C63 AMG (W204) 2008 - 2015
Boostane Octane Boost-Tried and Tested
Old Dec 30, 2016 | 12:59 AM
  #101
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
There is no magic here. The C63 is designed to run on 98 gas. Anything less than that and the ECU pulls timing. When the ECU pulls timing it generally pulls more than it needs to so you see dips in the dyno graph. This leads to a drop in power.
This gets even worse on a tuned car that is pushing more timing.
This test was done on a tuned car running 91 octane. So it would have been pulling lots of timing.
Add the booster, and it pulls less or no timing, and you make more power.
In South Africa, we get 95 fuel. I have run my C63 on the dyno on normal pump gas, then filled the tank with normal pump gas and added a bottle of NF, and driven back to the dyno. It consistently makes more power with the NF. I'll have to dig up the graphs to let you know the difference.
Methylcyclopentadienyl manganese tricarbonyl (MMT or MCMT) is what I assume is the main additive.
https://en.m.wikipedia.org/wiki/Meth...se_tricarbonyl
Old Dec 30, 2016 | 01:03 AM
  #102
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Originally Posted by BLKROKT
Math. Not too good. I get that you'd rather make up some formula, that's ok. For 12.8oz of anything to raise 8gal (1024oz) of 91 octane gas to 100, it would have to be over 1000 octane. What don't you get about this, it's a calculation, math, it's unarguable. I don't know how to make it any clearer for you slow guy. Your made-up formula there means precisely nothing because it's not based on, you know, logic.
lol you can keep making your meritless insults, just shows what a insecure little man you are and yes its math and because you got a number the indicates octane booster has a very high effective oct, you think it just cant be because nothing can have a higher octane than gas right? lmao! dude you have no clue about what you are talking about... torco (which is similar to the octane booster) has been tested before and it comes in about 462.... keep arguing with results as if that is going to change the dyno lol
Old Dec 30, 2016 | 01:05 AM
  #103
gaspam's Avatar
finally someone that gets it
Old Dec 30, 2016 | 01:06 AM
  #104
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
So you're saying that this stuff has over twice the effective stand-alone octane rating as Torco. Ok.
Old Dec 30, 2016 | 01:14 AM
  #105
gaspam's Avatar
nope, about 40.6 % more ( ~650) ... its funny you keep thinking octane booster in terms of gas concentrations ... its like comparing coca leaf concentration vs pure cocaine lol.... there is a reason you only put 16oz in your gas tank
i've used torco in my b5 s4 and picked up 15-20whp on dyno without changing my timing map same day before and many other people on the bmw s63tu platform and gtr as well... this is nothing new
Old Dec 30, 2016 | 02:01 AM
  #106
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
+1. I know my ecu pulls timing due to our CA 91 octane crap. I can understand BLKROKT's argument; he's simply saying that that octane booster isn't effective enough. I dunno. I'd love to find an effective solution though bc I know my car could put out more ponies with even 93.
Old Dec 30, 2016 | 09:16 AM
  #107
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by Jasonoff
I could likely reproduce this exact data by adding 89OCT fuel to an empty tank for a few pulls, then dumping and refilling with 91 for the other pulls.
for someone that thinks he's expert in the laws of physics and mechanically inclined, and puts down others he thinks isnt, you sure dont seem to know how much 2 oct (91 vs 89 from your example) is worth in timing and thus hp... general rule is 1.5 oct per 1 degree of timing, and 2-3 hp on n/a motor per degree, so lets do some math.... (91-89)/1.5= 1.33 timing, so 1.33 x 2 hp = 2.66 HP for 89 oct to 91 oct on low est and 1.33 x 3 hp = 3.99 HP for 89 oct to 91 oct on high est... thats a far cry from the 23 hp gained... try again with another excuse
I may have missed the part where I said I was an expert in the laws of physics, my bad if I did actually state that somewhere (I didn't BTW...).
It's not just the octane delta, it's also how much timing would be pulled on 89 and I doubt it would be linear. Incase you don't understand, I am betting on a similar HP loss with 89 vs 91 (maybe 23WHP ) than the HP gain from 91 to whatever this magic sauce raises it to.
Not discrediting the gain, but there's something else at play that this booster may or may not be overcoming something such as pulled timing due to garbage fuel.
I pretty much say the exact same thing with less words and he gets it but I don't?
You're way too emotional about this stuff.
Old Dec 30, 2016 | 10:09 AM
  #108
SuperFastYo's Avatar
C63 AMG - LSD
Everyone:
Me:
playing devils advocate: Considering what people are saying, couldn't I just add a bit of e85 and get the same results?
Old Dec 30, 2016 | 11:34 AM
  #109
Savage-wp's Avatar
Originally Posted by SuperFastYo
Everyone:
Me:
If the car can use E85, then yes. Anything that yields a higher octane rating will have less to no detonation, and therefore no retarded timing, which would give more power.
Old Dec 30, 2016 | 11:38 AM
  #110
C63 AMG - LSD
I'm sure a gallon wouldn't hurt much, would it? That should raise the octane at least close to the specified 98 octane. I would run 50/50 in my 335i (but I was modded and boosting at about 18psi so huge difference in setups). I never replaced my LPFP or HPFP or any of my fuel lines. It ran fine, so Im only assuming we can run a little in our tanks. Again, could be wrong but thats just based off my experience.
Old Dec 30, 2016 | 11:45 AM
  #111
Cli63's Avatar
2012 c63
Isn't US 91/93 equivalent to 95/98 RON? So if you are boosting the octane to 100 on US gas won't that be around 110+ in RON?
Old Dec 30, 2016 | 12:09 PM
  #112
gaspam's Avatar
and this is where you obviously dont know anything about timing and oct... as i explained 2 oct points is nowhere near enough to cause the timing pull that would result on 23whp change.... like i illustrated before, its worth maybe 1 to 1.5 degrees of timing pulled... if you think that is worth 23 whp then you have never tuned a car or messed with any timing tables and tested timing tweeks... again, 1 degree of timing is worth maybe 2-3 hp on a n/a motor and 2pt change in oct isnt going to pull more than 2 degrees of timing (and therefor no more than 3-4 hp)...again, come up with a better excuse as to why the dyno results dont fit your narrative
Old Dec 30, 2016 | 12:13 PM
  #113
C63 AMG - LSD
lol chill Gaspam, were just talking about octane of gas. Not world politics
Old Dec 30, 2016 | 12:41 PM
  #114
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
So you're saying this is true for any NA motor regardless of output? Cool...
Old Dec 30, 2016 | 12:42 PM
  #115
gaspam's Avatar
E85 is great, but you would have to have tank of almost 100% e85 to get the same effective octane of what the octane booster is supposed to do (get you around 100-104 oct).. and then you need to tune, bigger injectors, bigger fuel pump to notice advantage of e85 due to different stoichiometric afr of it vs gas
also ethanol has about 35% less energy that gas, so unless you increase you're fueling you will lose power...gas has a stoichiometric afr of 14.7 to 1, E85 is 9.8 to 1. So on pump gas we need 14.7 parts air to mix with 1 part gas. On E85 its 1 part fuel to 9.8 parts air. So on E85 the afr needs to be a lot richer, which means it has a larger volume of fuel. For this you need to inject around 35% more e85 to mix with the same volume of air when we switch from gasoline to E85.
i've only seen 1 MB guy running e85 over on the e55 forum and it wasnt an easy path... MB's are a pain with tuning
Old Dec 30, 2016 | 12:49 PM
  #116
gaspam's Avatar
it has some variance, but not a 475% variance (23hp vs 4 hp)... for a N/A car that is 300-500 hp the margin of error wouldnt be that big.... for a 8000 hp nitromethane car then sure that hp per degree of timing would be off, but that's not what we are talking about
Old Dec 30, 2016 | 01:00 PM
  #117
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What about RPM, displacement, crank/rod geometry, compression ratio, temperature, fuel table, etc?
Can you also explain how this magic sauce nets a larger gain without being specifically tuned for vs one that has been specifically tuned for with race fuel?
Does that mean you're implying using this stuff on a tuned for 91 C63 is better than using race fuel with a specific tune for it?
Old Dec 30, 2016 | 01:45 PM
  #118
skratch77's Avatar
2005 E55
I have 93 Oct here will this stuff do anything with 93 Oct or is it for people using 91
Old Dec 30, 2016 | 02:15 PM
  #119
gaspam's Avatar
lol crank/rod geometry... you're grasping
you know you gain hp on no2 without tuning for it either right? magic sauce strikes again .. same as nitropropanes/nitroparraffins used in concentrates power adders
and no, specific tune for specific octane is always best.... keep in mind, no tune is 100% perfect in all conditions, in every gear at every speed and every baro pressure, etc. hence why you're car will adjust timing and higher oct will mitigate that to an extent when it happens
Old Dec 30, 2016 | 02:18 PM
  #120
gaspam's Avatar
You can only add so much timing before the motor starts to lose power regardless of what you have for Octane, so biggest bang for the buck is going to be guys on lower 91 octane
Old Dec 30, 2016 | 02:48 PM
  #121
BLKROKT's Avatar
E85 is great, but you would have to have tank of almost 100% e85 to get the same effective octane of what the octane booster is supposed to do (get you around 100-104 oct).. ...... blah blah blah blah
You're on ****ing drugs if you think any octane booster is getting you 100-104 octane (AKI not RON). It may be able to mask low quality gas, but you're not getting instant race gas from this stuff. Put down the pipe.
Old Dec 30, 2016 | 02:57 PM
  #122
Savage-wp's Avatar
Definitely agree with you there. Proper race gas, is always going to be better than pump gas with octane booster.
Old Dec 30, 2016 | 03:01 PM
  #123
gaspam's Avatar
you're to dense to know the difference between an autoparts store octane booster (crap) and a race fuel concentrate (torco, boostane, etc...), they are not even close to the same and its been tested many times, old news that you still havent heard (by the way, the earth isnt flat but im sure you think all those satellite images of earth are a hoax lol)
i gained 2 mph trap using torco on my b5 s4
hell, even coxoc gained 20 hp under curve on a old mustang like 10yrs ago
http://www.mustangandfords.com/how-t...ower-additive/
Old Dec 30, 2016 | 03:04 PM
  #124
C63 AMG - LSD
Old Dec 30, 2016 | 03:08 PM
  #125
gaspam's Avatar
I dont disagree with this... a uniform mixture of pure race gas is better if you can afford to run it and have a VP/sunco station nearby... concentrates can be harsh on fuel systems but they do work... now octane booster from pepboys, different story (crap)
