C63 AMG (W204) 2008 - 2015
Leaked Supercharger Pics Inside
Old Nov 5, 2015 | 11:10 PM
  #101
mr747's Avatar
c63
Originally Posted by Properstyle
There were no times released on the new chevy SS blower and those cars on pump are making what CTSVs with upper and lower pulley and headers on e85 are making. Hellion just came up with a turbo kit for the new 5.0 mustang that put down a scary 900WHP, yes at the wheels on a stock block. No one has asked about 1/4mile times but customers have sense broke 9s with it. got to give it time sir. It really not that common to have 1/4 miles associated with hp numbers on products, the new age has moved on to roll racing and many just want to know power out up. Not saying thats good but just reality of the market in the US. Those gtrs from AMS have never posted 1/4mile with their packages only power out puts because there are just to many variables to say your car will run this or that.
while this all sounds good no body is running e85 in mercs
Old Nov 5, 2015 | 11:12 PM
  #102
Properstyle's Avatar
2010 C63 AMG, 2009 M3 DCT, 1994 slicktop 2jz swapped 300z
Originally Posted by mr747
built engine v2 tranny stage 3 blower 100 shot of nos 15 x 8 slicks front runners record broken
racing parts solution
Spray makes dream come true. must being using it on the big end. one hell of a mph. that should be around 800whp car or just short of it. very nice.
Old Nov 5, 2015 | 11:14 PM
  #103
mr747's Avatar
c63
There adding more nos into it on there next meet
Old Nov 5, 2015 | 11:16 PM
  #104
iShootYou's Avatar
2019 e63S, 2017 Audi R8 Twin Turbo
Reliability of the engine comes down to the tune, the hardware has been proven across many different platforms. The only reason you can say Weistec has been proven is because they have been the only reasonable option for the m156 platform.
Old Nov 5, 2015 | 11:18 PM
  #105
I think you missunderstood what I wrote. The Chevy ss on pump gas (93OCT) with a magison blower is making what a CTSV with upper and lower pulley with headerss are making on e85
It would be nice to see the jump in performance e85 would bring to the superchaged cars. E85 burns clearer and has better detonation resistants then pump gas and ms 109. also allows for more timing and lowers cylinder temps. I'm sure you will be seeing more c63S amgs doing blends quite soon. turbos and e85 are beautiful match. The only down side is the increase in fuel demand.
Old Nov 5, 2015 | 11:35 PM
  #106
mr747's Avatar
c63
no your wrong there what about eurocharged, OE tuning,brabus, etc etc
all these guys have been tuning c63s and m156s for years yes they have some N/A records but weistec is proven and proven and proven hence why they hold all the records
Old Nov 5, 2015 | 11:37 PM
  #107
Merc63's Avatar
C63 AMG
I think jrcart runs e85 in the clk. Whole new fuel system is required $$$
Old Nov 5, 2015 | 11:40 PM
  #108
iShootYou's Avatar
The magnuson supercharger has been proven to be reliable this same designs is used on multiple platforms. The Weistec tune on the supercharger they sell is the fastest because it is the only reasonably priced supercharger available. Now that we have a more affordable supercharger on the market that is making more power with only 7-8psi we should see some things changing.
Old Nov 5, 2015 | 11:43 PM
  #109
mr747's Avatar
c63
dyno figures can be manipulated those power figures mean nothing
Old Nov 5, 2015 | 11:44 PM
  #110
iShootYou's Avatar
It is amazing to me that e85 is not more common with supercharged m156 you can get much more power and the fuel is less expensive (at least here it is).
Our cars are able to run e85 bren tuning has even posted about it here
bren tuning e85
Old Nov 5, 2015 | 11:46 PM
  #111
iShootYou's Avatar
I won't disagree with you at all. We won't know much until I can see the full dyno she with hp and tq and know what dyno they use.
Old Nov 5, 2015 | 11:50 PM
  #112
mr747's Avatar
c63
bren tuning e85
i wish i had a tune for e85
Old Nov 5, 2015 | 11:51 PM
  #113
mr747's Avatar
c63
i cant access that link
Old Nov 5, 2015 | 11:52 PM
  #114
iShootYou's Avatar
On a n/a car the gains would be small but with a supercharger it would be amazing a friend of mine has an alpha 10 gtr he makes 900ish on 93pump and about over 1000hp on e85
Old Nov 5, 2015 | 11:55 PM
  #115
iShootYou's Avatar
Won't let me post the link any other way it's on Benz boost
http://www.*********.com/content.php...tuning-results
  #116
injectors(only if not direct injected), pumps and a retune. it's a myth about having to replace to different style lines ect. The chemical used in gasoline/10 ethonal is what eats and corrodes lines and causes plastics to break down. E85 doesnt cause this break down. Some say to run larger lines but this only makes sense when the power out put can not be optained on the smaller agauge line. Just throwing larger lines with one pump on e85 causes pressure drop on the higher rpm area because the pump can keep up the pressure due to fuel line size. this is true for all cars. I've been running my z on straight e85 for the last 2 years no problem. and many other have been running for much longer.
Walbro 485 pumps are intake puts that are 150 a piece or you can keep your stock pump and run a surge tank with a inline pump (some think this to be more efficient so you don't have to mess with the stock fuel basket). it's a lot cheaper than people realize.
Old Nov 5, 2015 | 11:56 PM
  #117
charliekay's Avatar
C63 AMG
It has already been stated that going down the path of E85 is not quite worth the gains.
The costs involved - changing the whole fuel setup, including pump, and lines, plus different tank isn't worth the 30whp you would gain.
This is something you would do as a last resort if you are trying to salvage every last hp you can.
Old Nov 5, 2015 | 11:58 PM
  #118
iShootYou's Avatar
Our cars are set to run e85 you don't have to change anything except a tune, I've run e85 on evo's, sti's, 335's, gtr's....with no problem so I have no idea what your talking about you have to make sure your tank is empty and you have a tune and I know with gtr's that switches the tune automatically
Old Nov 6, 2015 | 12:04 AM
  #119
charliekay's Avatar
C63 AMG
Thanks mate. So you are presuming that you can run E85 on C63s with just a tune because you can do it on a GTR?
Go run some E85 in your C63 and let me know how you go.
Old Nov 6, 2015 | 12:06 AM
  #120
iShootYou's Avatar
No that's not what I'm saying at all. You can run e85 as long as your car is tuned for it. I know some people that switch between pump and e85 tune and you have to make sure you change your tune and your tank is empty before you switch your tune
  #121
SO are you speaking from hear say or experience? given your response it's hear say lol.
The problem is when people look at peak horse power gains instead of the entire power band. Being able to ramp up timing sooner provide power down low and through out the mid range with a highe peak gain. no to mention a MUCH MUCH safer fuel for your motor when it comes to detonation.
Here is a real world example and i will see if i have the dyno sheet on hard drive. Premeire performance a local shop I help out at has a car that they do alot of there test with. RB26 with a 76mm turbo on pump gas the max hp that was achieved as 670whp with 480tq at 26 psi. on e85 the same car no other changes made 951whp at 680qtw on 44psi. E85 is great even running it with nitrous is much safer than running pump gas with has much greater detonating property.
Benz tuners are really behind when it comes to putting this type of info out but even when it comes to running flex fuel. gm car used to have to run a sensor that measured the octane level and adjusted timing accordingly. Now with as fast as the ECU in cars are now GM uses the information from the o2 senors and knock reading to make adjustments so the doesn't require an additional sensor.
Old Nov 6, 2015 | 12:10 AM
  #122
iShootYou's Avatar
The problem is when people look at peak horse power gains instead of the entire power band. being able to ramp up timing sooner provide power down low and through out the mid range with a highe peak gain.
Benz tuners are really behind when it comes to putting this type of info out but even when it comes to running flex fuel. gm car used to have to run a sensor that measured the octane level and adjusted timing accordingly. Now with as fast as the ECU in cars are now GM use the information from the o2 senors and knock reading to make adjustments so the doesn't require an additional sensor.
I know gtr tuners are doing the same thing when switching fuels, where the ecu detects the octane and changes the tune accordingly it's really interesting stuff.
I've only owned my amg for a few months, I've modified other cars before and I'm starting to notice Benz guys are behind with the times in many different areas compared to other platforms.
Old Nov 6, 2015 | 12:18 AM
  #123
Requirements of e85 are generally 30-40 more fuel to make the power generated on 93 oct.
How ever the detonation property of e85 is drastically lower. Typically NA cars run their injectors pretty high on the duty cycle unless direct injected. On na setup you could still run e85 but your HP gains would be minimal and not worth the cost of tune for the hp gain.
On a forced induction, or nitrous car this is not the case the gains and areas of safety are much better. BENZ, BMW, and audi have some of the fastest reading and adjustin ecus in their class.
The only platform I have seen that does not use e85 at are the UGR lambos and that is not because of cost but yet the owners of those cars are more than willing to pay for race gas so the company finds it easier to stick to that. This coming from the words of the owners of URG them selves.
Old Nov 6, 2015 | 12:23 AM
  #124
charliekay's Avatar
C63 AMG
I am talking from having discussions with multiple tuners on what fuels are usable on the platform. I race my car (1/4 mile) and am not new to the game, and not new to the platform. If you can tell me from experience something different to what people who have been tuning and modifying the M156 for years then I am all ears.
If you are going to give me some info based on what other cars have done then that is not good enough for me. I'd rather listen to the advice of people who have pushed this car and engine.
Old Nov 6, 2015 | 12:36 AM
  #125
The whole fuel system does not have to be changed. What makes your m156 different from EVERY other motor made? They all operate the same You change fuel systems base on duty cycle and fuel pressure requirements with rpm.
Its not any where near as complicated as people try to make it seem and I've found many will try to make something in to some complex discussion instead of just saying we haven't really tested it or we don't know. This being a big issue with tunes on any platiform.
If you can tune for race gas you can tune for e85 the difference is duty cycle required. If you had 100lb injectors they will have the ablity to produce more at 50 percent duty cycle on c16 than they will be on e85 because e85 requires more volume.
Benz has quite a few vehicles that are factory tuned for flex fuel. If your tuner is willing to safely tune you car for it you can run e85. when you reach the limits of your fuel pump and injectors they get upgraded plain an simple.
