Phenolic spacer
One thing I was alerted to, is that these gaskets effectively make the intake manifold runner length longer (3/8"?). Not sure what impact that has, if any. I don't think its a major concern.
It's the whole reversion and then ram effect of when air bounces against the valves when they're shut and then time it takes for it to bounce back against the plenum and then finally back into the engine when the valves open again. When the runner length and rpm range/vacuum is just right, an extra amount of air will get shoehorned/rammed into the cylinder. It's a bit like boost....only it gives a few hp and not a hundred
If you asked me today if I would install it again the answer would be no.
