C63 AMG (W204) 2008 - 2015
Can someone tell me what these are? [PIC]
Old Apr 23, 2015 | 08:37 AM
AMG893's Avatar
2010 C63 Estate
I know they are headers
They were off an E63 (not sure if 211 or 212)
They will supposedly fit a C63.
Obviously they need a proper clean up etc.
Will they fit a C63?
Will these delete the primary cats? Or do they bolt up to the cats?
Old Apr 23, 2015 | 09:42 AM
chrisridebike8's Avatar
'10 C63
Not sure of the brand. They definitely delete primary cats. It looks like they use a dump collector instead of a merge collector.
Old Apr 23, 2015 | 09:46 AM
AMG893's Avatar
2010 C63 Estate
Ahh, thanks for the reply.
I didnt want to delete primaries.
Old Apr 24, 2015 | 06:37 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Correct me if I'm wrong, but the type of collector has nothing to do with whether or not you can run cats. It's totally beside the point. O2 bungs are generally in the right place.
Looks to me like you could bolt up a pipe with cat right to the end of that header, as the placement would be about right.
Old Apr 24, 2015 | 07:12 AM
'10 C63
You are correct. I should have put "additionally, they look like dump collectors." All long tube headers go in place of the downpipes that come off stock log manifolds and those log manifolds themselves. The stock downpipes have the primary cats in them. I haven't looked that closely down there but I think smaller cats would be needed to bolt up to LTHs, kind of like the ARH setup.
Old Apr 24, 2015 | 07:27 AM
BLKROKT's Avatar
^ Agree. Sorry my bad I should have gotten that. Race Technology and other high-flow cats are generally smaller too. The cats that came with my MBH setup are much smaller than stock.
Not the best pic, but you can see how small they are here. Could tuck right in behind those headers above. Assuming of course that they fit in the first place. The tight space requirements with the C63 might not be taken into consideration for those headers if the manufacturer was an E-specific shop. I have no idea how tight the space is for those? Without seeing the headers head-on it's tough to tell...
Old Apr 24, 2015 | 11:15 PM
AMG893's Avatar
2010 C63 Estate
Thanks for all the replies guys, i am getting in touch with the seller to see if he can find out from who made them if they will fit W204
Old Apr 25, 2015 | 09:41 PM
Autosport7's Avatar
C63 AMG
Unless they are a custom one-off set, there are only a select few companies making these so odds are pretty good they should be a decent quality.
Good luck op and Happy Modding!
Old Apr 26, 2015 | 12:42 AM
Merc63's Avatar
C63 AMG
Nice headers, minus the horrible collector.
That collector is crap for performance. They should have a high flow merge collector on there.
