C63 AMG (W204) 2008 - 2015
Correct setup wheel for 275 rear tire
Old Jul 12, 2015 | 05:29 PM
Stefj's Avatar
Mercedes c63 amg
i try two time to setup 275 on my rear wheel
First I buy forgestar wheel 19"x10 with 275 -30-19 and it bend in my fender
Then I just buy a wheel setup in 18 inch x 10 with +45 offset and a superb tire nitto NT01 18-35-275 and it bend again on the fender ...
I'm tired to try and been advise by incompetent and buy for nothing.
I need recommendation by people who they already build a setup for that ...
Thank you in advance
*****I need to know which wheel offset in 18 and 19 inch, to put a tire *****
This show that the wheel lip are a bit oversize from the fender
Old Jul 12, 2015 | 06:53 PM
johnny--2k's Avatar
2018 GLS 550
first need to know if you are lowered or not... that will make a big difference.
Old Jul 12, 2015 | 09:09 PM
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Lowered?
Forgestar recommend 19 x 10 ET 52 for the C63. I run that size Forgestar wheel with 275 30 19 Michelin PSS with no issues.
Old Jul 12, 2015 | 10:07 PM
Stefj's Avatar
Mercedes c63 amg
No i don't, it's the standard setup
I buy forgestar cf5v 19x10 et?
and 18" x 10 et45
Old Jul 12, 2015 | 10:20 PM
CarHopper's Avatar
E63S | X5
The et45 is your issue. You want something more like et52 as GRP stated.
Old Jul 12, 2015 | 11:43 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Stefj - you used the phrase "bend in my fender "
Just to be sure - did you mean that the tire rubs on the fender?
Old Jul 13, 2015 | 03:31 PM
Stefj's Avatar
Mercedes c63 amg
Yes sorry the tire rub on the fender effectively
Old Jul 18, 2015 | 11:38 PM
AMG6.3's Avatar
C63
I am running Rennan wheels with the following specs:
Rear 275/30/19 19x9.5 with 50mm offset. They fit flush and have no issues rubbing. I am stock height and love these wheels.
Old Jul 19, 2015 | 12:05 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Yes u will need 18x9.5 or 18x10 +50mm & up to fit 275 tires.
Same offset for 19's.
