How To: Badge Removal and Application
All the items you will need for this procedure. Utilize a manly hairdryer for additional HP. I used a matte black one which gained me an additional .0284 multiplier for HP.
Clean area with detailing spray or window cleaner.
Apply tape to use as a guide. Be sure to align tape to the letters and not up under the letters.
Apply heat to the badge to loosen adhesive and ease removal.
Use fishing line or dental floss and glide along the backside of the badge in a sawing motion.
Saturate remaining adhesive with Goo Gone.
Use a credit card or something similar to scrape off excess residue and remaining adhesive.
Spray area with a mild cleaner to remove any additional contaminants and Goo Gone.
Align badge to the tape guides and press firmly. In hindsight, I would recommend using clear packing tape instead of the tape that was provided to me.
el fin...
Quality of plastic is good as well as the adhesive backing. The letters are a little larger by about an 1/8". They will arrive on backing but are NOT spaced correctly. I realized this mistake a little too late.
One other thing to note, the "A" in their AMG badge is the older pre-facelift version. I had to secure a newer AMG badge thru E-Bay. I'm not too happy with the adhesive backing on that one. I may pull that one off and apply my own 3M adhesive backing on that one.
Thanks!
Thanks!
Measured at the top of the C, using the line of the top of the badge it is 1.5" left to the trunk gap and 1.5" up to the spoiler. The gap between C and 6 is 1". The gap between 6 and 3 is 3/8". The distance from spoiler to top of the 3 on the right hand edge is 1.75" (a 1/4" drop from the C as it follows the curve of the trunk). On the AMG side, it is 2" drop to the left top corner of the badge and 1.75" to the top right corner of the G. The G is also 1.5" from the right hand trunk gap when using the line made by the top of the badge.
Hope this helps.
D3
