C63 AMG (W204) 2008 - 2015
throttle % wide open stock vs tunes?
Old Sep 21, 2016 | 11:07 AM
  #51
Tlnt60's Avatar
2012 C63 AMG Coupe
Mine has a tune. '12 MY coupe within LTH, HiFlo Cats, stage 3 tune from dyno comp. It reads 86.4% opening.
Old Sep 21, 2016 | 12:45 PM
  #52
Vladds's Avatar
2010 C63 2019 GLA45
Originally Posted by BLKROKT
There. Fastest guy on the board said it. Are we done now?
87% *IS* indicative of a tune. It's a known fact.
It IS NOT.
And this is the exact reason why you should not try to stop the research for factual data.
BTW, all those search results?
The numbers for untuned don't even match, some type 60%, some 70 degrees, some 74% and not one of them posted first hand not tuned numbers, only first hand tuned numbers.
First of all a lot more detail has to be discussed, so that we can sift out the useful information.
Was it 87% opening, or was it 87 degrees angle of opening?
Was it Absolute throttle position or relative throttle position?
Take a look below at the throttle percentage with accelerator resting.
How does it correlate to the throttle actuator percentage? Is the actuator supposed to peg 100%, or not?
Easiest way is to have one known stock car obd2 readings. I think that is mine, but let's see a stock car owner post numbers, to confirm mines.
Old Sep 21, 2016 | 12:59 PM
  #53
skratch77's Avatar
2005 E55
Originally Posted by Vladds
It IS NOT.
that's what I'm trying to figure out.bot one single post showed actual proof and people were just throwing numbers around.
Old Sep 25, 2016 | 08:04 PM
  #54
Vladds's Avatar
2010 C63 2019 GLA45
Additional info here:
So with the pedal floored:
Throttle position TP is 87%. This is an absolute parameter, since with accelerator resting, it is at 15%
Throttle Actuator Command Percentage TAC_PCT is at 100%.This is relative, since it is at 1% with pedal resting.
Throttle position relative TP_R is 74%, this by definition is the relative actual opening percentage and I interpret that 3% opening of it with pedal resting as a mechanical value (maybe it is opened at 3% for idle, even with key off)
TP_B is another absolute reading.
The others are Accelerator pedal position sensors, that are relative.
So here is what I think:
I obviously acknowledge what people that have tunes posted as far as the percentage that they see.
My question is regarding the numerous details (which of the throttle position differs, were there angle, or percentage differences and is it possible that the difference only shows while driving and over 5500RPM).
I continue to think that my car is not tuned.
At this stage I think that maybe the TP_R, the relative position is where the difference shows, which would mean that my car is at 74%, while the tuned guys are seeing the TP_R at 87%.
Obviously, the confusion here is that the "generic" TP, is an absolute value and it so happens that it reads 87%, therefore I try to get the details sorted out.
Attached Thumbnails throttle % wide open stock vs tunes?-photo364.jpg   throttle % wide open stock vs tunes?-photo322.jpg
Old Sep 26, 2016 | 11:32 AM
  #55
MJames2's Avatar
AMGs
wheres J-cart when you need him? Pretty sure he's the only guy besides mario actually qualified to speak about things like this due to their extensive knowledge of these cars
Old Sep 26, 2016 | 11:38 AM
  #56
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Says the new guy with 16 posts who can't even get jrcart's name right
Old Sep 26, 2016 | 12:41 PM
  #57
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Does that guy even wrench cars?
Old Sep 26, 2016 | 04:06 PM
  #58
the2000r's Avatar
c63
Old Sep 26, 2016 | 05:38 PM
  #59
mthis's Avatar
Anything W/4Wheels
My daily tune 88% logged with Zeitronix zt2.
Old Sep 30, 2016 | 03:50 AM
  #60
kimeran's Avatar
2012 C63 AMG, 1991 325iS. Ex: 2011 C63 P31
Hi guys
I've been interested in this for a while.
I have a P31, but I don't know if it has a tune or not.
Anyway here is a pic of the logs using OBD2 tool.
Old Sep 30, 2016 | 06:56 AM
  #61
Vladds's Avatar
2010 C63 2019 GLA45
I'm going to try to take a log of what's happening over 5500 RPM with mine.
Old Sep 30, 2016 | 08:06 AM
  #62
Celicasaur's Avatar
W212 - E63 AMG
I'm hoping to get my car scanned on STAR tomorrow at Eurocharged.
From what I understand, via an OBDII scanner thing the trump figure is 89% or something like that, but via STAR it's 78% (or something in that range).
I'm told that I will be able to obtain individual throttle body voltage at WOT, which should tell us which one of my throttle bodies (or both) have crapped out.
Does anybody here know what the max voltage per throttle body should be? I'm guessing we're talking about TPS voltage.
Old Oct 1, 2016 | 09:36 AM
  #63
Celicasaur's Avatar
W212 - E63 AMG
Hi guys, I got my car scanned today at Eurocharged.
For reference, on a STAR system, the throttle should be 78% when fully opened.
Voltage per throttle body should be 4.35V when fully opened.
Old Oct 1, 2016 | 11:09 AM
  #64
MJames2's Avatar
AMGs
i highly doubt your TBs have **** the bed ...the only reason the other guys are breaking TBs is because their pushing 600-700+ HP through them lol
Old Oct 10, 2016 | 02:45 PM
  #65
mthis's Avatar
Anything W/4Wheels
Old Oct 11, 2016 | 02:57 AM
  #66
Celicasaur's Avatar
W212 - E63 AMG
Looks good ^ Thanks for sharing.
On non-STAR systems, the trump figure is indeed 87% as it's worked out as a ratio of 100....or something like that. I can't remember the exact ins and outs of it.
Old Oct 11, 2016 | 07:23 AM
  #67
Vladds's Avatar
2010 C63 2019 GLA45
If mine shows 87% & 74% relative, over 5500 RPM, I guess next step is dyno.
Old Oct 23, 2016 | 01:34 PM
  #68
Vladds's Avatar
2010 C63 2019 GLA45
Here are some logs.
The first one from the left is with traction control on.
I'll post the details:
RPM, in pink climbs to 6610 RPM
Throttle position maxes at 60% and relative to 48%, at 5250 RPM. Then although still floored they drop to 52 & 40 %
The second one is with traction control in sport mode
RPM climbs to 6900 RPM
Throttle position maxes at 61% and relative to 48%, at 5100 RPM. Then although still floored, they drop to 52 & 40 %
The third one is with traction control off
RPM climb to 5850
Throttle position maxes at 60% and relative to 48%, at 5150 RPM. Then, although still floored, they drop to 52 & 40 %
Fourth one is with traction control off
RPM climb to 6230
Throttle position maxes at 60% and relative to 48%, at 5050 RPM. Then although still floored, they drop to 52 & 40 %
Here's how I interpret this:
With the engine off, the throttle opens to the stops, which are 87% and 74% relative.
With the engine on, un-tuned, the most the throttle will open is 60% with relative 48% and this is no further than 5200 RPM, then it drops to 52 & 40%.
In order to determine if you have a tune, you cannot check the logger with the engine off, you have to do pulls and don't worry about traction control, the results throttle wise end up being the same.
Attached Thumbnails throttle % wide open stock vs tunes?-photo655.jpg   throttle % wide open stock vs tunes?-photo656.jpg   throttle % wide open stock vs tunes?-photo606.jpg   throttle % wide open stock vs tunes?-photo902.jpg
Old Oct 23, 2016 | 03:49 PM
  #69
Celicasaur's Avatar
W212 - E63 AMG
Brilliant findings ^^^ thanks for sharing.
Vladds, is your car stock?
I find that information really interesting. My scan was done with the engine off. I think I now need to get it scanned with the engine running on a dyno or on the road.
Old Oct 23, 2016 | 04:04 PM
  #70
Vladds's Avatar
2010 C63 2019 GLA45
My car is second hand, so I questioned if it is stock, but at this stage I am reasonably convinced it is.
Old Oct 23, 2016 | 04:11 PM
  #71
Celicasaur's Avatar
W212 - E63 AMG
Perfect.
Old Oct 23, 2016 | 07:16 PM
  #72
skratch77's Avatar
2005 E55
ok I just need to log mine with to see what I get.im pretty sure mb limits power on the tunes by throttle openings vs timing advance and fuel
Old Oct 24, 2016 | 04:13 PM
  #73
bhamg's Avatar
C63 AMG
Now that is some great, useful info! Guess the self-appointed forum policemen don't know it all after all.
Old Jul 8, 2017 | 07:09 PM
  #74
Infiniti's Avatar
a unicorn tuned p30 e63
my car only spun to 6792 rpm and throttle was 86.3% my car has the unicorn tune as most know. i did just bore my throttle body shafts, LTH, custom intake mods, row and thermal intake spacers.
my buddies car has row, ec v6 tune
his throttle went 87.5 mins did 86.3 and IAT is also a mystery.
thoughts?
Old Jul 8, 2017 | 09:16 PM
  #75
Celicasaur's Avatar
W212 - E63 AMG
I'm confused....seems like a negligible variance between the two.......
Are you asking why your throttles opened to 86.3 vs his 87.5....?
