C63 AMG (W204) 2008 - 2015
Head Bolt Affected VIN - 2010 & older, & early 2011s
Old Aug 6, 2017 | 10:56 AM
  #926
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by Suat k
I curious for that headbolt issue. But I am not sure my car is in affected range or not.
Could you please check engine code.
WDDGF7HB6AF405036
Is your north american car a 2010 or older?
Old Aug 6, 2017 | 12:11 PM
  #927
Suat k's Avatar
c63 amg
2010 sw american
Old Aug 6, 2017 | 02:11 PM
  #928
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
WDDGF7HB6AF405036
2010 sw american
Old Aug 6, 2017 | 04:33 PM
  #929
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
2010 sw american
SA is still the NA market.
The only confusion is with the EU market cars because a 2010 could actually be a 2011 built car.
Your car is for sure affected. https://www.vindecoderz.com/EN/check...GF7HB6AF405036
Chassis
Sales designation: C 63 AMG
Order number: 0 0 714 10550
Delivery date: 08 09 2009
Market: NA,North America
Production order: N
Paint code 1:
040U - BLACK
Equipment:
201A - LEATHER - BLACK/ANTHRACITE
Engine no.:
156985 60 050016
Old Aug 6, 2017 | 06:04 PM
  #930
Suat k's Avatar
c63 amg
Chassis
Production order: N
Paint code 1:
040U - BLACK
Equipment:
Engine no.:
156985 60 050016
thank you for this informations. I was thinking maybe I could lucky because of the some 2010 63's did not effected(I thought middle of the 2010). So my question is car still running good. Mileage is currently 87k and there is no leaking coolant also water. I care all my cars all maintence etc. Do I have to wait this head bolt issue until happen? It is incredible amg did mistake for head bolt issues but there is no recall etc. your suggestion is important for me. If I change c63 , what year should I buy? Thank you.
Old Aug 6, 2017 | 08:19 PM
  #931
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
No worries, the maybe 2010 not affected is European only because of how they do their model years differently.
Do yourself a favour and get the bolts swapped out now before it's a larger problem down the road.
Old Aug 7, 2017 | 12:08 PM
  #932
hawk02's Avatar
VW .:R32, looking at MB!!!!!!
Engine number 156983 60 003215 2007 E63 AMG
Old Aug 7, 2017 | 05:40 PM
  #933
BLKROKT's Avatar
You need to drain all your oil and coolant immediately, then drive 100miles at high RPM.
It's the only fix for the problem you have.
Old Aug 7, 2017 | 06:07 PM
  #934
hawk02's Avatar
Thanks, in the process of doing this now, I'll report back after the drive with my findings.........
Old Aug 7, 2017 | 06:53 PM
  #935
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Are you asking a question?
Old Aug 8, 2017 | 05:22 AM
  #936
LARSLEMANS's Avatar
2008 C63 AMG
Hi guys !
I am considering to buy a C63 (451 HP) from 2008 that has a motor number in the low end of the affected area (VIN number WDD2040771F128788).
My question is: What is the casualty statistics on the affected motors ? The C63 on sale has 133 t KM on the clock and shows non of the warning signs (low coolant, engine failure, no white smoke etc). It could just be a calculated risk to buy the car if the statistics on engine failures are low.
What is your opinions on this ?
Old Aug 8, 2017 | 05:57 AM
  #937
BLKROKT's Avatar
What is wrong with you people. Seriously.
Old Aug 8, 2017 | 08:09 AM
  #938
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by LARSLEMANS
Hi guys !
Will probably fail at some point. When? Who knows.
It doesn't cost much to swap them out pre failure so buy it, do it, enjoy it...
Old Aug 8, 2017 | 08:48 AM
  #939
LARSLEMANS's Avatar
2008 C63 AMG
Thumbs up
Thanks Jasonoff,
Exactly my own opinion !
The car is bought, and no worries about future problems.
Old Aug 8, 2017 | 09:53 AM
  #940
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Thanks Jasonoff,
So you're having the bolts swapped before failure? Good plan!
Old Aug 9, 2017 | 06:43 AM
  #941
LARSLEMANS's Avatar
2008 C63 AMG
Yes, I receive the car on sunday, and plan to go to my local mechanic and ask him to do the one bolt at a time swap.
However, I talked to an AMG expert yesterday, and he adviced me not to choose the bolt by bolt swap, but instead remove all bolts and the cylinder heads and swap gaskets and bolts this way.
This sounds like a more expensive and much more complicated bolt swap, so I will ask my local mechanic for his opinion on the methods.
Old Aug 9, 2017 | 08:36 AM
  #942
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Did said AMG expert say why?
Old Aug 9, 2017 | 08:53 AM
  #943
Greg Hole's Avatar
2008 C63 AMG
Checked my vin unclear about engine number being in affected range
Can someone check if my engine is in the affected range?
vin:WDDGF77X68F160391
engine no.
156985 60 028395
thank you!
Old Aug 9, 2017 | 08:56 AM
  #944
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
engine no.
156985 60 028395
thank you!
The title of the thread you posted in gives you your answer.
Old Aug 9, 2017 | 09:09 AM
  #945
Greg Hole's Avatar
2008 C63 AMG
I see that but I'm not quite sure if my engine number is affected because my first digits are higher but my second number cluster is lower
Old Aug 9, 2017 | 09:28 AM
  #946
Valvestud's Avatar
Same answer, but since you need more understanding, it's the last 5 digits that are the serial numbers. Yours is way below the 60658 changeover. Please go do some research on the forum prior to asking follow-on questions, cuz they've probably been asked multiple times.
Old Aug 9, 2017 | 03:14 PM
  #947
LARSLEMANS's Avatar
2008 C63 AMG
The AMG expert said that the cylinder heads could be damaged if you made wrong tension by only removing one bolt at the time. I am definitely NOT a mechanic so I cant tell if this is true
Old Aug 9, 2017 | 04:42 PM
  #948
glennhl's Avatar
2011 C63
You loosen just one out of the ten bolts that hold down the head to the block. The other nine bolts are still at full tension. Even if the head was made out of a very brittle ceramic, it wouldn't hurt it.
I'd stay away from this so-called AMG expert!
Old Aug 9, 2017 | 10:35 PM
  #949
c6ixty3's Avatar
c63
VIN: WDDGF77XX8F157820
Talked to a MB dealer and he told me that he's only done 2 headbolt replacements out of the 3 years working at MB and said that it isn't super common.
It's an '08, but he said there's a possibility it won't be affected. Just want to be sure. Has about 87000 miles
Old Aug 9, 2017 | 10:37 PM
  #950
BLKROKT's Avatar
He's wrong. You're 100% affected.
And by the way, seeing 2 HB replacements at one dealer in 3 years is actually a lot.
