C63 AMG (W204) 2008 - 2015
Intake Manifold Gasket and PCV valve DIY
Old 08-12-2018, 05:18 AM
  #51
Celicasaur's Avatar
W212 - E63 AMG
Originally Posted by Zerocarpileup
what about the torque on the bolts on the throttle body cover plate?
I think it's 7nm.
Old 08-12-2018, 08:41 AM
  #52
BLKROKT's Avatar
Received 2,827 Likes on 1,670 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
The torque specs are in your DIY 82mm TB thread. It’s NOT gorilla tight. 12nm? They’re all the same and strip easily.
Old 08-12-2018, 09:19 AM
  #53
Celicasaur's Avatar
W212 - E63 AMG
It's either 7 or 9....defo not double figures though.
Yeah man they strip super easy....that's why I had to source a replacement intake manifold at one point.
Old 01-31-2019, 08:24 PM
  #54
KXC
KXC's Avatar
C63
Anyone ever hear of the plastic booster fitting leaking ? or know if it is serviceable ? I had the P0171 and P2187 lean codes. Local MB dealer hooked up the smoke machine and said the leak is in the fitting for the booster line itself, not the fitting on the hose side. There is no replacement or repair to their knowledge and the entire IM needs to be replaced (they say). Thoughts ??
Old 01-31-2019, 08:33 PM
  #55
Celicasaur's Avatar
W212 - E63 AMG
It can happen.
Try wrapping one layer or two layers of masking/duct tape around the portion of the booster line before slotting it in.
Too much tape and it'll kink badly and not seal. Not enough and it'll still leak.
Old 01-31-2019, 09:00 PM
  #56
KXC
KXC's Avatar
C63
Originally Posted by Celicasaur
It can happen.
Dam i was hoping there was a replacement fitting of some type. Thanks for the post
Old 02-03-2019, 03:38 AM
  #57
Zerocarpileup's Avatar
2008 S63
Question for everyone. I’ve noticed after performing the valve cover gaskets I still had a leak. Then I read somewhere that there’s a bulletin where Mercedes recommends adding their own gasket sealant to some points on the valve covers. That’s fine but my question is will I need that same sealant when doing the intake manifold gaskets? I’m heading some people are having trouble pulling the manifold off and finding sealant residue. M156
Old 02-03-2019, 11:12 AM
  #58
chrisridebike8's Avatar
'10 C63
you don’t have to pull the valve covers off to do this job. And pulling the intake mani off would not show you where sealant would be. That being said, I’ve never heard of this. I’ve only heard of leaking from failed or improperly installed valve cover gaskets.
Old 02-13-2019, 11:41 AM
  #59
Celicasaur's Avatar
W212 - E63 AMG
I just ordered a replacement pipe from Germany via my local dealer today as mine is leaking at the white plastic fitting that goes into the intake manifold, above the IAT sensor.
It might be a slightly different part number to the W204, as it starts with A212, but i'll take pics and post the part # when it arrives next week.
KXC (02-16-2019)
Old 02-19-2019, 06:50 PM
  #60
Celicasaur's Avatar
W212 - E63 AMG
Ok, so new pipe arrived a couple of days ago....I've given it several drives over two days and LTFTs are ~+7-8% bank 1 and ~-1.5% on bank 2.... CEL hasn't come back and I hope it doesn't. No stumble or wobbly idle that you sometimes get with a vacuum leak...power delivery feels smooth and strong...vacuum with throttle closed at 12.9 degrees opening is around -19.5 ....fingers crossed, this might well have solved my issue. If the CEL comes back, I'll let you know it failed. However it has definitely helped. Previously, the CEL was coming back within an evening and running the car rich. It's running nice and stoichy at idle, rather than 13.2:1AFR. For what it's worth, the pipe had a nice firm click that you'd expect from fresh tight plastic when I connected it to the brake booster. It felt tight and taught when inserting it into the intake manifold port also.
New and old...yes, the new one looks a tad smaller....either that or less stretched from the heat of the engine bay after 97k miles
Part number comparison
Worn old vs new
CEL pending, it's time to put this car for sale and get out of the AMG game for good
Old 02-19-2019, 07:18 PM
  #61
KXC
KXC's Avatar
C63
So the CEL came back after the new hose was installed ?
Old 03-09-2019, 04:41 PM
  #62
c63panda's Avatar
2012 C63 Coupe
If anyone needs pm me. Twenty for one, only two available. Repairing with a sleeve woulda worked but it just didn't feel right so I bought a used sprinter manifold (80$).
scalnajim (01-13-2020)
Old 03-27-2019, 02:42 PM
  #63
louiv2's Avatar
2008 W204 C300
What's the name I need one
What is this part called? I need one
Old 03-27-2019, 03:29 PM
  #64
BLKROKT's Avatar
It’s called, “you have to give Panda 20 bucks to find out”
PP-PRO_C63 (05-09-2024)
Old 03-27-2019, 08:51 PM
  #65
c63panda's Avatar
2012 C63 Coupe
Vacuum bung? Nobody knows but you can email pierburg and ask them, good luck on getting a reply
Old 06-16-2019, 06:31 PM
  #66
anomadtoo's Avatar
09 E63
Hose under Intake Manifold
How do you get the hose off that’s at the rear, under the manifold (without cutting ) thanks
Old 06-16-2019, 09:06 PM
  #67
c63panda's Avatar
2012 C63 Coupe
You pull
Old 06-16-2019, 09:15 PM
  #68
anomadtoo's Avatar
09 E63
Ok I got the line out of the underside rear of the manifold.
Now i can’t get the bottom off the intake manifold like in post #43. It won’t budge. All 13 screws removed but nothing. Need to clean inside chamber as oil leaked inside as well. It’s dripping out.
Thanks for any and all help!!
Old 06-16-2019, 09:29 PM
  #69
c63panda's Avatar
2012 C63 Coupe
Carefully pry. Remember to use some lubricant like vaseline when reassembling
Old 06-16-2019, 09:32 PM
  #70
anomadtoo's Avatar
09 E63
Believe me I’m trying to pry; it’s on there good. Not any leverage points either. Frustrating
Old 06-16-2019, 11:54 PM
  #71
anomadtoo's Avatar
09 E63
Panda, I finally got it loose. Now... how does this black line come off since it’s attached from the inside; therefore can’t completely remove the bottom of the manifold. Thanks again!
Old 06-17-2019, 02:33 AM
  #72
NaijaBerry's Avatar
2008 ML63 AMG
That's a rubber grommet, fold the entire thing inside the chamber, those are the wires that got to the throttle bodies, just press the whole rubber in
Old 06-17-2019, 09:21 AM
  #73
anomadtoo's Avatar
09 E63
Thank you for the help!!
Old 06-17-2019, 09:23 AM
  #74
Former Vendor of MBWorld
FCPEuro's Avatar
Mercedes
[QUOTE=anomadtoo;7780910]Panda, I finally got it loose. Now... how does this black line come off since it’s attached from the inside; therefore can’t completely remove the bottom of the manifold. Thanks again!
QUOTE]
Interested to know mileage on the E and if the center throttle plate has decay where the harness for the TB is routed.
--Kyle B
Old 06-17-2019, 09:31 AM
  #75
anomadtoo's Avatar
09 E63
Kyle, I’ll let you know and post pics once I get it apart; but I just hit 82k miles on my 2009 E63.
But here’s some with the intake manifold out and the terrible fuel injectors.
Quick Reply: Intake Manifold Gasket and PCV valve DIY
