Well that's just plain dangerous. . .
C63 AMG, P30
This is the cheapest I could find online:
http://www.oemercedesbenzparts.com/o...FUiGfgodteEAHA
EDIT: Just found this. May be worth looking into such it's a fraction of the OE part's cost.
http://frugalmechanic.com/auto-part/...86-control-arm
I admit, I don't know a thing about MOOG so you may want to do a bit of research as to the quality of the bushings etc.
Generally speaking, MOOG has a pretty good reputation for quality parts.
I called dealer at it's $700 per control arm. A bit excessive if you ask me.
Good thing I've got an aftermarket warranty on the car. . . .
Little update. This is a dealer only part. No aftermarket solution.
Is it normal that a control arm fails prematurely like this? Car has 80k KM's on it.....
On top of it all my aftermarket warranty does not cover suspension parts.
C63 AMG, P30
Okay - either I'm missing something or you are lol but I swear this is the lower control arm. ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
http://www.fme-cat.com/overlays/part...int%20Assembly
There shouldn't be a bend in the middle.
See ECS Tuning link below. This is the part needed. MB part exclusively....
https://www.ecstuning.com/Mercedes_B...Arm/ES1738116/
C63 AMG, P30
1) Look at the bushings between the Moog and ECS part. In the Moog part, the hole is slotted to allow for adjustability while the OE part doesn't have that slot.
2) The part number, if you look closely on the ECS piece, doesn't match the OE number which is 2043305011. It reads 2043330060
I'm a bit confused to be honest. Google "C63 Control Arm". You'll actually find that it looks like the Moog part and not the ECS tuning part. That picture looks to be wrong. If what I'm saying is correct, you could save a boat load of money.
Hmm.. Strange. Two things I noticed on the ECS picture.
The part number on ECS is correct. It states it under the description.
Bottom line there are two control arms per side:
1 with balljoint facing down (cheaper one)
1 with balljoint facing up (The dealer only part)
Marcil802 (06-17-2022)
C63 AMG, P30
Hmm let me do more investigating
EDIT: Damn. I think you're right. Why do they have an upward AND downward facing lower control arm?
Totally agree. The part number they list is correct, but it's not the pictured part. Zoom in on the second picture. It says 2043330060 which is obviously not 2043305011.
Trust me I was rattled when I found out the price..
Almost looks like the movement is where it attaches to the knuckle??
I think I have a used set here. Never seen those go bad before, you must be smashing a lot of potholes hard.
Is the nut on top tight?
To be honest I didn't even check... just figured the control arm was shot.
The nut on top was tight. The arms are in fact shot. Visited the dealer and they only had one available, claiming the 5011 part number is back ordered.
Please let me know thanks.
Hi Guys, mechanic also told my my front left lower control arm is shot. Just a question, are P30 control arms the same as standard C 63?
I see this one on ecs and this other on another website, is it the the same one?
Anyone know the difference between these parts?
Left 2043300107 Right 2043300207
Left 2043305011 Right 2043304911
https://www.ecstuning.com/b-genuine-...rm/2043300107/
https://www.getmercedesparts.com/oem...Vuc2lvbg%3D%3D
