Weistec Stage III SC. Stock Engine Internals goes 10.22.
The fastest Stage 2 SC M156 which is a CLK63BS is running the same headers as me. This is 10.48 out of a Stage 2.
These headers started as MBH headers but they are modified, not only to fit RHD but also modified for power.
Something is not adding up to me?
But then again there is also a stage 3 with built engine also running 18psi that has run 9.90 but that was built recently.
I honestly think it has something to do with the new version of the tranny plus the flow of the headers.
Looking forward to pushing each other into the 9s.
I hope that tranny makes that much of a difference, mine is at Weistec now for v2 upgrade.
Must be something in the air down under, you guys are all running very strong there.
Charlie, are you going to throw the smaller pulley on with the stock engine?
Looking forward to seeing your results with V2 tranny.
At the moment I am hesitant to run a smaller pulley, I am trying to find the right wheel setup to help with the 60ft first. If I get closer to 9s with a better wheel setup then I might try it, but I do not think the smaller pulley will shave off enough time alone to get me to the 9s.
Your thoughts?
What power are you making currently?
Will we be seeing a C63 Stage 3 with stock internals in the 9s? I hope so!
Do you have the ice tank?
Also if you trailer the car there that would knock another .1 off for sure.
4-5lbs might just make enough difference to get a 9.
Might be worth talking to Weistec to see if they think the stock engine will hold up.
I know someone of you guys have a ***** fit when a dyno number is mentioned, but a BONE STOCK CLS made 25 less whp then my car. Exact same dyno, same correction, same temperature, and the pulls were 12 hours apart. I had all the bolt-ons besides the supercharger. That is ridiculously low gains over a stock vehicle, unless mine has a major underlying issue.
I'm a tech for living and worked at a shop with a Dyno Dynamics. The numbers are a very equal comparison and "accurate" representation of actual power. My trap speed is proof. Stock E55s at my local track are trapping 117. I still need to get this car on a scale to compare the weight of it to a C. It is going to be one of the heavier Es due to the Panoramic roof.
12.17 @113
1.90 60 ft
This was with absolutely no wheel spin. The car is on drag radials and was like a Honda before the supercharger. It was a dog before 5k. All the local tracks are closed so I will have to wait till next year to get a pass in.
I bring up the cam issue because I have worked on two 63s in the last four months that have needed cams/lifters, and a couple that have needed adjusters. There is another thread started discussing these issues, and one person had the cam wear with no valve train noise. The two I have seen have had very obvious audible valve train issues.
12.17 @113
1.90 60 ft
What track you running at?
Your car is absolutely hauling ***. That must be a fun ride.
The non built motor part isnt shocking. Plenty of stock 2jz motors to hit 900-1000whp. It's all in the tuning to get them there, but no matter how conservative the tune they dont stay together like that for long and neither will a m156
It's alot cheaper to put upgraded pistons and rods in before you put custom windows in the side of the block. New short blocks aren't cheap.
How has the TCU upgrade been working out? I've been thinking I should do it try to get the most life out of the clutches.
My comment regarding MBH was directly from the tuner. This was not my opinion, just what he said. It seemed to be his reason for not having any interest in looking further in to my car.
I think the numbers are close enough to right. 635hp atw, would be about 770-780hp crank, which is what Weistec say the Stage 3 system puts out.
780hp should get you close to 139mph for a 3900lbs car, unless my numbers are off?
It's alot cheaper to put upgraded pistons and rods in before you put custom windows in the side of the block. New short blocks aren't cheap.And that is why I do not want to put the smaller pulley on, getting a 9 is fun, but will the engine go boom before or after I hit the 9. That is the risk of running 14psi on a stock engine
Merc63 has been running a Stage 3 on a stock engine for a while, with no issues, so hopefully mine stays like that.
It's alot cheaper to put upgraded pistons and rods in before you put custom windows in the side of the block. New short blocks aren't cheap.I don't have the TC or the heads, engine is completely stock. My friend with just headers and tune is only trapping 115mph. Our track is pretty slow compared to others.
There is a track 11-12hrs away, a few buddies with blowers went and were doing .25 quicker. Catch is they are real tight with the rules and I would need a cage to run.
How are you launching the car? Off idle? What rpm?
By the way, awesome time and mph.
Have tried launching a couple of different ways, best times have been coming off idle and onto the accelerator on green, also tried stalling up to 2200rpm and flooring it on green. They both netted similar 60fts but the ET was better coming off idle.
