C63 AMG (W204) 2008 - 2015
Can we jump start these cars?
Old Mar 14, 2014 | 07:22 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
I have left my CLK63 BS out in the country for a while, taken the car cover off and battery flat, can we jump start these guys with jumper leads? Anyone help?
Old Mar 14, 2014 | 07:32 PM
GeorgeSmooth's Avatar
C63
I have jumped my C63 on several occasions with no issues.
Old Mar 14, 2014 | 07:42 PM
Overspooled's Avatar
Slow Vehicle
+1
Old Mar 14, 2014 | 09:39 PM
estrellajon's Avatar
C63 ///AMG P30
Of course. You can even choose either side of the car
Old Mar 14, 2014 | 09:48 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
In an emergency I would say yes go ahead and boost the car, but if you have time remove the negative battery terminal and connect the battery to a charger, if inclined remove the battery from the car and charge it that way just in case of any shorting out of the cables within the trunk or under the engine cover depending on model. When away try a battery maintainer in the .75 amp range, will keep the battery fresh.
Old Mar 14, 2014 | 11:45 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
excuse my ignorance, but is there a reason why we couldn't jump start the battery?
Old Mar 14, 2014 | 11:50 PM
tfthach13's Avatar
'09 C63
Because sometimes if the surge of voltage is too high it will short out the electronics. Seeing how our cars depends on a lot of electronics it may not be a good idea. However, it worked fine for some people.
Always use a battery maintainer if possible when storing your car for a prolonged period of time.
Old Mar 14, 2014 | 11:56 PM
Critter's Avatar
You beat me too the answer tfthach13, some will just hook up to a dead battery with a vehicle that is running which besides the surge could be enough spark to ignite gases around the battery, or the driver could hook up the cables incorrectly and short out the battery, cause an explosion and be blind for the rest of their lives. So not being too dramatic if you have to ask do not jump any car unless you are confident doing so. A dead battery is a giant resistor, remove from the car and charge it using a proper charger, again in an emergency be very cautious.
Old Mar 15, 2014 | 12:06 AM
Jump started, all good, everything works fine, thanks or the advice fellas
Old Mar 15, 2014 | 06:16 PM
Skyline 123's Avatar
E320 4matic
Jump start it with the other car switched off the voltage will not jump that way
Old Mar 15, 2014 | 08:08 PM
shades's Avatar
09 C63, 11 Cayenne S
Just jump start where it's supposed to be and you'll be fine. Two terminals made for this in the engine bay. The positive has a red cover and the negative is close two the coolant reservoir
Old Mar 15, 2014 | 10:19 PM
C63 ///AMG P30
+1. Unsafe batteries were back in mid 80's and older
Old Mar 17, 2014 | 02:17 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Soo much misinformation...
Yes, you can jump the car, no it will not destroy the electronics. Between the battery and pretty much everything, are voltage regulators. This will prevent surge scenarios from doing any damage.
At most, you can damage your battery by connecting the terminals directly to another battery. When jumping, positive to postive, negative (source) to grounded chunk of metal (destination).
In older cars, using a smaller battery was problem, insufficient current to crank the starter and poor voltage regulation caused problems. In our cars, the car just won't crank. I had that problem when the airport sent a V6 pickup (even though I specified a V8). Took about 20 minutes before my battery was charged enough to turn over.
Old Jun 26, 2024 | 01:31 AM
Thomasbiju's Avatar
Ml63 amg 2007
Ml63 amg 2007
I made the mistake of letting my battery die completely whilst being stored.The tow truck company used a heavy duty battery booster to try jumpstart it which failed but caused damage.I replaced the battery and the vehicle starts fine but will not engage into any gear just locked in park.Initially my radar detector and garage door openers on the rear view mirror and light did not work.I swapped the two yellow relays in the engine right side fuse box and the radar detector started to work but the transmission still seemed to engage but not actually allow to drive followed by an error.
In the process orpf replacing yellow relay as next step as one seems to have a burn mark on the top and swapping made the radar detector work.called the dealer said either transfer case or computer related.
any comments to try
Old Jun 26, 2024 | 02:31 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
The sequence when jump starting should be performed from the mindset of keeping the circuit “cold” for as long as possible.
With this in mind, start by making ABSOLUTELY sure which battery posts are positive and which are negative.
You could easily not follow color convention with the jumper cables, and not get in trouble if you are careful, and paying attention, but in an ideal world, use the red jumper wire to connect positive to positive, and the black jumper wire negative to ground.
Connect dead positive to good battery positive. The circuit is half hot now, in a manner of speaking.
Connect good battery negative to dead ground. Only as an absolute last resort should the dead battery negative post be used as a ground. When you make the last connection, line it up first, then turn your eyes away from the battery as you connect.
During the whole process, keep the leads separate from touching each other, or the ground.
Old Jun 27, 2024 | 12:21 AM
roadtalontsi's Avatar
10 C six trizzle
any comments to try
Your ML63 doesn't even have a 2 speed transfercase (hi and low) only 1 speed, any electronics or even a center diff lock. It's purely mechanical. As usual the person you spoke to at the dealership doesn't know anything just a typical technician secretary that spouts off lies. "computer related" is the most generic answer ever. Atleast I can promise you it's electrical related, and not a transfercase, differential or brake caliper though lol. In all seriousness probably popped a prefuse or something along those lines. You need someone that knows these cars to fix it. If you're competent enough to change your own battery look at the fuses to the left side of the battery tray (under the passenger seat) those are the big ones that usually go when jumping off or low voltage issues. If you're lucky that's all it is.
Pulling out and swapping random relays is just wasting time as you dont even know what they are for. Benz's very seldom have relay issues. It's normal to have some burn marks after thousands of cycles. They usually only get replaced when the component they control has a problem - like a secondary air injection pump or an airmatic pump.
