Wheel hop?? ('13 C63)
I've got about 1,800 miles on my new '13 C63.
Even with the traction control completely disabled, it feels like the rear of the car is about to explode/fall apart when I stab the throttle from a stop in S+.
Is what I'm experiencing just ultra-violent wheel spin?
Or is it wheel hop? I didn't think wheel hop was an issue on the C63.
Any feedback would be appreciated. I'd be happy to answer any follow-up questions.
Thanks in advance.
It's cold here right now (41 degrees Fahrenheit) and I'm still running my summer tires (OEM Continental tires).
I'm thinking it's time I put on my new Bridgestone Blizzak LM-32s.
I wasn't feathering the throttle at all. I was just flat-out mashing it (on purpose) to see how the car would respond.
I've used Race Start feature twice and have experienced a bit wheel hop using that as well.
Everything about the car feels strong. The engine, the brakes, etc.
Suspension has felt wonderful as well. I'm wondering if the wheel hop I'm encountering is a product of user error. Alternatively, I'm trying to determine if other variables (tire pressure, temperature, etc.) are contributing to its occurrence.
I've been researching C63 wheel hop thoroughly and cannot find a lot of information. I don't see how this could be an issue at all on such a strong-running, well taken care of, new car.
I don't seem to remember any wheel hop issues at all during the scorching September we just had here.
If that's the case, I'll put on the Blizzaks immediately. I was waiting because I still have a 750i xDrive that I use for the winter.
Thanks.
So do you think the fact that I'm still running the summer tires in cold(er) weather is playing a significant role in this?
Thanks.
I do have a factory LSD.
What tires are you running?
I'm running the OEM Continental tires.
Would be happy to answer any other questions. Trying to diagnose this ASAP. Thanks.
Edit: cold and wet, I drive the beater to work. Lol
Thanks for the extra info. I can see why you have likely never experienced it then. If you've got great grip, it shouldn't be an issue. If you have no grip, then it shouldn't be an issue.
When your grip somewhere in between, prepare for your spine to be punched. Hard.
I noticed today that, despite the cooler temperatures (and despite the fact that I'm still running my summer tires), I did not experience any wheel hop.
The difference: I made sure the tires were warmed up.
https://mbworld.org/forums/c63-amg-w...ons-print.html
Was that you?
I've heard from several people now that they have indeed experienced it at one point or another. Consider yourself fortunate that you've always had phenomenal grip!
Wheel hop is also relatively common for the E9X M3s, I've come to learn.
I've checked out the car. Everything looks good, as suspected (it is a brand new car with less than 2,000 miles on it, after all).
In any event, it looks like cold temperatures and cold tires played a major role.
You are also playing with the devil if you are really running summer tires at 15f (if you mean celsius then you are ok but in the low end of use) your 5P's should not be used under 45F/7C, Continental will deny warranty due to cracking as the rubber gets so hard below freezing it will damage the tires and probably end up killing someone as they are almost useless at low temps.
