Full Weistec build and much more on 2009 C63
Shop is working on assembly plan. Only pic I got so far. Valve covers and brake caliper with bronze power coat to match lip on my ADV.1s. Will have a 'mechanical' look with some depth with the caliper color.
Photographer is taking some unique pics of the parts together with the vehicle.
My ADV.1s are getting Neros and will b shipped directly to me this coming week so ill send some of those.
I know someone who did the same thing with his valve cover and oil pan.
The paint started chipping off where is came in contact with the oil and clogged his oil pump...... in the end he needed a new engine.
I would be careful with painting/powder coating components which come in contact with fluids.
It appeared to me that the covers where coated all the way around since the bolt seats, ignition coil contact surfaces and oil cap sealing surface are coated.
My bad!
Progress well underway on the BS conversion. A little more refining and then will be primed and painted. It'll then be back at Fluid Motor Union for test and tune and dyno.
But 3yrs...... damn. You should just apply for Classic Car plates now and avoid any emission hassles. By the time you’re back on the road they should be valid.
