C63 AMG (W204) 2008 - 2015
new owner- 2012 feels unstable on the highway
Old Sep 11, 2015 | 06:15 PM
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
UPDATE PAGE 4
I just took possession of my P31 C63
Everything on the car is stock
18" wheels front and rear with the split 5 spoke
Continental Sport contact at the front: 235/40/18
Continental Extreme contact rear : 255/35/18
pressure is 39-40 front and 45 rear
tires have GREAT tread 7/32
at take off and under 55mph - car feels fine
over 65-70 on the highway cruising im floating around the lane
is this because i dont have a limited slip and the car is pushing in one direction?
is it that I dont understand F/R with 445 ft/lbs tq?
any help is appreciated before i hit my first track event.
again stock suspension and wheels.... makes no sense to me
Old Sep 11, 2015 | 06:25 PM
flubbernub's Avatar
2013 C63 P31 coupe
Congrats on the new purchase.
By floating around, do you mean pulling left and right at random times?
Old Sep 11, 2015 | 06:37 PM
dbldpr's Avatar
Veteran: Navy
Welcome
Old Sep 11, 2015 | 06:51 PM
95gsrturbo's Avatar
More like contanstly if I'm on throttle. Not like pulling as if there was an issue with an alignment. It's different hard to explain except for "floating" it's the only word I can think of.
Old Sep 11, 2015 | 06:52 PM
95gsrturbo's Avatar
Originally Posted by dbldpr
Welcome
Thank you
Old Sep 11, 2015 | 07:00 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
It is definitely not normal to feel like the car is floating.
The lack of an LSD will not be the cause of that feeling.
Get an alignment. Was the car ever in an accident? Aside for the tread depth being even, how does the wear on the tires look? is it even across the tire?
Old Sep 11, 2015 | 07:03 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
It could be your tires mismatched. Check the suspension too.
Old Sep 11, 2015 | 07:22 PM
AMG893's Avatar
2010 C63 Estate
Get an alignment. Or at least (if not getting an alignment) get it on a hoist of a suspension place, and get them to check everything is tight, and nothing is prematurely worn out.
Even on newer cars, some parts can be defective.
As previously mention, lack of LSD wont cause this
Old Sep 11, 2015 | 07:34 PM
chrisridebike8's Avatar
'10 C63
Is the freeway surface grooved? In my experience, some tires tramline so badly on grooved pavement that I've stopped on the highway because I thought I had a flat tire.
Old Sep 11, 2015 | 07:59 PM
95gsrturbo's Avatar
Thank you everyone for your replies.
Tire tread is perfectly even across all 4 and as I mentioned it's different than an alignment pull but I'll do that asap to check
Does anyone know if alignment is covered by the factory warranty?
Old Sep 11, 2015 | 08:02 PM
Guilty's Avatar
'16 C63-S
Your tires are over inflated. Happened to me before. Reduce the PSI to spec and you should be gtg.
flubbernub's Avatar
2013 C63 P31 coupe
No it is not, unfortunately.
Old Sep 11, 2015 | 08:06 PM
95gsrturbo's Avatar
Old Sep 11, 2015 | 08:13 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
+1
Old Sep 11, 2015 | 08:16 PM
95gsrturbo's Avatar
Old Sep 11, 2015 | 08:21 PM
95gsrturbo's Avatar
I'm actually under spec right now.
Inside the door shows 42 front 46 rear.
I'm at 39/45
Old Sep 11, 2015 | 08:23 PM
HBC350's Avatar
'18 C63A Cabriolet
^+1. Sounds like tramlining to me. If the car is darting right and left over the drainage grooves with no other rhyme or reason, that'd be my bet.
Old Sep 11, 2015 | 08:27 PM
Guilty's Avatar
'16 C63-S
I'm at 39/45
Nvm then Idk lol
Old Sep 11, 2015 | 08:35 PM
ENVē's Avatar
2001 Porsche 911 Turbo (heavily modified)
Mismatched tires will do that.
That 39/45 spec which is front which rear?
Old Sep 11, 2015 | 08:40 PM
95gsrturbo's Avatar
Unfortunately no - no grooves on the road... I assume you mean like construction.
Example: today I was cruising in 6th gear (S+ mode if that helps) and wanted to pass an 18 wheeler. Blinker on and I begin to change lanes - car downshifts and I begin to change ... car carries me across 2 lanes to the left. I changed one lane... car "floated" on air the other lane
But it happens within the same lane while cruising too. Just sliding left and right.
Gonna take take a ride with a buddy now and see if he can explain it any better.
Old Sep 11, 2015 | 08:55 PM
95gsrturbo's Avatar
He says car feels "loose"
As if something suspension was disconnected
These cars don't have an active suspension do they?
rickclass's Avatar
2014 C63 AMG 507 Edition
what type of tires are they? correct load/speed rating?
Old Sep 11, 2015 | 09:00 PM
95gsrturbo's Avatar
Yes
Continental sport contact Y rated up front
Continental sport contact extreme Z rated rear
Old Sep 11, 2015 | 09:06 PM
95gsrturbo's Avatar
So it's dark but crawled under the car and looked and there does seem to be an electronic dampener of sorts on the front which could be a problem but I would assume if it was I would get a code
Old Sep 11, 2015 | 09:19 PM
ENVē's Avatar
Ummm I dont think these cars have any adaptive suspension
