Is there anyone who can program face lift rear led tail lights to work on a 2010??
I really want to switch mine out.
Depo's are much better if you're going for OEM look. The LED turns are amber and they offer them in both smoked and clear.
Quote:
just going to add my two cents that ipexmotoring also has them in smoked/clear with red/amber turn signals. you can't really go wrong with either supplier.Originally Posted by flubbernub
i believe benzworks in huntington beach can program oem. one of the very few shops that can...
Quote:
If I remember correctly, only 08 & 09 can be programmed with the facelift rear lights. MY10 & MY11 couldn't be programmed.Originally Posted by intence
Quote:
I recall a 2011 C300 owner managed to get his facelift SAM coded. So it is possible.Originally Posted by ab0bab0i
I got mine from ipexmotoring and one of them didn't work. The seller was amazing to deal with though refunded everything including return shipping. I was contemplating ordering another one when another friend had the same issue with his one light not working either. I just chalked it up to low quality or whatever and decided not to order them again. I do think about it every now and then as I really did like the look. What are my alternatives? Any links?
ExploreMBWorld Fanatic!
Quote:
On my 09 sedan I bought OEM taillights + used facelift rear SAM ( so already programmed) and did the swap. It worked like a charm. Aftermarket solutions didn't look reliable for me.Originally Posted by papashango
mthis
close
- Join DateJun 2008
- LocationNy
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveAnything W/4Wheels
Liked:31 Times in 30 Posts
Quote:
so just buy a 2012+ rear SAM and plug it in will work plug and play?Originally Posted by abcut973
Quote:
Yep. You find a rear SAM from a facelift car (doesn't have to be C63 but preferably), install and you are good to go! Now if the SAM comes from a less optioned car you might loose some functionality like heated seats or rear power sunshade. If you have access to star developer you could just code them back.Originally Posted by mthis
Or you buy a brand new SAM get it coded in a facelift car and then install it in your car. That option is the less economical.
mthis
close
- Join DateJun 2008
- LocationNy
good info. would u happen to have a PN for it. i tired looking on parts.com but no luck.Originally Posted by abcut973
Yep. You find a rear SAM from a facelift car (doesn't have to be C63 but preferably), install and you are good to go! Now if the SAM comes from a less optioned car you might loose some functionality like heated seats or rear power sunshade. If you have access to star developer you could just code them back.Or you buy a brand new SAM get it coded in a facelift car and then install it in your car. That option is the less economical.
Quote:
This is the part number for the SAM I bought a year ago : A204 900 55 01Originally Posted by mthis
You might not find it since it is a part number for european model. Bought mine off ebay!
Let me see if I can find the US part number.
mthis
close
- Join DateJun 2008
- LocationNy
Ty. will try with that.Originally Posted by abcut973
This is the part number for the SAM I bought a year ago : A204 900 55 01You might not find it since it is a part number for european model. Bought mine off ebay!
