C63 AMG (W204) 2008 - 2015
Looking to buy aftermarket X Pipe!
Old Dec 25, 2014 | 07:00 AM
bshipton's Avatar
2010 C63 AMG. 2010 C300 Sport 4Matic. 2003 ML350
I am interested in buying an aftermarket X Pipe for my C63. If anyone is selling one of knows where i can look to buy one please let me know!
Old Dec 25, 2014 | 07:28 AM
H20 MRV's Avatar
C63 - Golf Tdi
Better to get your local garage to open up and gut your secondary cats, sound great and looks std.
Old Dec 25, 2014 | 07:32 AM
bshipton's Avatar
What is your reasoning for gutting the secondaries instead of cutting them off and running an X pipe?
Old Dec 25, 2014 | 08:09 AM
H20 MRV's Avatar
C63 - Golf Tdi
In the uk you will fail your yearly test if you fit a x pipe, Unless I am mistaken you lot from the colony's have strict
" don't pull the cats " laws, My way its cheap, sounds good and looks totally std and will pass any inspection, not only that you don't have to cut your std system and have It rewelded when you sell or trade the car in, Not only that Merc MAY get upset and void you warranty if you Fit a x pipe, my way they don't know. simples!
see here.. http://www.mbclub.co.uk/forums/amg-l...vment-c63.html
Old Dec 25, 2014 | 08:31 AM
bshipton's Avatar
Good thing I live in the US haha my area isnt too bad with the emissions. As long as i have 1 set of cats I'll be ok. I plan on doing the resonator delete also. If i do that id like to do an x pipe also
Old Dec 25, 2014 | 08:36 AM
H20 MRV's Avatar
C63 - Golf Tdi
Iwould do the secondary's first and see what you think, you may not want it too loud.
Old Dec 25, 2014 | 08:45 AM
bshipton's Avatar
I personally like loud stuff so i wouldnt mind it
Old Dec 26, 2014 | 04:49 PM
CMC-63's Avatar
C63 P31
Definitely do one of the deletes first and see how you like it. I was like you and was planning to do both, and realized the resonator delete was loud enough. I've seen all kinds of set-ups, and straight piping both the secondary and resonator is ridiculously loud. To a point where its almost obnoxious. The x-pipe in the secondary is not as bad, but it is still much, much louder.
Old Dec 27, 2014 | 01:37 AM
Merc63's Avatar
C63 AMG
Gutting a cat will do nothing for performance.
Burns stainless will make u an x pipe but you need to supply some dimensions.
Any good exhaust shop should be able to make an x pipe from two U pipes.
Old Jan 1, 2015 | 09:06 AM
jptaylor's Avatar
W213 E63S Wagon, W204 C63 P30(RIP), WK1 Grand Cherokee SRT8(RIP)
http://www.asaperformance.com/2-5-x-pipe-crossover-st-steel-exhaust-sbc-bbc/
This is what is on mine....reso delete, xpipe, rear muffler delete and to me it sounds amazing.....
Now keep in mind the xpipe quiets the system down a LOT!!!!!! Ive got sound clips posted in other threads
Old Jan 1, 2015 | 12:13 PM
bshipton's Avatar
Ehhh well if an x pipe will quiet the sound im not sure im all for that lol i didnt think it would. Should do a little power increase though, torque if im thinking correctly
Old Jan 1, 2015 | 06:55 PM
jptaylor's Avatar
This is the thread with xpipe sound clip....
https://mbworld.org/forums/c63-amg-w204/561425-non-32-461-exhaust-setup-c63.html
Think about it this way, in the factory reso the pulses just kinda brush up against each other, whereas with the xpipe you are forcing them to collide head on which cant help BUT cancel out some sound.....and actually the reso delete, xpipe install felt like it COST me a little low end torque but I feel I got it back when the mufflers came off.
Old Jan 2, 2015 | 11:16 PM
Ihopaz's Avatar
2013 C63 Amg
X Pipe
I think my shop used a Magna Flow Xpipe with resonator delete and I did second cat delete also and put an Hpipe also. Sounds amazing! In fact I hear aftermarket exhaust systems on here for 3k and laugh mine was $60 bucks for Hpipe custom made in stainless and Xpipe and all piping in stainless for another $100 and my car sounds just as good if not better. In fact not as loud as only header alone but louder than BS exhaust for $3000.00 just and FYI All work was great, welds were great. Search for a good exhaust or hot rod shop to do this for you!
Old Jan 3, 2015 | 12:09 AM
jptaylor's Avatar
So you have an xpipe, AND an hpipe? I dont follow the logic
Old Jan 3, 2015 | 01:33 AM
Ihopaz's Avatar
2013 C63 Amg
I had done one before the other at another time and still wanted it louder. When I went back I told them just to leave Hpipe where the cats where and add the Xpipe and delete the resonator.
Old Jan 3, 2015 | 01:46 AM
jptaylor's Avatar
It would seem to me that would be über quiet
Old Jan 3, 2015 | 01:50 AM
Ihopaz's Avatar
2013 C63 Amg
Very loud! Xpipe does not quest anything down. No drone though
Old Jan 4, 2015 | 10:53 PM
Ihopaz's Avatar
2013 C63 Amg
I meant the Xpipe doesn't really quiet anything down.
Old Jan 4, 2015 | 11:11 PM
jptaylor's Avatar
The xpipe in mine literally cut the exhaust volume in half
Old Jan 4, 2015 | 11:19 PM
Ihopaz's Avatar
2013 C63 Amg
What was your setup when they put the Xpipe in? Did you hear straight pipes no mufflers then Xpipe no mufflers?
Old Jan 5, 2015 | 12:43 AM
jptaylor's Avatar
I was stock and deleted reso only w/ straight pipe...pretty loud
Added xpipe in place of straight pipe....sounded like a Prius
Deleted mufflers.....perfect tone and volume for me
