Racing Brake Rotors after 113,556miles
Those rotors used 1.75 OEM brake pads.
They wore from 1.4inches new, to 1.3inches on the inside edge and 1.25inches on the outside edge.
If you want details on torques I used, look at the original install here. (The guys at RB posted their info at the bottom of page 3 of that thread)
Sadly, I never tracked these. However, my replacement includes XT910 brake pads from RB, so I gotta get on my home track Laguna Seca.
Another note. The replacement disks essentially cost a little more than half the original install. Not quoting exact number because that would mess with RB marketing.
Here we go.
So the first two attachment photos are of the rotor on the car, the kit of gear, and a fuzzy edge shot of the wear on the rotor.
Got to get an inch pound torque wrench to torque the 10 bolts.
Next, clean the aluminum hat. Oven cleaner!!!! Worked great with a paint brush to remove all the old brake dust and other crap accumulating on the hat. Used the same on the calipers!
Then, re-assemble. As I said, look at the link I put in the first post for torques I used on the caliper bolts. 85ft-lb pretty sure with blue lock tight.
The pads did not include the damper weights that MB added to reduce brake squeal. I have only a little. One pad was VERY tight (outside left), but did not ultimately pose a problem after following the break in instructions. No room for any shims, thus any brake grease was omitted.
I have Ti brake shims, and if I go to the track, I might add them. They keep the heat in the pad and act as an insulator to the caliper.
This all was very straight forward. Other than the tight pad, no hickups.
Hope you all enjoy...
Jon - the highest mileage original owner M156 on the forum
RacingBrake is also a proud supporter to C63 track enthusiasts in inspiring their confidence on tracks.
https://mbworld.org/forums/c63-amg-w...their-car.html
All our brakes are made from the finest material (per SAE, ASTM, FMSI and other applicable standards), with better designs resulting precise fitment that can provide you with years of durable performance and lasting beauty behind your loved wheels.
Thank you.
Warren-RB
I used it on my stock wheels after removing them. It looked like the barrels had never been cleaned and the Iron X made them look almost brand new.
The stuff isn't cheap and it smells horrible (need to use it outside), but it works damn well.
The attached pic shows it working on the roof of my Durango.
Can you share with us and update the overall performance of this set up - RacingBrake two piece rotors with XT910 brake pad combo.
http://www.racingbrake.com/Mercedes-.../mb-irk-07.htm
Thank you.
Thank you.
At 216.6K I can tell you the brake dust is less than stock but not as low as some focusing on that. Pretty much matches the rears now. No noticeable fade on spirited mountain driving. Very good brake feel. I wish I could report how it does on the track, but I will update,
Oh yes, no squeal and no problems in the cold. Where 25F is about as cold as they would get.
Best part is I kept my floating rotors for a fraction of the price now that I only change the iron disk!
2. No squeak.
3. Lower replacement cost over the time (just replace the rings) than OE or 1pc.
Thanks to your true legendary testimonial which sets the new standard on Mercedes brake (OE or aftermarket).
Jon, this is simply an amazing write up and product follow up. Just simply wow. i believe you are definitely the highest mileage M156 in this forum, or even in general at that for all M156 owners, AND at original head bolts wow. My '09 SL63 with P030 just had a complete internal refresh a few weeks ago with new updated head bolts and requested SLS lifters among other preventative maintenance, all done at the dealer; and I'm at 65k mileage lol
Originally came across your original thread looking for the caliper bolt torque specs and simply cross refernecing between chassis with similar / same front brake set up, and what a lot of 101 i have read just by your DIY / write up / brakes follow up
I applaud you brother!
What a legendary review with a historical record of rotor longevity for Mercedes.
When you got a chance would you give members an update of your brake condition after 4 years of disc replacement.
Thank you.
> Lastly, use the in a classic star pattern to tighten all to 108-120 inch pounds. I used 114 in-lb.
Separate thanks to @Jon2007E63P30 View Post , your posts are the reason I'm installing RB rotors
https://racingbrake.com/rb-2-pc-rotor-hardware/]RB Two piece rotor hardware
RB exclusive design of mechanical "self- locking" hardware (M6)
New hardware (Left) After torqued to 110 in-lbs (Right)
Shinning threads exhibit the nut effectively bite into the thread permanently so you don't have to worry about what grade of Loctite to use, and how long it's going to hold.
Final rotor assembly (Plaid front stock replacement 380x32mm)
RB self-locking design w/o using Loctite like most of others, so it can ensure the assembly retains consistent torque during the life of the rotor at any braking temperature.
Illustration of disc movement (sliding) during heat expansion & contraction:
RB rotors assembly uses less piece of hardware (2 ea) than the traditional surface mount assembly with multiple pieces (3+), resulting a 2D "Sliding" movement during heat cycles vs. traditional 3D "Floating" design, with the advantage of more effective brake torque transmittal (no slippage) and "No" noise as opposed to the common knowledge of others' "Floating" rotors.
We set a new standard of building a better two piece rotor that you can see and understand why.
