C63 AMG (W204) 2008 - 2015
mandrus mannheim 18x9.5 fitment?
Old Apr 21, 2015 | 03:29 PM
rockdizzle's Avatar
2009 c63amg
Any one know the offset i should run in 09 c63amg with 18x9.5 wheels on rear? 53mm?
Old Apr 21, 2015 | 05:37 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
+48 to +53 will be perfect.
Old Apr 21, 2015 | 05:57 PM
rockdizzle's Avatar
2009 c63amg
thanks
Old Apr 22, 2015 | 12:51 PM
AMG893's Avatar
2010 C63 Estate
FYI im running +48 rear on 9.5" rims with no issues. 255 Pirelli
Old Apr 22, 2015 | 02:22 PM
rockdizzle's Avatar
2009 c63amg
you know if stock lub bolts work with mandrus wheels or did you need new ones
Old Apr 22, 2015 | 03:22 PM
Roswell's Avatar
If ur aftermarket wheels are ball seated, u can use oem otherwise buy cone seated lugs. Only ur wheel manufacture can tell u the right lugs needed.. Unless u can tell by looking in each lug holes.
Old Apr 22, 2015 | 05:52 PM
rockdizzle's Avatar
2009 c63amg
Thanks buying off ebay guy said he talked to mandrus and said the mannheim 18x9.5 53 offset will hit brakes. They have 2.5 inch lip but i spoke to car id and element wheels they said will fit any input or any one have these on a c63
Old May 5, 2015 | 12:07 PM
rockdizzle's Avatar
2009 c63amg
mandrus arrows 18x 8.5 +43 offset hit my brake calipers in the front. need wheel sapcers anyone running 12 or 15mm spacers in front
