C63 AMG (W204) 2008 - 2015
How To: Install Eurocharged Tune
Old Jun 20, 2016 | 10:20 AM
  #101
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Originally Posted by AMGonFire
Sounds like it's the exact same file you received. Shouldn't be different just because of row boxes and an x pipe confirm with eurocharged.
They tell me it's 2 different files, and the file name is also different so I would assume that it's not the same.
Old Jun 20, 2016 | 10:43 AM
  #102
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
You can only have two tunes maximum on the tuner. Double check that as well.
Old Jun 20, 2016 | 07:06 PM
  #103
Mazspeed's Avatar
I did and spoke with Dylan at Eurocharger and they said that I need to bring the car back to stock with the stock tune and then dump the old tune and go from there. I will try that today.
Old Nov 16, 2016 | 11:12 PM
  #104
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
FWIW I was able to load 3 tunes on the MyGenius, based on what PurpleheartAMG mentioned in response to a question I had.
Currently have:
v5-blip
v6-burble
v6-no burble
And the 'stock' tune.
Not sure how many tunes you can load, but it is at least 3.
Old Feb 2, 2018 | 12:45 PM
  #105
tai rahmaad's Avatar
C63 AMG!
Originally Posted by 561design
Ok folks, I got the file back from Eurocharged. Just follow the directions below and you should be good.
Select "Upload to Mygenius"
Select "next"
Remember to select the .MYG file extension when looking for your file.
Select "open"
Select "next"
Select "confirm"
Select "close" and proceed to your car with the Mygenius
Select "work"
Select "writing"
Select "ok"
Select "ok"
Select "ok" REMEMBER position 2 for keys and two button pushes no pedal for KEYLESS GO. DO NOT START THE VEHICLE.
Select "ok"
Select "ok"
At this stage you will hear the engine fan turn on and it will run for the duration of this stage.
Select "ok"
Select "ok"
Select "ok"
Select "ok"
Select "ok"
Select "ok"
ALL DONE!!!
great info bro.. right on point!
