Is this the dreaded cam tick?
My C63 has 89,000kms on it. At about 50,000kms the lifters were done, I started it up this morning and it sounded like this (video taken about 30 seconds - 1 minute after cold start), is this normal or the cam adjusters? It seemed particularly loud today. No CEL or codes.
Thanks!
Some of these M156 engines are just noisier than others. Doesn't automatically mean there is a problem.
More Info: https://mbworld.org/forums/c63-amg-w...ing-noise.html
Does your engine quiet down once fully at temperature?
https://www.youtube.com/shorts/YnYG3pRP47U
Thanks!
Mine had that noise as it got older. I recently changed the plugs, coils and injectors and I no longer have that tick.
80k kms
The question here is not whether the engine is cold or warm, but rather how long it has been sitting before you fired it up. *ALL* C63s will make some lifter noise if you let them sit for a while (several days on the ones withe the early-style lifters to a couple of weeks on the ones with the newer "SLS" lifters) as any residual oil drains and it then takes a few minutes for the lifters to fully pressurize. Seeing as you have no lifter noise in the second video, I wouldn't worry about it as it is not happening during normal engine operation.
Let me know if yours is still making this louder than normal tick.
