C63 AMG (W204) 2008 - 2015
New C63 AMG 507 break noise
Old Mar 2, 2014 | 12:41 PM
507amgdu75's Avatar
C63 AMG 507
Unhappy New C63 AMG 507 break noise
Hi, I just received my c63 507 after a long wait but I have a problem with the brakes. Driving the car, I hear a squealing noise from the breaks when I slowly stop the car, is this normal???? Any known breaks issues with this model? : nix:
Old Mar 2, 2014 | 12:42 PM
avery.whss's Avatar
S550 on order
mine did the same when i bought it..i think it was because the car sat for a few months without being driven..anyways after about a month it went away
Old Mar 2, 2014 | 12:47 PM
507amgdu75's Avatar
C63 AMG 507
did you buy your car new or used???
Old Mar 2, 2014 | 12:49 PM
avery.whss's Avatar
S550 on order
used...it's an 09, it mostly would happen when i would come to a stop, never at higher speeds
Old Mar 2, 2014 | 01:30 PM
planefreak's Avatar
2017 C63S Coupe AMG edition 1
its a known issue, my c63 does that as well
Old Mar 2, 2014 | 03:08 PM
abehoward's Avatar
2009 C63 AMG & 2006 C55 AMG
My 2009 does that too. Went to the AMG shop and they said my pads had more than 50% left
Old Mar 2, 2014 | 03:33 PM
snowmuch's Avatar
C63 AMG
My 08 does it too, going with a different brake pad next time.
Old Mar 2, 2014 | 03:42 PM
momo style's Avatar
C 63 AMG 507 Edition
I have a 507 and it does appear sometimes
Old Mar 2, 2014 | 03:48 PM
zibby43's Avatar
'20 GLC300 SUV
For high-performance brakes (i.e., a big brake "kit"), this is sometimes typical behavior. I've been told that bedding in the brakes upon delivery can help to diminish the risk of the problem occurring.
Old Mar 2, 2014 | 04:24 PM
douwe22's Avatar
my c63 did the same thing had about 50% left on pads, I put ebc brake pads on and have been happy since, no more annoying squealing noise
Old Mar 2, 2014 | 06:24 PM
ab0bab0i's Avatar
mazda rx7
Mine does that also. Braking hard makes the sound go away for a bit, but will eventually come back.
Old Mar 2, 2014 | 08:48 PM
Girard@ACGautomotive's Avatar
a car
It's hard to hear but yes it's typical behavior from brakes that are as large as equipped on the C63.
2 things you can do to help. First being your own bedding of the pads. Second and most importantly would be throwing those OEM pads in the garbage and getting a better compound that will dust significantly less, bite more, and hopefully provide less noise.
Old Mar 3, 2014 | 05:34 AM
edwardsflight33's Avatar
'16 CLS 63 S
Typical for Mercedes. My wife's GLK squeals worse than my 507, but yes both do squeal. I only notice it during gentle breaking at slow speeds for both.
Old Mar 3, 2014 | 06:52 AM
autockr989's Avatar
2015 E63S AMG
I had same issue on my old 08 C300. Car was in and out of shop, they couldn't figure it out at one dearlership, went to another one, they told me it happened from the clips. Anyway, they replaced the clips on the rear brakes, and issue never came back.
Old Mar 3, 2014 | 02:05 PM
cheesy's Avatar
2012 C63 AMG
This provides no useful info to the question , different car , different breaks , not the same issue either
Mine has done it from day one , annoying yes , still does it at times when they're hot and coming to a stop , has 34 k now , I guess drive them harder then they may become quieter
Old Mar 3, 2014 | 03:01 PM
507amgdu75's Avatar
C63 AMG 507
thank you, what kind of brake pads should i get? will my warranty be voided if I change the brakes? I live in france
Old Mar 3, 2014 | 05:55 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
because race car
Old Mar 3, 2014 | 06:29 PM
chrisridebike8's Avatar
'10 C63
Mine squealed the same way. I asked them to check it out and they said it was normal but they would go ahead and replace the rear pads under warranty. 500 miles so far and no noise but that's hardly any mileage.
Old Mar 3, 2014 | 10:39 PM
roadtalontsi's Avatar
10 C six trizzle
totally different issues. all 204's this is C class and GLK of any motor share the same parking brake assemblies. The repair pertains to a clip that the pads ride on.
The other noise that the thread is talking about is pretty normal on big high performance brakes. very light braking at low speeds once warm. As mentioned you can try different pads. Any feed back from aftermarket pad users?
Old Mar 4, 2014 | 04:42 AM
Harold1898's Avatar
2015 E400 Coupe
I never had one iota of squeak
Old Mar 4, 2014 | 12:44 PM
Merc63's Avatar
C63 AMG
Porterfield rs4 pads, no noise or dust and work great.
Old Mar 4, 2014 | 02:16 PM
rage2's Avatar
C63 BS, GLA45
Originally Posted by dchl21
because race car
This. All MB brakes, AMG or not, squeak unless you drive 'em hard. Do a panic stop from freeway speeds in the middle of the night once or twice, and the noise will go away for a while. If you drive aggressive all the time, the brakes will be silent. It's all about driving style.
Old Mar 4, 2014 | 02:22 PM
Mikegpr03's Avatar
C63
+1
Amazing pads and super rotor friendly
Old Mar 4, 2014 | 02:50 PM
Tinbucket's Avatar
C63
Breaks squeal
It may be you washed it or let the brakes get wet. MB says to always drive a bit after washing to prevent rust and possible pads sticking in last position, a bit. Amazing how quick the rust forms.
2 Someone may have replaced the pads with cheaper ones or harder ones.
Wagner brand brake pads, from many years ago had a lot of resin, in them and were hard and squeaked all the time .
3 the pads and brakes may need cleaning. That is the one good thing about pressure washers, at appropriate settings.
I'd pull them and very lightly sand the surface if it persist. Wipe the rotors with brake cleaner.
Check to see if there is grease etc on the rotors especially the back side.
I've only had momentary noise of pad sticking from not drying the brakes after washing.
That don't do it replace with MB pads maybe
Could be if the pads are on since 09, time to replace. Might even be rivets digging in, since I can't see them.
Last edited by Tinbucket; Mar 4, 2014 at 02:51 PM. Reason: left out possible reason
Old Mar 4, 2014 | 03:39 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I assume living in Paris wont help you bedding the pads efficiently. Unless you go to a nice empty stretch and get it done. If you do not plan on tracking your car I think OEM pads are enough but could be dustier than some aftermarket models.
Bon courage et bienvenue dans le cercle AMG
