throttle % wide open stock vs tunes?
that's what I'm trying to figure out.my car was bought from Miami and was tuned in-house at renntech by previous owner and it felt flat after getting it back and was curious if i could tell if it's still tuned by the throttle % it's opening without putting it on a dyno
so at least we have one stock that might be tuned to compare with.i was reading on 6speed forums that those people were saying stock cars don't open up past 70-75% throttle but no one really confirmed it .
I'm trying to see if the WIS has a testing procedure for the throttles with an angle to be measured or something similar.
I guess AAT is Ambient Air Temperature
Received 2,830 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
You guys really know how to beat a dead horse
#32
Guys, is there a simple way to find out what the individual throttle body opening % is? ie, to diagnose a fault and double check if they're opening as they should be?
#34
The dead horse is that all untuned the cars open 87%, or that all unturned cars open 70%?
And do you want to provide a link to a thread where this issue has already been beaten to death? because the previous link only has someone mentioning that they think that all unturned cars open to 70-something%
As far as INDIVIDUAL throttle opening, use an OBD2 scanner and you will see the percentage.
It would be nice if more people would post here the scanned throttle opening percentage, so that there is a more clear understanding of what this should be.
I'd also like to see the throttle opening percentage of the P30/31 cars.
#35
Do a search. Both here and Google. I turned up 4 threads where this is discussed in great detail.
#37
Go get ****ed
#40
Maybe you should start a new thread about it. Seems like every time you open your stupid pie hole the thread gets shut down by a mod. Seeing the pattern yet genius?
Jasonoff (09-20-2016)
#42
It's also a "Thanks", not a "Like" for the post. I see your attention to detail hasn't improved.
This would have been much better in a new thread because adding to this one isn't actually adding more information. It would have in a new thread. Nobody is benefiting now. Makes me sad...
#43
You know, in psychology terms they would call this 'projecting'. Really, I'm flattered, but sorry I'm happily married big boy.
Here you go since you have so much trouble with our language and looking things up:
Psychological projection is a defense mechanism people subconsciously employ in order to cope with difficult feelings or emotions. Psychological projection involves projecting undesirable feelings or emotions onto someone else, rather than admitting to or dealing with the unwanted feelings.
#46
C63 507 AMG DA Car #19
If the TB only opens to 70-80% max due to the shaft.... then why where people buying ported TB's with the shaft ground down if the blade only opens 70-80%? Seems like a silly mod.
I amazed at the amount of mis-understanding of this platform, and conflicting information provided on the inter web and in the community.
#49
There. Fastest guy on the board said it. Are we done now?
87% *IS* indicative of a tune. It's a known fact.
#50
