AMG3.2's DIY Headbolt Adventure
https://tarheel.mbca.org/star-articl...ne-refinements
The variable cam is actuated via oil pressure, from a solenoid.
There should be two measured parameters:
The position of the camshaft sprocket and the angle of the cam as actuated by the solenoid.
Now the oil pressure varies so, as the solenoid pulses oil into the actuator, there could be errors of angle.
So then the procedure holds the rpm steady and therefore the pressure steady and possibly puts the actuator through a routine and gets reports from the angle sensor. A calibration.
Now why I meant to say is that my old w124 was an early throttle by wire car, with abs and traction control.
After I bought it, I tried to rev it from under the hood, to listen for noises, using the cable for cruise control.
The minute I did this, I got an abs and traction control error. So these three, throttle abs and traction are tied together. With our cars the cam angle could be tied too.
I've had my e63 for about a year now and totally love it. Just ordered the tappets, head bolts, and everything else for my preventive head bolt and lifter replacement job. These threads have been remarkably helpful and informative to get this done on my own. Will take some pictures of my experience and post the inevitable issues and questions I get as well.
Thanks!
Where exactly are the 0000 0000 1150 Timing Case Bolts used?
I just completed the head bolts/tappets job on the right bank. I swapped the headbolts and lifters, reattached the camshafts, cam caps, cam adjuster, and cover. I assumed the Timing Case Bolts replaced the cam adjuster cover screws, but that takes 5 + ground, and I notice you ordered 8 (4/side).
Thanks in advance and for this super helpful thread.
As Merc63 has mentioned in his DIY threads, this is not a DIY kinda thing. You have to a) be mechanically inclined, and b) have done tons of tons of reading on the subject.
Below is my updated parts list:
M156 Tappets, 156-050-02-25 $17.55 32 $561.60
M156 Updated Headbolt, 156-016-07-69 $8.31 20 $166.20
Actuator Bolts, 910105-012018 $8.42 4 $33.68
Timing Case Bolts, Eight Zeros in front 1150 $2.22 8 $17.76
27MM Short Socket for Crank $9.98 1 $9.98
Mercedes Cam Timing Tool M156 $90.00 1 $90.00
Engine Lubricant - Redline $16.40 1 $16.40
Engine Camera $20.00 1 $20.00
Torque Angle Guage $20.00 1 $20.00
High Temp Silicone $6.00 1 $6.00
Cylinder Head Gaskets 1560162221 $6.00 2 $12.00
Valve Cover Gasket Left, 156-016-25-21 $19.89 1 $19.89
Valve Cover Gasket Right, 156-016-24-21 $19.89 1 $19.89
Spark Plug Gaskets, 1560162121 $5.85 8 $46.80
Diamond Washers Cam Phaser, 1560510275 $6.32 4 $25.28
3/8 Torque Extension $10.00
m5-8 screw 4
Coolant
CDI Torque 2502MRMH
CDI 1002MFRMH
Mobil1 0W40 Oil + filter
Best prices on OE parts are found here.
http://stores.revolutionparts.com/mb...-v8-gas-engine
Do you mind posting a picture of said bolt? Maybe that'll jog my memory.
Edit: just found the pic here: https://www.ecstuning.com/b-genuine-.../000000001150/
I have no clue actually. I think I ended up not using these.
I dropped by my local AD parts dept today (to discuss a snapped cam cap bolt... more on that later). He gave me a parts printout for the heads. It turns out these are replacement bolts for the camshaft bridge. Smoke em if you got em I say, (but mostly wasn't sure if the new screws superseded the original ones like for the actuator bolts) so I replaced them since they came out as part of the install anyway. There are 8 in the car, and I ordered 8, how tidy is that.
Thanks for your responses. Here are some pictures of the new and old screws side by side, bridge before, after, and the Merc docs
Another question - the stock head bolts had some sort of white paste/grease/something applied to the threads. The Weistec studs call for moly. Any idea if anything is needed for the updated bolts? Did you apply anything to the threads? I'm applying some Permatex high temp gasket maker just under the heads of the bolts to seal the top.
I saw an awesome yellow wrapped pre-face lift C63 on sawmill road today.
