Help ! Wheel fitment and offset 19 inch rims
Hey everbody, Great forum ! I apologize if this has been discussed before but im about to pick up my 2013 C63 Sedan this week and i have found some great 19 inch wheels, they are 19x8.5 offset 40 and 19x9.5 rear offset 40, the wheels are AMG Reps.
I'll be wrapping them in Michelins PSS 235/35/19 front and 255/30/19 Rear....i am a bit of a noob so before i purhcase them i wanted to to get some insight as to whether this combination will fit the car without any rubbing issues (car will be stock height)...Any feedback would be great or if anyone has this comnination that could help, Thanks
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
From what I understand you should be OK with just 1/2" increase in wheel width as you are not approaching the limits of width generally recommended.
My winters are running on 8.5 inch wheels ET 43 on BA with 235/35 tires.
Rpjizzle (11-28-2016)
According to WillTheyFit.com you are good to go as far as clearance is concerned. Both axles come in with 7 mm more inside clearance from the suspension and will poke out 20 mm more than the stock 8 x 19 ET45 and 9 x 19 ET 54s.
Just noticed but you made a brand new thread for this, after you already had this one https://mbworld.org/forums/c63-amg-w...-question.html.....
The following 2 users liked this post by INS1GNIA:
BLKROKT (11-28-2016),
SuperFastYo (12-06-2016)
BLKROKT (03-16-2018)
Damnit, that made me go to our breakroom and get one lol....sooo goood!
This right here Alex.currie44, the fact that the sarcasm went by him and he missed the "why u" meme ... this is why things happen.
The following 2 users liked this post by Adi-Benz:
BLKROKT (03-16-2018),
chrisridebike8 (12-06-2016)
Front no issue rear will be close. Pss tires run wider then most. If you lower it. It will def rub. Stock height it's a gamble. I personally wouldnt go that aggressive of a rear offset.
Rpjizzle (11-29-2016)
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
19x9.5 +40 rear is very aggressive. U will rub if lowered or at stock height, u won't be able to carry passssngers w/o rubbing.
Looks like u bought the wheels already. Post pics & report back on fitment.
I'll upload some pics in the proper thread after i have washed the car , but im happy with the fitment as i wanted a slightly more aggresive look, The wheels are C63s Reps 19x8.5 -19x9.5 ET 40 all wheels wrapped in Michelin PSS 235/35/19 front and 255/30/19 rear So far no rubbing on my own, with 2 adults in the back also no rubbing.
Thanks to those who offered helpful advice
