EBD, ABS and ESC Inoperative - Also no power steering
Just came on today... Extended warranty still in effect so may ask for all of the above...
Oddly after filling gas tank, all was good again, even the power steering which cut out... (And why would the steering cut out with any of the above anyway ?!?!)
I'm just happy to have it back to normal today.
I have a 2010 GLK350 and I got the exact same messages as the OP: brake AND pwr steering inoperative. The power steering works fine, though. Do the above mentioned sensor cleaning fixes cover that odd combination of messages as well, or just the brake message?
Thanks!
Mike
Ended up grabbing an Easydiag 2.0 Plus to scan everything. After scanning, it did show some stored faults so I figured my EPS module may have bit the bucket. Car was completely fine after the scan lol.
Thanks!
Had a thread on it as well. Looks like carly was comparable.
https://mbworld.org/forums/c63-amg-w...-2-0-plus.html
Thanks!
2010 C63 here. Had the EBD ABS and ESC error, run flat indicator and no power steering upon cold start and immediate drive.
Pulled into the underground at work. Let it sit a couple of hours. Turned on, let it warm up and went for a drive. Took lots of turns and went up to 70KM/H and could not replicate these errors. Warranty is up so I'm hopeful that this error doesn't return. Would hate to have to replace the ESC module.
Goes away with new battery.
Still trying a few things before I do the module swap.
However, after failing for 2 days (including power steering), it miraculously was fine for the 6 weeks I ended up waiting to get it repaired.
Don't rush, it may clear itself... there are a few threads on this.
