C63 AMG (W204) 2008 - 2015
how much peak amp is needed to jump start our cars?
Old Jan 25, 2016 | 06:12 PM
bluejae's Avatar
'10 C63
i'm looking to purchase one of those portable jump starters... they talk about amps and peak amps in the descriptions... some of them even tell you what size engines they will work on... so to make it easier for me, i'd like to know what specifications i should be looking for to know that it would work with the c63 engine/battery...
Old Jan 25, 2016 | 06:33 PM
Carbon Dated's Avatar
2019 GLE 63S AMG, 2009 C63
Good question. I got one of these lithium ion jump starters for a Christmas present. Mine is made by Stanley and it claims to be able to start a V8 car or truck. I have not used it as yet but it is a nice looking unit for what that's worth.
Old Jan 25, 2016 | 06:36 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
There should be a CCA rating listed as well. IIRC our OEM AGM battery is 850CCA, when I replaced mine it was down to 486CCA. It would be good enough for one start at least.
Old Jan 25, 2016 | 07:46 PM
tpliquid's Avatar
too poor now
i usually use 2 sets of jumpers if my car battery is total dead
Old Jan 26, 2016 | 02:38 PM
bluejae's Avatar
'10 C63
yes, i've seen some that say for V8 cars... but also seen some that state V8 up to 5L... i think i saw one that said 6L as well...
i believe you are correct... website for a replacement battery says 850CCA... cold cranking amps...
but i guess what i'm looking for is what is the minimum needed to start the car with a jump starter... if something like 500 amps will be enough... then i figure i can ignore the notes about it only working for 4 cylinder/6 cylinder...
i don't know what specs of the jump starter make it compatible for a V8...
Old Jan 26, 2016 | 02:47 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I'd say 500CCA is the min and not to be confused with Amps or Max Amps. Those ratings are useless.
Cold Cranking Amps are the numbers of amperes a battery at 0°F/-18C° can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12 volt battery).
If they only list CA it's the same as above but at 32°F/0°C
Old Jan 26, 2016 | 03:31 PM
bluejae's Avatar
'10 C63
for example
Amazon.com: Stanley J5C09 1000 Peak Amp Jump Starter with Built in Compressor: Automotive Amazon.com: Stanley J5C09 1000 Peak Amp Jump Starter with Built in Compressor: Automotive
this says 1000 peak battery amps / 500 amp instant starting power...
so something like this would work with our cars?
and then there are products like this one
Amazon.com: NOCO Genius Boost Plus GB40 1000 Amp 12V UltraSafe Lithium Jump Starter: Automotive Amazon.com: NOCO Genius Boost Plus GB40 1000 Amp 12V UltraSafe Lithium Jump Starter: Automotive
where it says 1000 amps starting power... works on engines up to 6L... but our engine is 6.2- 6.3 whatever...
Old Jan 26, 2016 | 04:05 PM
I was all set to buy that exact NOCO Genius Boost until I got the other one (Stanley) for Christmas. In a perfect world, I'll never have to use it but it's nice having around. Doesn't take up much space in the trunk.
Old Jan 26, 2016 | 10:57 PM
QWKSNKE's Avatar
09 Carrera S, , 03 F250 CC FX4
I would consider the below since the M156 is a high compression engine
http://www.amazon.com/gp/product/B000JFJLP6
Old Feb 9, 2016 | 12:56 PM
hyunman's Avatar
2010 C63
https://www.ecstuning.com/News/Schwa...016/ES2986358/
Saw this on ECS' site and was looking to pick it up if it would work for the C63. I know the compatibility chart says it will work for all Mercedes cars, but I've seen other similar jump starter kits that say will only work for up to 5L engines. The description also states "If starter draw on vehicle is less then 200 AMP this should start your vehicle." Can anyone confirm what the amp draw on the C63 6.2L motor is?
Last edited by hyunman; Feb 9, 2016 at 01:03 PM. Reason: Forgot to insert the URL for the ECS jump starter...duh
Old Feb 9, 2016 | 12:59 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yup. I have this one with the air compressor and it works great.
Amazon.com: Jump-N-Carry JNCAIR 1700-Amp 12-Volt Jump Starter with Power Source and Air Compressor: Automotive Amazon.com: Jump-N-Carry JNCAIR 1700-Amp 12-Volt Jump Starter with Power Source and Air Compressor: Automotive
Old Feb 9, 2016 | 01:07 PM
hyunman's Avatar
2010 C63
Sorry..had to edit my post because I forgot to add the URL to the ECS jump starter I was referring to...duh
That thing is huge though maybe because of the air compressor. I already have a portable air compressor so I was looking for something bit more compact like the one in the ECS link.
Old Feb 9, 2016 | 02:35 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
I bought the 1000 amp Stanley jump starter. It works great for jump starting our cars. I had forgotten to plug in the battery tender and the battery did not have enough charge to turn the motor. The stanley jump starter didn't struggle at all to jump the dead battery.
Originally Posted by bluejae
for example
Old Feb 9, 2016 | 02:37 PM
BLKROKT's Avatar
Looked at the ECS thing. I don't think 200A is nearly enough for our big engines.
Old Feb 9, 2016 | 03:26 PM
hyunman's Avatar
2010 C63
Hah..yea my gut was telling me the same thing. Just wishful thinking on my part. I'm seeing quite a few other compact options on Amazon with much higher starting amp ratings so maybe I'll try those. Thanks for the input guys.
Old Nov 6, 2022 | 02:02 PM
B N's Avatar
B N
W 211, 2003, E-320
Any one knows :
1. of a JUMP Starter for E-320, W211 which can be charged by the Cigaret lighter while the car is being driven?
Your Answer : __________________________________________________ _______________________
2. Simple answer as to how many apmeres are needed to jump start the above car? would 700 Amp help if the battery has some voltage like 10V?
Your Answer: __________________________________________________ ________________________
Thank you. BN
