C63 AMG (W204) 2008 - 2015
please evaluate my rear tire wear
Old Apr 1, 2015 | 08:17 PM
bluejae's Avatar
'10 C63
Normally, I would have replaced my tires long before they got this bad but it caught me by surprise since I've only been on them for 7551 miles.
Attached Thumbnails please evaluate my rear tire wear-img_20150401_170636.jpg   please evaluate my rear tire wear-img_20150401_170731.jpg   please evaluate my rear tire wear-img_20150401_170738.jpg   please evaluate my rear tire wear-img_20150401_174711.jpg
Old Apr 1, 2015 | 08:21 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Do you have a lsd installed in your car? I ask because you have more wear on one side.
Other than that, the wear is normal. You have to remember that you also have long tube headers installed in your car.
Old Apr 1, 2015 | 08:22 PM
bluejae's Avatar
'10 C63
Factory lsd
Old Apr 1, 2015 | 08:35 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
I'd say they look absolutely normal with a modestly agressive alignment other than extremely over worn
Old Apr 1, 2015 | 08:44 PM
johnny--2k's Avatar
2018 GLS 550
What kind of tires? I destroyed my P-Zero and my PSS both in 5K miles each!
Old Apr 1, 2015 | 09:27 PM
HBC350's Avatar
'18 C63A Cabriolet
You've been risking the lives of everyone on the road for about 2000 miles!
Old Apr 1, 2015 | 09:37 PM
I am Jeff's Avatar
I was commenting about the wear on tires, not about the safety. He has LT headers and an assortment of other power upgrades. I have been driving with my ARH LT headers installed for about 2k miles, the added power definitely has a positive correlation to your rear tire wear. The fact that he was able to make it 7700 miles is pretty good. I'm also curious about what type of tires he was running.
Judging by the way he way the tires looked after 7700 miles, he was just endangering the lives of other people for about 1k miles, not 2k.
Old Apr 1, 2015 | 09:49 PM
Merc63's Avatar
C63 AMG
C63 has too much rear toe which causes the rear tires to be scrubbing 24/7 wearing them down quicker.
I removed all but a small portion of the rear toe and my rear tires wear more consistent.
Old Apr 1, 2015 | 10:08 PM
bluejae's Avatar
'10 C63
It was my first time trying out the nexen nfera su1... won't be going back...
Old Apr 1, 2015 | 10:17 PM
rentzington's Avatar
2010 C63 P30
Mine had nexen on when I bought it, fairly new looking and they were half worn after 500 mi Decided to just replace all 4 when one of them got a leak
But my goodness how did you not notice that wear?
Old Apr 1, 2015 | 10:41 PM
bluejae's Avatar
'10 C63
I've only had them on for 4 months... it was just unexpected...
Which nexens?
I've tried n3000 and n5000 and they wear great compared to these...
Old Apr 1, 2015 | 11:28 PM
Merc63's Avatar
C63 AMG
I run all seasons on the rear, just some cheap ones, they work great.
Old Apr 2, 2015 | 02:02 AM
OC6.3AMG's Avatar
C204 C63 507, W164 ML63, 996 C4S
Looks pretty good for almost 8K miles.
Old Apr 2, 2015 | 07:44 AM
2010 C63 P30
Which nexens?
3000 i think, i hate those things. terrible traction compared to the pss
Old Apr 2, 2015 | 08:32 AM
bluejae's Avatar
'10 C63
Pss had better traction... but for me the nexens worked well as an all season (rain) and lasted twice as long... and then there's the price difference... i went through 2 sets of the pss but couldn't keep using them for a daily driving tire..
Anyone think that my alignment could have helped to the tire wear or was it just that these tires were just softer than my previous...
Old Apr 2, 2015 | 09:18 AM
2010 C63 P30
whichever model i had was a super aggressive tread pattern, it was awful in the wet.
if i daily drove mine i wouldnt keep putting PSS on them either, just gets too cost prohibitive if you arent tracking the car.
if you got 7500 out of the rears thats not bad, from what ive read around here most get 5k on michelins so i think your alignments probably fine.
Old Apr 2, 2015 | 10:10 AM
AMGangster's Avatar
2010 C63
You run cheap all-seasons on a State 3 Supercharged C63?
Old Apr 3, 2015 | 12:40 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I guess it was not raining recently otherwise you would have realized this earlier on the highway
Be careful you might not be as lucky next time.
Old Apr 3, 2015 | 01:09 PM
2010 C63 P30
haha we've been getting rain the past few weeks
Old Apr 4, 2015 | 05:05 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
“Anyone think that my alignment could have helped to the tire wear or was it just that these tires were just softer than my previous. . .”
GONE ARE THE DAYS WHEN “FULL FRONT AND REAR WHEEL ALIGNMENT” MEANS WHAT IT SAYS!
ONLY OEM ADJUSTMENT IS “FRONT AND REAR TOE”
For the front (only) you can purchase “one position” offset slotted bolts for the 4 main front bushings. But these only allow a miniscule .3 of one degree (1/8 of an inch – 3mm). And to change setting means labour intensive disassembly each time.
We saw the need therefore to design, manufacture “precisely adjustable replacement bushings” for the front providing both Camber and Caster adjustment and with 3 times the adjustment range of the one position bolts.
For the rear also precise Camber adjustment with additional Toe adjustment to compensate for the new Camber facility.
The patented K-MAC design allows full precise ongoing front and rear adjustment capability – “single wrench” (no disassembly, on car, accurately under load).
To correctly resolve costly, premature inner edge tire wear, steering pull, improving traction, allowing to return to factory specs after curb knock damage, fitting wide profile tires / wheels, altering height or just the advantage to be able to change settings for “track days”.
YOU FIX IT RIGHT THE 1St. TIME WITH K-MAC – No more ongoing trips to dealers or alignment shops or constantly changing tire brands because of only Toe adjustment or the minimal adjustment offered from inaccurate one only position offset bolts!
Bonus is the 4 front (and the 4 rear) bushings also replace the highest wearing suspension bushes. The K-MAC patented design allows twice the load bearing area with the front bushes being 2 axis/self aligning without the use of oil and air voids. Result is improved brake, traction and steering response.
Also importantly K-MAC rear adjusters move lower arms/tires inwards when wanting to reduce inner edge tire wear/improve traction (unlike “Camber Arms” that move top of tires outwards diminishing essential clearance to outer fender).
All kits come with instructions and bush extraction/insertion tubes (MB World member Heiss Rod has kindly provided step by step picture sequence re front bush installation. See https://mbworld.org/forums/w211-amg/518431-k-mac-bushing-install-guide-w211-airmatic.html )
W204 Front kit (Camber and Caster) #502616K $480.
W204 Rear kit (Camber and Extra Toe) #502226K $480.
Including airmatic.
Special promotional price delivery for MB World members USA/CANADA $30 one kit or $40 for front and rear (average delivery time 3 – 4 days). Payment Visa, M/Card or PayPal.
Old Apr 4, 2015 | 10:35 AM
Merc63's Avatar
C63 AMG
Ya why not?? Ice had RE11s on it and they barely make a difference in traction. I'm not racing at a road course so what do I care? I just burn the rears off anyways so why burn an expensive tire off?
Old Apr 4, 2015 | 12:34 PM
bluejae's Avatar
'10 C63
+1
my thoughts exactly... if i'm going to race or something, then i can just switch...
