AMR Performance Tuned: C63 AMG w/ Nitrous: A little bit of nitrous goes a long way :)
This clients setup is quite unique as it has only the "bare-bones" of modifications done.
Modifications:
- Drop-in Air Filters
- AUTOMASTER Custom Test Pipes (www.automasteramr.com)
- AUTOMASTER Custom Nitrous Oxide System (www.automasteramr.com)
Fuel:
- Pump Gas: 93 Octane
ECU:
- AMR Performance: Custom Nitrous Tune (www.amrperformance.com)
Power:
- Base Line: 385hp / 380tq
- Nitrous + Tune: 528hp / 600tq
"RAW" Dyno Plot:
Track Time Slip:
Special Thanks:
- David: For choosing AMR Performance for his ECU software needs and providing us with his results as well as his experience.
- AUTOMASTER: For their expertise in custom fabrication and excellent installation services. (www.automasteramr.com)
- Nitrous Express: For their solenoids and bottle.
Not to mention the exhaust costs the same, so why wouldn't I just buy from Weistec?
Stock tire 1.7 60'? With nitrous? Or was nitrous used after launch?
The custom test pipes were done by AUTOMASTER not AMR Performance. Different companies.
Our website: www.amrperformance.com
Their website: www.automasteramr.com
The custom test pipes, done by AUTOMASTER, eliminated both right and left CAT on the vehicle. We noticed through testing, on another C63, that the factory CATs will fail with anything over a 50shot and sprayed consistently.
The nitrous setup, which was done by AUTOMASTER, had an activation switch for the system to power and was triggered to "spray" under wide-open-throttle (WOT).
Regarding tires, the customer states he had street radials on the car.
And what method was used for shifting - RS, S+, manual? Power brake? Weight reduction? Was it a coupe or sedan, FL or PFL? Wheels and tires used?
Just trying to figure out the differences between these two separate companies located in the same place with the same name.
AMR Performance: We manufacture software & hardware for the automotive industry. We manufacture a complete line of intercooler systems, exhaust systems, turbochargers and a large variety of other products. We also are the exclusive U.S. (CANADA as well) importer & distributor for automotive & aeronautic balancing equipment (i.e.: turbochargers, flywheels, driveshafts, etc...). We also are the exclusive software provider for a variety of aftermarket companies such as Raptor Superchargers, Vogue Performance, etc...
Though we can not speak for AUTOMASTER, we can tell you the following:
AUTOMASTER: Custom fabrication, engine building and installation. They are our preferred installation shop.
AMR Performance current "open-to-the-public" location is at Suite A of Jansen Street. This is a temporary location as we are patiently awaiting C-of-O (Certificate of Occupancy) at our new building/location in which AMR Performance will notify the public of its grand opening.
Disappear? No sir! Busy busy.
We just launched our new tuning center in Danbury, CT 06810.
Check out our website for directions and further details.
In regards to the car, customer has been enjoying it. Once the weather breaks I'm sure he will be back out.
If somebody has a conventional tune (ie with more timing, fuel etc) to take advantage of headers etc, how much nitrous is a safe amount to run? Or rather, who has actually safely managed to run x amount with a tune and for a number of years/miles?
