C63 AMG (W204) 2008 - 2015
Check Engine: P0191 code
Old Jul 20, 2015 | 10:39 PM
ray_huge's Avatar
'06 E55,'10 ML63
Check engine light came on. So I scanned via Star and got the following code:
P0191 Fuel pressure control:the upper limit value is reached*
Anyone ever have this code? or have any clue as to what it might be?
This is for my Ml63 but that forum is fairly slow so I thought I'd try you guys...
Ray
Old Jul 22, 2015 | 01:02 PM
ray_huge's Avatar
'06 E55,'10 ML63
Anyone seen this before??
Old Jul 22, 2015 | 01:18 PM
joemomma's Avatar
CLS63
Currently dealing with it myself, been discussing it in another thread
Old May 19, 2016 | 12:33 PM
Vette Guy's Avatar
2008 AMG E63
Any resolution to CEL code P0191? I'm not sure where to begin - any assistance is much appreciated.
Thanks!
Mark
Old May 19, 2016 | 03:37 PM
Mr. Lin's Avatar
2008 C63
so my 08 C63 has had this problem for awhile now. took it in and the indy shop says it's P0191 and 3699 - Upper limit has been reached or whatever. They say according to their tech site, all of the repairs for this code on this motor have been to replace the fuel pumps. changing the fuel pressure sensor on the fuel rail does nothing.
Old May 25, 2016 | 09:12 PM
qjumpr's Avatar
CLK63 BS
https://mbworld.org/forums/clk63-bla...p-failure.html
Here is a thread that was on the BS page. It shows the pic of my old and new filter. The fuel just clogs the hoses and upsets the pressure. If your car is 5/6 years old, its due for a filter change anyway and its a lot cheaper than pumps, although some have had to change pumps as well.
If you are being cheap and are mechanical, you can buy walboro pumps off amazon and retro fit them in. I was going to do that, but the filter solved my problem.
Old Jun 3, 2016 | 10:06 AM
ml63amg_simon's Avatar
ml 63 amg
Please help me
Hello
I have a ml63 AMG 2007
I have THE same problem 3699 p0191.
If i drive my car THE first 15 minuten i have full power , and than THE car goes slowly.
Parking THE car for 1 a 2 hours than i have 15 minutes full power.
I have replaced:
Fullpomp
Fullfilter
Fullmodule
Full sensor
No results..
Please help me
Old Jun 3, 2016 | 10:20 AM
ml 63 amg
Ray
Is THE problem gone ??
How you did that ?
Old Jun 3, 2016 | 10:26 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
No wonder you have a problem, you can't follow instructions. It says to remove the film before use
Jokes aside, I had the same problem a few years back. Both pumps were replaced under warranty, for me that solved the problem.
Old Jun 3, 2016 | 10:30 AM
ml 63 amg
The film?
What must i remove ?
Can you help me with this problem.
Old Jun 3, 2016 | 12:48 PM
qjumpr's Avatar
CLK63 BS
Originally Posted by ml63amg_simon
Hello
I have replaced:
Fullpomp
Fullfilter
Fullmodule
Full sensor
No results..
Please help me
When you start the car, is there a high pitched whine or whistling sound. If so it may need a PCV valve replaced. This can also cause the P0191 code.
https://mbworld.org/forums/w211-amg/...-m156-e63.html
Old Jun 3, 2016 | 01:12 PM
ml 63 amg
THE sound is normal for 10/15 minutes with fullpower. And then i want do a kickdown the sound is not normal, en than the full power is gone.
Parking for 2 hours than i have
Help me please
Old Jun 3, 2016 | 03:29 PM
Starky_'s Avatar
'10 C63 AMG
I thought the whining sound is normal/common on cold starts with these cars? Usually goes away after a couple of seconds.
Old Jan 11, 2017 | 03:18 AM
ml 63 amg
i have replaced A New ECU and A New valve.
the same problem p0191
gelp me please 8 months stil the car in garages
Old Jan 11, 2017 | 07:19 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
What exactly are you looking for someone to do? Look at all these posts. You need someone who knows what they're doing and has the proper tools to diagnose and correct the issues. It looks like there are a lot of them.
Old Jan 11, 2017 | 08:57 AM
Mbm6f's Avatar
09 C63 AMG
Try finding a shop that has a good diagnostician so you stop throwing parts at it if they aren't solving the issue. Too many shops throw parts at issues because they aren't playing with their own money.
Also, is anyone else reading this thread like it's Borat?
Old Jan 11, 2017 | 10:17 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Couple different solutions in here --> https://mbworld.org/forums/c63-amg-w...ust-pipes.html
Old Jan 11, 2017 | 10:47 AM
BLKROKT's Avatar
He already crapped all over that thread too
Old Jan 11, 2017 | 10:56 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Under a different username?
Old Jan 11, 2017 | 11:27 AM
BLKROKT's Avatar
Oh, sorry. There are many threads all named similarly (see above). Now he can go pollute that one too.
Old Dec 3, 2019 | 12:46 PM
Viktori's Avatar
C63 AMG W204
did someones have solution for this? have same error, but it was erased and not happen again, afaik there is engine cpu should be replaced, but maybe there is solution not so expensive?
Old Oct 8, 2022 | 02:27 AM
Intor_thexx's Avatar
2014 c63
just got done replacing the fuel rail pressure sensor the crankcase breather vent tube as well as the fuel filter and the code still comes back
The codes im getting is 3699 but not p0191
Old Oct 8, 2022 | 11:01 AM
Viktori's Avatar
C63 AMG W204
you should ask for smoke generator on car repair stations to check if engine have vacuum leaks
