Spark plugs with a supercharger
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
Like title says I need to know what plugs you guys are running with stage 3 weistec blowers,I have 3k miles on my stage 3 n went thru 6 sets of plugs,just installed a fresh set 3 days ago as I had a racing event today and car ran smooth when I installed,started car this morning after cold start car started missing again fml
No check engine light or anything just a miss idling,car runs strong when wot.
Tried to reach weistec past 3 weeks to no success,I need to figure out which plug is suited for blown cars and which gap?
Thank you guys
Thank you guys
Thank you guys
Thank you guys
Who are you emailing?? Couple of the boys have left
Call them gzim speak to Zach
We (Magnuson) supply NGK ILZKR7B11 plugs with our Hammer kit and have not experienced any issues. The ILZKR7B11 have a 16mm hex (OEM is 14mm) so you need a 16mm socket that is 20.7mm or less outside diameter to fit down the cam-cover sleeve.
You should be able to get a set of ILZKR7B11 for under US$80 with a bit of hunting.
You should be able to get them for under US$80 with a bit of hunting.
Before gapping, check this out:
http://www.ngk.com/learning-center/a...g-instructions
and
http://www.ngk.com/learning-center/a...i-gap-my-plugs
I run mine at 0.80mm (0.031"), but some of our installers run a little less (0.70-0.75).
and
and
and
Ah, I see. I'd live chat with Snap-on on Mon and see if they carry one or have a lead to source one. If they don't have it you may well be out of luck. They may be out there as an mfr dealer tool but you'll have to hunt one down.
2010 C63 AMG FBO, 2014 E63 AMG S
I just have header,exhaust,tune.Using one step colder plugs. Check with snap on, there sockets are thinner than other manufactures, so you can get it in the tube to torque down the plugs.
I have since found two other proper spark-plug sockets - one is from a local (Au) supplier & the other is a China supplier that we now buy in bulk and offer as part of a workshop installer kit.
I have been told that http://www.mactools.com/en-us/Specia...rk-Plug-Socket fits, but I suggest you call them and confirm.
However - most installing workshops simply buy a cheap (PepBoys, Napa, autozone or similar) 5/8" socket and turn it down.
NGK used to sell (gift) a moulded tube for it ... a long time ago.
