C63 AMG (W204) 2008 - 2015
Weistec Stage III SC. Stock Engine Internals goes 10.22.
Old Nov 3, 2015 | 08:04 PM
  #76
65fastback's Avatar
amg c63
Originally Posted by charliekay
My thoughts exactly.
Have tried launching a couple of different ways, best times have been coming off idle and onto the accelerator on green, also tried stalling up to 2200rpm and flooring it on green. They both netted similar 60fts but the ET was better coming off idle.
A shorter tire is easy to try and inexpensive, this should be the next move... make one change at a time. stage shallow.
Old Nov 3, 2015 | 09:02 PM
  #77
PetroC63's Avatar
2012 CTS-V
I would try slightly above idle. 1200 to 1500 rpm. Just enough to take some slack out of the drivetrain while still being able to get a little flash out of the converter. Go around the water box and back into the water so not to get any water on the front tires. Also, tire pressures are very important and are dependent on track conditions. I always like to start at 20 psi and go from there, which is usually down until the car hooks. And always check your pressure after a run and adjust because they will be up a pound or two. Do a good burnout and have fun.
If you can get a 1.50 on that 60' I think you can run 9's without adding anything else to the car.
Old Nov 3, 2015 | 09:09 PM
  #78
Merc63's Avatar
C63 AMG
Get the torque converter that will get you off the line harder. Without it I doubt you will drop a .1 on the 60' unless you drop weight and try a smaller tire.
Get a race battery, remove front pass and rear seats.
Try trailering the car out there too. The heat soak from driving out there will cost you.
Old Nov 3, 2015 | 10:29 PM
  #79
roadtalontsi's Avatar
10 C six trizzle
Originally Posted by layzie12g
Are you on the east coast by any chance?
How has the TCU upgrade been working out? I've been thinking I should do it try to get the most life out of the clutches.
My comment regarding MBH was directly from the tuner. This was not my opinion, just what he said. It seemed to be his reason for not having any interest in looking further in to my car.
not sure if this was directed at me? but i'm in dallas texas. tcu works good. Not going to say it's night and day different but noticeable. My trans only lasted about 15kmi before giving me troubles. I've got around 10k since the rebuild (stock internals) and tcu upgrade. So we'll see if it holds up any longer this go around soon.
Old Nov 4, 2015 | 05:28 AM
  #80
RNS-11Z's Avatar
09 C63
Charlie what's it like to drive with the convertor?
Old Nov 4, 2015 | 04:32 PM
  #81
charliekay's Avatar
C63 AMG
It feels very stock mate, the car is still very beautiful to drive daily.
Old Nov 4, 2015 | 06:39 PM
  #82
ZeroF's Avatar
C63 AMG 6.3L IPE
I'm a bit late but congrats Charlie, my palms are sweaty just from reading this thread
