the H & R 12mm spacers in once the dang longer titanium lugs finally show up...
and I went 255/35/19's & 275/30/19's w/ Hankook V12's..... ( I blew a rear tire jsut after purchase so didn't have much time to wait for Michelins..)
Old Nov 5, 2017 | 06:37 PM
  #73
immelman's Avatar
C63 AMG
Great info. Thanks for the response! Do you any pics by chance?
Old Jan 7, 2018 | 09:17 PM
  #74
sarchib's Avatar
1982 300D (W123) & 2013 C63 P31
Originally Posted by LakeShow23
I just ordered 245s in the front with 265s in the rear. Michelin Pilot SS
LakeShow23, am buying a set of 507 wheels for my 2013 C63. Noticed that you made a +1 upsize to your tire purchase in September 2014. Any interference issues on front or back? Were you able to make the tire upsize without using spacers? Thank-you.
Old Apr 9, 2018 | 06:59 PM
  #75
hadam3's Avatar
Top Answer: 1
996 Turbo, E86 Z4M, GLE 63 AMGs
Wanted to add my experience here for other members looking to go wideeerrr...
255/35/19 PS4s Fronts and 275/30/19 PS4s Rears.
Rear is flush, and if I were to go 285s, I’d probably need a spacer to bring the wheel out for clearance + roll fenders.
Front has ALOT of room. And if sizes were available + wheel could take the width, it could go 265s no problem.
Some pics to show how the gap/clearance. *i am on stock suspension 507edition.
