C63 AMG (W204) 2008 - 2015
EBD, ABS and ESC Inoperative - Also no power steering
Old Jan 3, 2015 | 11:41 AM
nallishaw's Avatar
C63 AMG
ESP module failure?
Hi I'm new here, I purchased a 10 palladium C63 with 59k on christmas eve as a gift for myself, two days ago I took the front wheels off and removed the front bumper to change out the lower grille, put the car back together carefully and as I am leaving my house, I get a bing followed by, BRAKE EBR ABS and ESP Inoperative accompanied by stiff steering, surely I thought I damaged a wheel sensor somehow, I bring it into MB and the SA says oh don't worry happens all the time, we will scan it and tell you which sensor it is. After a few mins of waiting the tech grabs me and says hey I have to show you something, he shows me the diagnostic computer is claiming there is a internal fault with the ESP module itself.
What do you guys think? the car was perfectly fine prior, I am almost certain I did not do anything, I checked all fuses, checked the connections to the wheel sensors, I also want to note that if I start the car up there is no warnings, its when you begin to drive for a few seconds it kicks in. Which is why I swore it was a wheel sensor.
Old Jan 3, 2015 | 12:31 PM
Merc63's Avatar
C63 AMG
I probably have this module if a 09 will work. Where is it located?
Old Jan 4, 2015 | 12:32 AM
roadtalontsi's Avatar
10 C six trizzle
its the electrical module box on the abs hydraulic unit. Usually these are vin coded, mated to the car but i cant say i've done one on a 204 in a long time. It'd definitely not common but like anything electrical it can take a dump at any time, you never know. Sometimes it just wakes up on the wrong side of the bed and will reset and never come back if your lucky .
Old May 8, 2015 | 11:45 PM
Mikecrash's Avatar
2011 C63 AMG
Message pops up when the car gets past 5mph. Before then all systems are fine then message pops up and power steering shuts off.
Getting it towed to the dealer tomorrow - God I hope it's not the head bolt issue.
Anyone have any suggestions/advice or info. Would be so appreciative - car is out of warranty
Car was running just fine before this. Fired it up in the morning to go to work and there it was.
Old May 9, 2015 | 12:26 AM
cmacclel's Avatar
2014 C63 Polar White
If you google the message some people with similar issues state the error was due to a wheel speed sensor.
Old May 9, 2015 | 12:32 AM
cmacclel's Avatar
https://mbworld.org/forums/clk-class...iy-repair.html
Old May 9, 2015 | 09:52 AM
Conv_GSDriver's Avatar
'18 Audi A4
I have gotten the ESC a couple of times upon starting the car. Car's RPMs shoot a little over 1k at idle. I usually turn it off and back on again and it goes away. It does leave a CEL but it clears in about a day or so. Very weird.
Old Jul 14, 2015 | 03:29 AM
Mikecrash's Avatar
2011 C63 AMG
Just a follow up - turned out to be the esp control module. $1300 part had to be ordered from Germany. $1700 total repair cost at the dealer in Austin Texas
Old Jul 14, 2015 | 08:05 AM
cmacclel's Avatar
Sorry to hear that strange everyone seems to be replacing a $25 brake switch for the same symptoms you where having. Did they replace that too
Old Sep 3, 2015 | 08:48 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I've had this come on here and there in the winter but go away after a power cycle. Now it comes on every time after re-starting and moving a few feet.
Old Sep 5, 2015 | 04:38 AM
tdk930s's Avatar
2011 C63 P31 LSD
It happened to me one time two months ago. When it happened ,I tried to restart the car hope it goes away but it comes back everytime when the car about 5 mph and when the door auto lock kick in, so I decide to disable the auto lock function and see. And it goes away until now.So far so good. Hope this will help.
Old Sep 5, 2015 | 04:53 AM
tdk930s's Avatar
2011 C63 P31 LSD
https://mbworld.org/forums/c63-amg-w...ml#post6449600
Old Sep 5, 2015 | 08:45 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I tried disabling the auto door lock, no dice.
For me it's once I go over 20kph (~12mph), the door locks actuate before that speed. If I keep it under 20kph no error so it's not a time duration either. Just speed.
Old Nov 25, 2015 | 01:52 PM
jwickert's Avatar
2011 C300 Sport 4matic
This is common when the battery is getting weak. I had the same warning that came out of no where. Use a multi-meter to check volt out put when the car is off and when running. Chances are your battery will fail a load test if you check the battery. Change the battery, problem solved, for me at least.
Old Nov 25, 2015 | 01:59 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I cleaned all the hub sensors to fix my problem.
Old Nov 25, 2015 | 02:38 PM
deadlyvt's Avatar
2010 C63 AMG
It's 100% wheel speed sensor issue either the inner bearing seals with magnets need to be cleaned/repaired or the speed sensors need to be cleaned or repaired
Old Nov 25, 2015 | 05:45 PM
drawde's Avatar
2009 C63
i had a similar issue pop up yesterday, except it is EBR, ABS and ESP. took it to the dealer and after 3 hours they couldn't do anything with it because they couldn't get the message to pop up. seems to only happen on a cold start.. once the car gets up to temp, i can restart and it's fine until the next cold start.
battery makes sense. my car is a 2009 with 117k so it's up there in age and i don't think i've ever changed the battery. i will also have them check the wheel speed sensors when i drop it off after the holidays.
Old Nov 25, 2015 | 11:30 PM
tdk930s's Avatar
2011 C63 P31 LSD
I agree that happened when I left the car a bit long without driving it.
Old Nov 25, 2015 | 11:51 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
I take it this statement was a joke.
Old Nov 26, 2015 | 03:49 PM
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Mine did the same thing on and off. I changed the battery and that didn't help. Tuesday it came on and stayed on. Wheel speed sensor
Old Nov 26, 2015 | 09:16 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
In my case, I think it was just brake dust buildup on the hub sensor ring. The sensor itself is very protected. I still removed them, cleaned the sensor casing and the housing.
Old Nov 28, 2015 | 10:54 AM
red60R's Avatar
2017 C63S
had this happen on one of my AMG cars in the past and it was the wheel speed sensor, like a few others mentioned.
Old Nov 28, 2015 | 01:54 PM
drawde's Avatar
2009 C63
was it wheel speed sensor for the specific problem in OP? or is it generally for these types of issues? mine is EBR, ABS, ESP..
Old Dec 29, 2015 | 02:31 PM
AMGangster's Avatar
2010 C63
I took out the wheel speed sensors and attempted to clean them. It didn't do anything.
I had the same problem with the same fix. ESP control module was bad. $1,650 after taxes and installation.
It will be fixed tomorrow.
Old Dec 29, 2015 | 06:29 PM
Dogtag114's Avatar
2009 c63
Thanks Bob... And the next contestant is... Dogtag114 with a 2009 model year...
Just came on today... Extended warranty still in effect so may ask for all of the above...
Oddly after filling gas tank, all was good again, even the power steering which cut out... (And why would the steering cut out with any of the above anyway ?!?!)
