UPD Adjustable Rear Suspension Arms - Toe and Camber
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
The UPD suspension kits development and testing is complete and is available for sale for many different AMG`s and non AMG models. We have kits in stock to fit all years of W204 and C63 from 2008-2014.
More traction, even tire wear, improved handling, better braking and firm muscular road feel are some of the features attained with the new UPD rear suspension kit. Mildly lowered cars and cars with larger tires can quickly adjust suspension back to factory or custom alignments. Stock suspension and on lowered cars, tires tend to wear out the inside patch of your $300.00+ dollar tires every 4000 miles. With the UPD suspension kit, abnormal tire wear can be tuned out with quick on the car adjustments.
With more tire contact on the ground creating better traction, your car will be faster from a dig or a roll. We have seen from a 30-100 mph roll, up to .4 tenths quicker time by improving traction , reducing rolling resistance with better toe angles and less tire wobble.
The factory camber and toe arms are made with soft rubber bushings that allow a plush mushy luxury ride and compounded by age and use, you get toe and camber wobble.
Features:
*Full heavy duty, adjustable race camber and toe arm kit
* 6061 aircraft grade, 1.25" hexagon aluminum
* Massive 3/4" adjustable chrome molly rod ends
* Self lubricating, self sealing , injected nylon races
* Easy to adjust toe and camber settings while on the car
* Over 26000 lbs radial static load rated rod ends
* One year warranty
Price $ 799
Features:
* One year warranty
Price $ 799
![](http://imagizer.imageshack.us/v2/xq90/661/pkLU5v.jpg)
What exactly is included at that price? All 4 pieces shown included? I presume 1 pair are camber and the other are for toe? Forgive my ignorance.
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Reading up on this in the W211 forum (seems you have never made any product for the C63
). Could you give a little more info on the construction, and if the chassis-end is a fixed link or spherical. Seems some members had problems with the latter. And your "4 tenths" quicker time 30-100 is backed up with a Vbox or similar? Thanks.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Do the rear camber arms work with the level sensor for our cars with lighting package (xenon head lights)?
The reason I'm asking is, because the level sensor is attached to the stock camber arms. I don't see any holes or brackets which the level sensor would attach to on the above shown arms.
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x600/image_c3c5f5d873f432582cffcae72e1ed9803e0f2b45.jpg)
PLATINUM SPONSOR
Straight line performance gains come from a dig to 1/4 mile runs and by tuning your toe and camber angles, allow a lot larger tire patch contact to the ground. Adjusting camber angles and also less toe, allows tires to roll easier/quicker. 1/4 mile and vbox test will show improvements and how verify your suspension tune changes. lowered cars have a lot less tire contact than stock.
Bottom, line is a adjustable suspension kit will allow the suspension to react quicker and most of all give you options on tuning your rear suspension to meet your needs. May it be handling , 1/4 mile or just saving a ton of cash on un-even tire wear.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
PLATINUM SPONSOR
__________________
www.ultimatepd.com
www.ultimatepd.com
Product is made from 1.25" hex 6061 aluminum and then hard anodized. This gives you a strong , light and durable product. Rod ends are 3/4" chrome moly and rated at 27000 psi. You could hang 10 C63 class cars from one rod end![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I see a lot of "more," "better," "faster," "bigger," with no real back up. What specifically is improved and to what degree. So far, they just look like bling.
This kind of hardware (not necessarily this brand, but these kinds of adjustable arms) just address simple physics and geometry. The bigger the rubber patch on the ground, the better your traction - that's physics. When you drop a car on its existing control arms the tires sit on the inner edges - that's geometry. Tires on their edges don't grip as well - physics again. And they wear faster.
Race cars aren't just lowered on their existing mount points like so many "tuned" street cars. They have exactly this kind of hardware in the rear, plus camber and castor plates in the front to get alignment back where it should be.
Negative camber at a road course (track) makes sense because the cornering forces lean the loaded tires back to straight with full contact. Without negative camber at the track you get poor traction and excessive outer edge wear because the outside tire is pushed over toward the sidewall. Most race cars run 3.5 to 5 degrees negative
Negative camber doesn't make sense on the street. I wouldn't go more than half degree rear or full degree on the front for day to day use.
****ed up toe doesn't make sense anywhere, not even on a camel, yet that's what a lot of lowered street cars have.
You don't need this if your car is stock height, but if you have lowered it you need this or something like it. What is really "bling" is lowering a highly engineered German car to a point that the existing suspension components leave the wheels canted at bizarre angels that actually hurt performance.
BLKROKT (09-30-2018)
^ True. The concept is no doubt sound. However you can't go around saying that "from a 30-100 mph roll, up to .4 tenths quicker time" without anything to back it up. That's just a pure bull**** statement right there.
Further, I'd like to know exactly what type of bushing they are using, as there have been some problems with the spherical vs fixed.
Without any previous user experience with this group seen on this or any other forum with the W204 C63, I'd like some more clarity before considering this as a solution vs KMAC or Agency Power.
Neither question was answered. Just more "marketingspeak". This is what the previous poster, and I, were pointing out.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
^^^Fair questions, but I would think as long as they install cleanly and then don't break they would be as good as any other option. I have been researching arms in the last week, and while there are a few makers of adjustable camber arms, this is the first I have seen with adjustable toe as well.
All the camber arms look pretty similar except some have rubber bushings and a couple have spherical bearings. The K-Mac bushings do not sound attractive based upon what I have read, and I will leave my comments at that.
I'd like to see your questions answered about earlier problems. However, there are some positive things written on the 211 forum too.
I personnaly don't care if dialing your alignment properly gives .1 or .4 in a straight line, because in truth that answer really depends on just how f**cked up the alignment was before these were installed. I think it is a bit of a distraction.
All I want are arms that allow me to dial in camber and toe properly, and then not have it break. These particular arms sure *LOOK* over-engineered to the naked eye. If I lower my car (which is likely) this or something like it will be part of the job.
if you think your kmac bushings are loud wait till you use some of these on a street/daily car that see's weather. lol. The toe arms are totally pointless you already have around 3 degrees of adjustment from the factory which is really 2 degrees more than necessary. The camber arms are fine and dandy, but I dont agree with what hans mentioned about a street car only need to run -.5* of camber in the rear. Do you realize the c63 runs -2* front and -2.5* rear STOCK. There is a reason they designed the car this way. You dont know what people are doing with their c63's. Sure some live in the concrete jungle of the city, but some live in the mountains, curvy roads or go out of their way to use the handling the car provides. c63's werent meant to be drag cars. If they were they wouldnt be 4dr, barely fit 265 rear tires, weight 3900lbs etc...
Question though, are you saying the factory adjustment can get a lowered car to zero toe? If so, that is good to know.
And if noise is an issue, what do you think about the aftermarket adjustable arms with rubber bushings? Better?
PLATINUM SPONSOR
This isn't some new vaporware technology. It is a tried and true solution to an old problem, just made to fit these chassis.
1) All the kits go out with Spherical rods ends on both ends, just like in the big picture Shardul posted in the opening thread for all to see. If you want fixed ends or something custom, PM me or Shardul. In the last 10 years or so, quality rod ends are quiet, self lubricating and injected with nylon and other materials to make them durable.
(From the opening thread) * Self lubricating, self sealing , injected nylon races
2) We do find stock cars benefit from being able to adjust toe and camber, since MB tends to lock in a lot of camber , that still creates more inner tire wear. Also the suspension sags with some wear and tear, making camber angles more negative.
Below is how I run my toe and camber on my CL55 but others with 204, 211, 212 and 220 class make all kinds of custom adjustments. Some people want the VIP look and that is where you rake the camber angle in as extreme as possible. For me, I like straight line racing, like Texas mile, 1/4 mile or half mile runs, so I like the least amount of rolling resistance as possible.
![](http://i991.photobucket.com/albums/af31/Vitabc/2015021895161019_zpsxl9dwofz.jpg)
__________________
www.ultimatepd.com
www.ultimatepd.com
I live in downtown Atlanta and unfortunately don't get to many miles on the twisties. The last car I had with a lot of neg camber in the rear was a late 90's 540i. I dialed it out bc I was getting about 5000 miles out of my rear tires.
Just wanted to bump an old thread to clear something up. I still stand by my original post about claiming specific increased acceleration times etc from these without any supporting data. BUT... since I’m using the car almost exclusively for track events now, I needed more adjustability in rear up top to tuck the wheels under the fenders more (in combination with the KMAC lower bushings I should still get my desired -3* of camber). Just got the toe arms and they are BEAUTIFUL. Seriously beefy (yes they are over-engineered to answer a previous question), really very impressed with these. Upper control arms get here tomorrow which are angled to fit, and were impossible for someone like me to cobble together from spare parts. If the sphericals ever wear out, all it takes is screwing in a new one. I likey.
See, I can admit where I’m wrong. Thanks to Shardul for the quick and easy transaction, this is exactly what I needed.
Just wanted to bump an old thread to clear something up. I still stand by my original post about claiming specific increased acceleration times etc from these without any supporting data. BUT... since I知 using the car almost exclusively for track events now, I needed more adjustability in rear up top to tuck the wheels under the fenders more (in combination with the KMAC lower bushings I should still get my desired -3* of camber). Just got the toe arms and they are BEAUTIFUL. Seriously beefy (yes they are over-engineered to answer a previous question), really very impressed with these. Upper control arms get here tomorrow which are angled to fit, and were impossible for someone like me to cobble together from spare parts. If the sphericals ever wear out, all it takes is screwing in a new one. I likey.
See, I can admit where I知 wrong. Thanks to Shardul for the quick and easy transaction, this is exactly what I needed.
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Thanks again for the help and feedback. I very much appreciate it.
