C63 AMG (W204) 2008 - 2015
Time for new rotors/pads
Old Oct 13, 2014 | 10:01 AM
itzjonjon69's Avatar
12 C63 Coupe
Alright guys so it's time to replace my rotors and pads and had a couple of brake setups i was contemplating. My C63 is a daily driver which gets some spirited driving () At this point i'm debating if should upgrade to 2 piece rotors front and rear or just stick with the fronts. Would upgrading to 2 piece even be worth it for me?
OEM 1 piece rotors, pads (front and rear): $939.00
OEM (P30) 2 piece rotors (front only), pad (front and rear): $2163.00
RB Brakes 2 piece front rotors, pads + oem 1 piece rear rotors, pads: $1943.00
Old Oct 13, 2014 | 11:00 AM
chrisridebike8's Avatar
'10 C63
I'd say either keep them 1 piece stock with something like the Porterfield pads or if your really want to go 2 piece, go with something aftermarket. Vendors on here will help you out. I have no experience with any of the 2 piece rotors so I won't send you any particular direction. But aftermarket will be lighter, probably cheaper, and offer more options. And IIRC, the P30/31 2 piece rotors can't simply replace the braking surface but aftermarket units often can (ie-you keep the aluminum hat)
Old Oct 13, 2014 | 11:48 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Originally Posted by itzjonjon69
Alright guys so it's time to replace my rotors and pads and had a couple of brake setups i was contemplating. My C63 is a daily driver which gets some spirited driving () At this point i'm debating if should upgrade to 2 piece rotors front and rear or just stick with the fronts. Would upgrading to 2 piece even be worth it for me? OEM 1 piece rotors, pads (front and rear): $939.00 OEM (P30) 2 piece rotors, pad (front and rear): $2163.00 RB Brakes 2 piece front rotors, pads + oem 1 piece rear rotors, pads: $1943.00
I didn't know there were OEM rear two piece rotors.
Old Oct 13, 2014 | 11:51 AM
12 C63 Coupe
oops sorry i meant front and rear pads! OEM 2 piece is only available in the front
Old Oct 13, 2014 | 11:55 AM
Ingenieur's Avatar
C63 AMG
The $939 is a good price
Where did you find it?
I'd stick with the 1 piece unless you track the car
Old Oct 13, 2014 | 11:56 AM
12 C63 Coupe
www.oediscountparts.com free shipping too! i ordered my ROW airbox covers from them.
Old Oct 13, 2014 | 11:59 AM
Ingenieur's Avatar
C63 AMG
Book marked for future reference lol
Old Oct 13, 2014 | 12:04 PM
The $939 is a good price Where did you find it? I'd stick with the 1 piece unless you track the car
+1. unless you're into the coolness factor, one piece is fine for the street. heck, I am even considering using one piece oem's to replace my p30 rotors when the time comes.
Old Oct 13, 2014 | 12:08 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yeah if you do not plan to track the car OEM 1 pc are just fine for daily driving and some spirited moments.
Old Oct 13, 2014 | 12:13 PM
Ingenieur's Avatar
C63 AMG
A $1200 difference for marginal track advantage and no street advantage
For the difference if you replace the 2 piece every 80k miles you do the 1 piece every 40k and still be way ahead
Before I get the 'cheap *******' BS I can afford it but don't squander my hard earned cash
Old Oct 13, 2014 | 12:40 PM
A $1200 difference for marginal track advantage and no street advantage For the difference if you replace the 2 piece every 80k miles you do the 1 piece every 40k and still be way ahead Before I get the 'cheap *******' BS I can afford it but don't squander my hard earned cash
cheap *******! jk. I'm on the same page as you.
Old Oct 13, 2014 | 12:41 PM
12 C63 Coupe
Alrigh guys so i think i'm gonna stick with the OEM 1 piece rotors. Now what brake pads do you guys recommend?
Also... I was on ECS tuning and i noticed they said that rotor screws aren't included. Do these need to be replaced or something or can i reuse the ones i have now?
Old Oct 13, 2014 | 12:44 PM
Ingenieur's Avatar
C63 AMG
I prefer 'frugal *******'
Heck $1200 is a set of good tires
Old Oct 13, 2014 | 12:47 PM
Ingenieur's Avatar
C63 AMG
I'd stick with oem
A bit dusty but easy on the rotors and good cold bite
They are smooth in application and transition nicely
Get the srews you 'cheap *******' jk lol
You will probably bung them up getting them out
Use a bit of anti-sieze on the new ones
Old Oct 13, 2014 | 01:03 PM
12 C63 Coupe
I'd stick with oem
lol damn... anyone know how many bolts i need?
Old Oct 13, 2014 | 01:06 PM
abcut973's Avatar
One on each corner.
As for brake pads OEM are fine but endless ME20 pads are not too bad and less dusty.
Old Oct 13, 2014 | 01:07 PM
12 C63 Coupe
Originally Posted by abcut973
One on each corner.
I'm looking at a picture and it looks like each rotor requires 5 screws, so 20 screws in total? i was thinking of going with the Porterfield R4S pads...
Old Oct 13, 2014 | 01:09 PM
abcut973's Avatar
I'm looking at a picture and it looks like each rotor requires 4 screws, so 16 screws in total? i was thinking of going with the Porterfield R4S pads...
Which screws are you talking about? I only see one?
Porterfields are a good choice as well.
Last edited by abcut973; Oct 13, 2014 at 01:12 PM. Reason: didn't read the full thread
Old Oct 13, 2014 | 01:14 PM
abcut973's Avatar
The 5 holes you see are for your lug bolts.
12 C63 Coupe
oooh ok! i thought those 5 holes were for the rotor screw!
Old Oct 13, 2014 | 01:16 PM
12 C63 Coupe
What do you guys think about Centric rotors? Don't they make all the stuff or stoptech?
Old Oct 13, 2014 | 01:45 PM
no opinion on centric, but I was told brembo made the p30 rotors.
Old Oct 13, 2014 | 01:46 PM
and you can probably reuse the set screws.
Old Oct 13, 2014 | 01:58 PM
Ingenieur's Avatar
C63 AMG
I never had much luck with them
Much swearing and cursing involved when they strip
If you do
Let sit with some penetrating oil squirted on them
Insert key and tap lightly to break loose
Then make sure the tool is seated fully and apply gradual pressure
Then throw a fit when it strips lol
E-Z out tools should be on hand
Or drill the head off and remove the shank with vice-grips
Either way you'll still need a screw
Old Oct 13, 2014 | 08:06 PM
ToXicXxX's Avatar
2011 C63 AMG P31
You can, as it has no set tension on it because the lug bolts carry all of it. They should be buttery loose when you go to remove them.
I do brakes on BMW's all the time (exact same single set screw) and it comes out with a tiny bit of force on a 3/8th wrench. Actually did the brakes and discs on a Range Rover sport (exact same brakes and very similar rotors), and it was also easy.
But throw some copper anti-seize on them when they go back in.
The head might be a bit corroded, so when you insert the hex bit, give it a smack with the ratchet to make sure it's seated.
