C63 AMG (W204) 2008 - 2015
Mirrors: Pre-Facelift to Facelift - Where T Buy?
Old May 16, 2014 | 10:44 PM
Autosport7's Avatar
C63 AMG
Who sells this modification in carbon fiber?
This can't do it right?
http://m.ebay.com/itm/271320599599?nav=SEARCH
Old May 16, 2014 | 10:53 PM
Sidv22's Avatar
Audi A5 6MT, C63 AMG
I have these. well, atleast looks the same in pics. quality is not astounding but just about ok. i can send couple of pictures if you would like.
Old May 16, 2014 | 11:00 PM
estrellajon's Avatar
C63 ///AMG P30
These are just the cover and not the whole unit
Old May 16, 2014 | 11:04 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Do you want just pre-FL CF cover with the FL look (like the ones on ebay) or do you want actual FL mirrors + covers?
Contact Matt (olszowa12) for the FL mirrors.
Old May 16, 2014 | 11:34 PM
Autosport7's Avatar
C63 AMG
I don't know what I'm doing with regards to mirrors. Lol
I want facelifted look in cf, that's all I know. Can I do that by just swapping the cases or do I need a new mirror?
Will the ones from cf complete my goal?
Initial poster if u wouldn't mind posting some pics in here I would appreciate it.
Old May 16, 2014 | 11:56 PM
abcut973's Avatar
Well CF covers for your OEM mirrors will be the more economic solution.
Pre-FL mirrors (bigger) are totally different from FL mirrors. Therefore you cannot swap covers and actual mirrors.
If you want to retrofit the FL mirrors you will need new units. IMO an improved look as well as airflow. Pre-FL are known to be nosier at high speed.
Old May 17, 2014 | 12:40 AM
Autosport7's Avatar
C63 AMG
Those things on eBay, are those what you're calling covers? Will they fit my current housing?
Old May 17, 2014 | 12:43 AM
CarHopper's Avatar
E63S | X5
The ebay mirrors wont work for you.
As mentioned, just send Matt (olszowa12) a PM asking about mirrors. He knows everything and can sell you some I believe. If anything, he can get you the facelift mirrors and then you can just have those wrapped in CF if you want that look.
True CF facelift mirrors are seriously expensive.
Old May 17, 2014 | 12:46 AM
Autosport7's Avatar
C63 AMG
Ok thanks guys.
Old May 17, 2014 | 08:46 AM
black lavender's Avatar
R8, C63, C300
That's actually false.
See thread
https://mbworld.org/forums/c-class-w...ers-139-a.html
They look like FL mirrors, and fit on your 08-09 C63. They are a little larger than OEM FL, but look like them.
Old May 17, 2014 | 03:21 PM
Sidv22's Avatar
^^+1. here are couple of pics
Mirrors: Pre-Facelift to Facelift - Where T Buy?-photo15_zps9189c37b.jpg
Mirrors: Pre-Facelift to Facelift - Where T Buy?-photo32_zps4eef871a.jpg
Old May 17, 2014 | 03:58 PM
Autosport7's Avatar
C63 AMG
Wohhh wait what!!!!? Those eBay ones are this????
Old May 17, 2014 | 10:05 PM
Sidv22's Avatar
It appears so. but different seller.
Old May 17, 2014 | 10:43 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
sidv22: look pretty good! i have a few questions for you:
(1) how long have you had them?
(2) how hard was the install?
(3) how come they are lit up? are they connected to the parking lights?
thanks.
Old May 17, 2014 | 11:17 PM
Sidv22's Avatar
thanks.
i have had them for a year and half now. they are holding up pretty well so far. the installation is straightforward but the fit is not ideal so it can be bit of a struggle to get them to fit. they are connected to the parking lights thats the reason they are lit up. once you manage to install, then no problem.
Old May 17, 2014 | 11:29 PM
Ingenieur's Avatar
C63 AMG
I had my mirror covers off today to clean them up and lube the adjustment mechanism
Pretty easy
Remove mirror glass
Point mirror down
Put both hands fingers at the top to pull
Thumbs pushing at bottom
Pop it off, takes some force
Remove wires
Driver side 2 wires and 1 plug
Passenger wires only
Put a bit of wd40 on the connections and use needle nose
Locate 3 small torx
Remove and dont lose
Pop off black trim piece
The painted part can then be removed
Youll see some clips to release
It lifts up
Youll see a slip on electrical connector
You can remove the lense
2 small torx
Release clips and pop out
Install is reverse
Make sure connector is seated
Everything 'clicks' in place
Dont over tighten screws, just seat them & lightly snug
Old May 18, 2014 | 12:56 AM
did you have to connect them to the parking lights? just asking bc i'd prefer mine to be like the stock ones, with them lighting up with the turn signal only. and when you say the fit isn't ideal, do they fit properly once you are done struggling to get them to fit, or are there gaps, etc?
Old May 18, 2014 | 12:58 AM
Originally Posted by Ingenieur
I had my mirror covers off today to clean them up and lube the adjustment mechanism Pretty easy Remove mirror glass Point mirror down Put both hands fingers at the top to pull Thumbs pushing at bottom Pop it off, takes some force Remove wires Driver side 2 wires and 1 plug Passenger wires only Put a bit of wd40 on the connections and use needle nose Locate 3 small torx Remove and dont lose Pop off black trim piece The painted part can then be removed Youll see some clips to release It lifts up Youll see a slip on electrical connector You can remove the lense 2 small torx Release clips and pop out Install is reverse Make sure connector is seated Everything 'clicks' in place Dont over tighten screws, just seat them & lightly snug
thanks for the write up!
Old May 18, 2014 | 01:07 AM
Sidv22's Avatar
its only a cover so you still are going to connect to OEM connectors. its a direct connection, just like stock. once you get it installed, the fitment is almost as good as OEM. no gaps. once done, they def look better than stock. better than the ones on 2008/9.
Old May 18, 2014 | 01:37 AM
I see. interesting that they wired it up to light up with the parking lights. afaik, the oem FL don't do that. thanks for sharing the info, I appreciate it!
Old May 18, 2014 | 10:57 AM
Autosport7's Avatar
C63 AMG
Lots if great info here!
Old Jul 24, 2022 | 01:09 PM
crayzee88's Avatar
W204 c220 cdi
Iv been looking all over for these...
I dont want to replace the whole wing mirror itself because i do like the size of the pre-FL oem mirrors. If i could get a hold of black or carbon fibre FL-looking covers, then that would be great...
Iv looked all over ebay, alibaba, etc and cant seem to find them. Would someone be able to point me in the right direction? It seems as though this wing mirror cover has the same look as the facelift one, but is designed to be fitted over the old pre-facelift wing mirrors. https://youtu.be/RK_iOZM9wu4
Old Aug 14, 2022 | 03:19 AM
James115's Avatar
C63 Amg
i am having the same problem, have you found the covers?
Old Aug 14, 2022 | 10:06 AM
crayzee88's Avatar
W204 c220 cdi
I didnt have much luck... so I ended up upgrading the indicators instead. These smoked sequential LED indicators look pretty cool too imo
Old Aug 14, 2022 | 11:16 AM
James115's Avatar
C63 Amg
55 tech they have it
