C63 AMG (W204) 2008 - 2015
school me on mittyvacs
Old Jun 10, 2015 | 12:25 AM
solekeeper's Avatar
A V8
saw a diy with a member doing his oil change via this way.. i figured i should invest in one since it's not too expensive. which one is the most practical/easy to use?
it won't be used often, so i don't want anything electrical (if such a thing exists) i'd like to keep it as simple as possible.
also i'm used to removing drain bolts and replacing them with new seals etc.. obviously this isn't neccesary with the mittyvac... but is swapping seals something that should be done in general, when changing oil? or as long as the bolt isn't loosened, it will be fine?
Old Jun 10, 2015 | 10:32 AM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
I use a mittyvac to change the oil in my cars.
Works pefectly fine, and makes it much easier. No different than how they change it at the dealership.
Old Jun 10, 2015 | 10:38 AM
Settthhh's Avatar
2006 C55
They are not expensive at all and definitely easy to use, not messy.
Old Jun 10, 2015 | 11:45 AM
solekeeper's Avatar
A V8
was just really curious about the drain bolt issue.. should these seals/o-rings be replaced when doing oil changes? or is it only if that bolt is removed?
Old Jun 10, 2015 | 11:58 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I believe it's just a crush washer on the drain bolt so it can seat to imperfections. If you don't remove the bolt you don't need to change it. That's how they're designed.
Old Jun 10, 2015 | 12:02 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i use this...
Amazon.com: Mityvac 7400 7.3 Liter Fluid Evacuator: Automotive Amazon.com: Mityvac 7400 7.3 Liter Fluid Evacuator: Automotive
Old Jun 10, 2015 | 12:07 PM
Euler's Avatar
2008 C63, 2008 ML550, 2014 KTM 500 XC W, John Deere 990
I have a mityvac and it works great. I also use it on my yard equipment and for removing old gas from things like my generator. I still go under the car on occasion just to drain any sludge from the oil pan.
On the crush washer. I have never replaced one any vehicle I've ever owned and never had a drain bolt leak.
Old Jun 10, 2015 | 02:16 PM
solekeeper's Avatar
A V8
thanks for the replies guys. leaning towards that one mj.
in general, how much oil do you guys feel is being removed via this method as compared to removing the drain bolt? i've read that most vehicles sumps dont allow all of the oil to fully drain via the bolt. mittyvac better for this, (removing more)?
Old Jun 10, 2015 | 02:17 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i'd say about 1qt difference between extracting and draining...
Old Jun 10, 2015 | 02:19 PM
solekeeper's Avatar
A V8
that is alot.
think i'm gonna buy that one off amazon.
or maybe if i can find it locally. i hate waiting for car goods to come in the mail.
Old Jun 10, 2015 | 02:22 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
2-day shipping if u r prime member...
Old Jun 10, 2015 | 09:02 PM
Merc63's Avatar
C63 AMG
How long does it take to suck the oil from the engine? I think mine took 30 mins is that normal?
Old Jun 10, 2015 | 09:05 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
never timed it but it's definitely less than 30min...
oil needs to be warm to extract faster...
maybe ur oil was colder...
Old Jun 10, 2015 | 09:14 PM
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Isn't it better to change the oil when it's warm?
Old Jun 10, 2015 | 09:28 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I have an MV7300. I'd say it pulled around 7.5L of the 7.8Lish in the pan. Maybe you didn't get the tube down far enough?
Which one do you have? I'd say 10min with 100psi inlet pressure and oil around 78C.
Old Jun 11, 2015 | 01:32 AM
tfthach13's Avatar
'09 C63
I was lead to believe that draining from the bottom will yield more oil than sucking it through the top?
Old Jun 11, 2015 | 08:29 AM
rentzington's Avatar
2010 C63 P30
Yes it will but as noted above its not a huge difference
Old Jun 11, 2015 | 09:52 AM
solekeeper's Avatar
A V8
air operated sounds cool. but one more thing that can break. lol
how has yours treated you?
Old Jun 11, 2015 | 09:59 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's actually less complicated than the hand pump unit. It just uses a venturi valve.
I've only used it once so far. Was super easy.
Old Jun 11, 2015 | 10:59 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
should've stated <1qt...
Old Jun 14, 2015 | 07:39 PM
solekeeper's Avatar
A V8
on a final note, which oil should i be using down here in south florida? i cannot seem to find a definitive answer whether 5 or 0 40?
Old Jun 15, 2015 | 04:31 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
That's the one I have as well. I modified by buying a metric sized push-to-connect reducer plastic fitting to eliminate the stepped rubber adaptor between the two tubes. And another with a plug in one end to cap off the end of the tube when I'm not using it to prevent residual oil from dripping out the end of the draw tube.
Next time around, I'd buy the one with the vacuum pump. The hand pump is not well made and tends to lose the ability to create a vacuum.
Old Jun 15, 2015 | 11:15 PM
solekeeper's Avatar
A V8
dammit...
for those of you with the vaccum pump, how is the quality? i don't want to use something twice and have to junk it.
