C63 AMG (W204) 2008 - 2015
Ditching Mobil 1 - NA (Has anyone done any research on the other approved brands?)
Old Oct 5, 2016 | 04:51 PM
  #151
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
Originally Posted by AMG3.2
What is this all about?
LiquiMoly MoS2 is an additive that helps protect your engine. I don't have a computer with me to post links at the moment but look on mbworld and on bobistheoilguy and read the arguments. I personally swear by this stuff and everybody I know that uses it does as well. Even in non performance engines, you'll idle smoother, have more power, and effectively have more protection for your engine. I tried with Mobil 1 in the past and it helped, but combined with Motul it was like butter butter butter.
If you want to jump on I'd recommend d running LiquiMoly Ceratec first, then upon your next oil change start cycling in LiquiMoly MoS2 as recommended by LiquiMoly. I drive my car hard and after 1.5 weeks of driving Mobil seemed to lose that fresh oil change feeling. Motul with LiquiMoly felt as strong as it did day of oil change.
Old Oct 5, 2016 | 05:08 PM
  #152
shaun.barnard's Avatar
2012 C63 AMG Coupe
Originally Posted by Jasonoff
I may have missed it, but if you actually ran a 30 weight that was done by a MB dealer, that's on record for that matter. I would request a free extension on warranty because your motor has likely been compromised by premature wear.
The oil make and type is on the B service receipt.
Old Oct 5, 2016 | 06:09 PM
  #153
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Ouch, that's not good. How long have you been running it?
I would get after them asap! I would also recommend having the oil tested as well.
Old Oct 5, 2016 | 06:53 PM
  #154
2012 C63 AMG Coupe
Not long luckily, I seldom drive the car, did about 3000km since 10 months of ownership and oil has been changed twice.since last service about 50km
Old Oct 5, 2016 | 06:56 PM
  #155
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
I agree. Who uses a 10W30 or anything that is a 30 these days.
Old Oct 6, 2016 | 08:39 AM
  #156
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I would still have the oil tested and get something out of the dealership. That's a major mistake.
Old Oct 6, 2016 | 11:58 PM
  #157
bhamg's Avatar
C63 AMG
Originally Posted by hachiroku
just run Motul 8100 with LiquiMoly MoS2 and call it a day.
Courtesy of BITOG, this is one of the more amazing UOA's I've seen. Motul 8100 X-cess 5W-40 (I've used it for 23,700 miles in the C63 with two outstanding UOA's) in an A3. The oil use interval was 20,509 miles. The wear metal readings are freakishly low. Virtually NO shear, hot viscosity at 13.0. TBN still very high at 4.0. You can't go wrong with this oil.
Attached Thumbnails Ditching Mobil 1 - NA (Has anyone done any research on the other approved brands?)-german-autohaus-chattanooga-2006-audi-a3-motul-8100-x-cess-5w40-oil-analysis_zps2ezisgzc.jpg
Old Oct 7, 2016 | 03:16 AM
  #158
Tlnt60's Avatar
2012 C63 AMG Coupe
Subbed
Old Oct 7, 2016 | 08:58 AM
  #159
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
The big quesiton is why did you drive your car 24k miles without changing the oil - it seems to test ok still, but not a fan of running that close to the limit myself!
Big fan of Motul 8100 x-cess myself, run it in my 335i and C63.
Old Oct 7, 2016 | 09:06 AM
  #160
bhamg's Avatar
C63 AMG
Bad wording on my part. 24k covered three Motul changes, the first and last were tested. In general I go about 8k between changes.
Old Oct 7, 2016 | 09:31 AM
  #161
Top Answer: 1
Ah, that makes more sense!
Old Oct 10, 2016 | 12:47 AM
  #162
hachiroku's Avatar
SPONSOR
now add LiquiMoly MoS2 and report back while holding back your smiles.
Old Oct 10, 2016 | 11:37 AM
  #163
Top Answer: 1
This line in the manual makes me not want to do that until my warranty is over.
"Do not blend oil additives with engine oil. They may damage the engine. Damage or malfunctions resulting from blending oil additives are not covered by the Mercedes-Benz Limited Warranty."
Old Oct 10, 2016 | 11:54 AM
  #164
AMG3.2's Avatar
C63 AMG, P30
Nice. Thanks for the info.
Old Oct 10, 2016 | 01:15 PM
  #165
bhamg's Avatar
C63 AMG
Old Oct 10, 2016 | 01:19 PM
  #166
bhamg's Avatar
C63 AMG
https://bobistheoilguy.com/moly-basics/
Old Oct 10, 2016 | 02:12 PM
  #167
hachiroku's Avatar
SPONSOR
If you're at less than 4 years and 50k miles, sure...but once you've elapsed that warranty, time live life on the edge and make more power while having more protection.
Old Oct 10, 2016 | 02:38 PM
  #168
raphman's Avatar
'16 C63s
L-M states one bottle is good for 1.5 gallons of oil (or, 6 quarts). Has one bottle been sufficient in your experience or are you measuring out the precise amount necessary for 9 quarts of oil?
Old Oct 10, 2016 | 02:51 PM
  #169
bhamg's Avatar
C63 AMG
I'll answer that. My last UOA showed 138 ppm of moly with a half-bottle maintenance dose of MOS2 added with new oil. That's too low for me - I was expecting over 200 ppm which is the min level I am looking for. So, the easiest is to add a full bottle at every oil change.
Old Oct 10, 2016 | 02:52 PM
  #170
hachiroku's Avatar
SPONSOR
I agree...I add a whole bottle upon every oil change.
Old Oct 10, 2016 | 02:57 PM
  #171
raphman's Avatar
'16 C63s
Ok, so just to clarify, one bottle os MoS2 is sufficient for the 9 quarts we use, and NOT a bottle and a half (which would be the "correct amount", according to L-M).
Old Oct 10, 2016 | 02:58 PM
  #172
bhamg's Avatar
C63 AMG
I've never mentioned this before to anyone but's absolutely true. And particularly true when (I) (you) have been using MOS2 over multiple changes. Idle is very noticeably "creamy-smooth."
Old Oct 10, 2016 | 03:01 PM
  #173
bhamg's Avatar
C63 AMG
The initial dose should be the "strongest." I added the recommended amount of 1.5 btls.
Old Oct 10, 2016 | 03:21 PM
  #174
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I dosed with CeraTec, ran that through for a couple thousand miles, and have been follow-up dosing with one bottle of MOS2 at subsequent oil changes for about a year now. Idle is much smoother and lifters are quieter too. I'm usually pretty skeptical of additives, but after thoroughly researching on BITOG (where the positive experiences and UOA results are in the clear majority), and now seeing a difference on my car, I'm a believer.
Old Oct 10, 2016 | 03:38 PM
  #175
AMG3.2's Avatar
C63 AMG, P30
I picked up a bottle of MoS2 over the weekend and too noticed that we'd need 1.5 bottles to meet their recommended dosage.
That being said, for those starting out on this, the recommendation is to:
1) Run Ceratec through during your initial oil change (5k miles)
2) Upon future oil changes, add 1.5 bottles of MoS2.
Correct?
