C63 AMG (W204) 2008 - 2015
Spoiler Removal
Old Jun 17, 2014 | 10:12 AM
RAKLAW's Avatar
2012 C63BS 2009 Ferrari 16M 2016 Cayenne turbo S 2019 G63
Spoiler Removal
Has anyone removed the OEM trunk spoiler that came on your car to replace it with a different one. What process did you use to take it off if you DIY
Old Jun 17, 2014 | 10:49 AM
alpharabbit's Avatar
C63 507
I used fishing line, wedge it under one side of the spoiler and move it back and forth in a sawing motion and it will cut through the foam tape without scratching your car or the spoiler. I then used a 3m tape residue removal wheel on a drill and cleaned up what was left over. After that little bit of rubbing alcohol cleaned up the surface.
Old Jun 17, 2014 | 11:14 AM
rickclass's Avatar
2014 C63 AMG 507 Edition
Dental floss also works....same technique as above...
Old Jun 17, 2014 | 11:45 AM
RAKLAW's Avatar
thanks guys
Old Jun 18, 2014 | 08:20 PM
AMG Boost's Avatar
2010 C63 P30
I did my spoiler last month and used a 10lb fishing line. Worked good but snapped the line multiple times. I recommend something stronger than 10lb. Also make sure you get a stripe off wheel to remove the excess glue. All in all its a easy DIY
Old Jun 19, 2014 | 12:56 AM
Spine55's Avatar
SL55, CLK55, C63BS
Correct ! A heavier gauge fishing line and then some clean up and your ready to install that new Mode spoiler!! Good luck!!
Old Jun 19, 2014 | 01:14 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
and heat gun...
Old Jun 19, 2014 | 04:12 AM
AMGPower88's Avatar
C63 AMG
Doesnt fishing line scratch the paint on the car??? Sounds very risky..
Old Jun 19, 2014 | 08:11 AM
Rib Feast's Avatar
Fishing line worked for me. It snapped and I resorted to dental floss. Use a hairdryer to soften things up under the spoiler first and it'll probably be easier (sadly I heard that tip after I spent a couple of hours doing it cold).
Old Jun 19, 2014 | 10:44 AM
bbb_fatboy's Avatar
2014 C63 507
Does anyone have photos of how much glue residue is generally left behind? Just curious, I have never done this before.
And as everyone knows, without pics it never happened anyway...
Old Jun 19, 2014 | 10:59 AM
RAKLAW's Avatar
i hope to have mine professionally installed Saturday.
I'll take pics
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Heat gun + fishing line works great to remove the spoiler. Depending how old is your car you could be left with some tape residue. Use any adhesive remover to get rid of them. I have no pictures for this unfortunately but this is a simple DIY procedure.
That might help https://mbworld.org/forums/c63-amg-w...m-spoiler.html
Old Jun 19, 2014 | 07:43 PM
Mort's Avatar
I took mine off with fishing line as well. It did break many times but only took about 15 minutes to get the spoiler off. It would have been faster if the line didn't keep breaking. Getting the old tape and glue off was another story. I used 3M vinyl adhesive remover and it worked but I had to go over it a lot of times to get it to get down to the paint. Probably took > 2 hours of spraying, letting it set and rubbing. Used a whole spray can @ $32. The fishing line did leave some small marks on the bend line on the trunk under the spoiler. Might be a problem if you are not putting another spoiler on.
Old Jun 23, 2014 | 08:34 AM
RAKLAW's Avatar
I had my Mode Carbon Spoiler installed professionally over the week-end on my 2012 C63 BS.
The fit was perfect and the overall quality of the boot lid spoiler is top notch. The Carbon design even matches the direction and pattern of the OEM carbon diffuser. The installer refused to use fish line or the like, as he position is it can and often damages the paint. He only uses a heat gun and then a wheel to remove the excess adhesive. On the BS the OEM carbon spoiler was held down with two layers of 3M tape..One on the spoiler and one on the trunk. An hour job in total.. The new spoiler really looks kool. pics to follow.
Attached Thumbnails Spoiler Removal-photo.jpg   Spoiler Removal-bs-spoiler.jpg
Old Jun 23, 2014 | 02:26 PM
ddcha's Avatar
2022 E53 SG
that's purdy.
Old Jun 23, 2014 | 02:40 PM
Mode Carbon's Avatar
SPONSOR
E90 M3, F80 M3, C63 507, F90 M5
Thanks for the photos and kind words, Richard! Looking good
Old Jun 23, 2014 | 03:39 PM
vtune's Avatar
E92 335i / C63 AMG / GSX-R 600
there will be a lot of glue / residue after you remove the spoiler. i have some pics from when i removed mine. It took about 4 hours to remove completely. I used fishing line, heat gun, goo gone, and some other cleaners. there is a drill bit tool made by 3m designed for removing residue 3m tape quickly, but it is about $80.
Old Jun 23, 2014 | 03:50 PM
Autosport7's Avatar
C63 AMG
$37.99 + shipping here:
http://www.autopia-carcare.com/3m-st...YXIs3uBVPD_BwE
Old Jun 23, 2014 | 07:10 PM
Ingenieur's Avatar
C63 AMG
I've removed tape items as follows
Heat it up at one end
Use a plastic wedge/shim to get it started
Then work the shim down the piece heating as you go
Once you get enough lifted up to grasp, just lift and heat as you go
Pops right off
Leaves very little residue
Old Jun 23, 2014 | 08:17 PM
AMG Boost's Avatar
2010 C63 P30
Originally Posted by Autosport7
If you guys want to do the job efficiently you need this wheel. I got one from a local body shop for about $25.
You dont need a heat gun either. The fishing line cuts right through the adhesive no problem.
There is no reason this should be a 4 hour job unless you are super meticulous. I had mine installed in 2 hours and I took my time.
Old Jun 23, 2014 | 08:30 PM
Ingenieur's Avatar
C63 AMG
3M website
Q: How can I get the part off after it has been applied?
A. In general, this is difficult to do unless it is removed immediately after application. The part can be gently heated to soften the adhesive and peeled, or the foam tape can be split at one end and the part carefully peeled off. Tape and adhesive residue can most easily be removed with a 3M™ Stripe-Off Wheel without the use of solvents. 3M™ Prep Solvent-70 and 3M™ General Purpose Adhesive Cleaner can also be used to soften the adhesive residue, which can then be scraped off with a plastic squeegee.
Saw a guy at a body shop remove a spoiler
Heated it, got it started with a wedge
He lifted it up as he heated the point where tape/spoiler/body met
The heat and the tension in the spoiler peeled it right off
Less than 5 minutes and hardly any residue
